K000001
K000001
    ARDUINO
    KIT TINKERKIT BASIC
K000001 数据手册
Datasheet Arduino TinkerKit Base K000001 The Base Kit is a pack of different TinkerKit Modules, aimed to start designing interactive environments / prototype interfaces without using the breadboard or the soldering iron. The Base Kit consists in the Sensor Shield V.2, 7 different Sensors and 5 Actuators, cables, and more. Kit Includes: Description Sensor Shield V.2 Button Module LDR Module Tilt Module Therm Module Rotary Potentiometer Module Linear Potentiometer Module Touch Sensor Module Relay Module 5mm Green Led Module 5mm Yellow Led Module 5mm Red Led Module 10mm Green Led Module 20cm Cables 50cm Cables 100cm Cables Part Number T020010 T000180 T000090 T000190 T000200 T000140 T000150 T000220 T010010 T010112 T010113 T010114 T010116 T020060 T020070 T020080 Quantity 1 1 1 1 1 1 1 1 1 1 1 1 1 4 2 1 Arduino TinkerKit Base available at Mouser Electronics: K000001 Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet
K000001 价格&库存
很抱歉,暂时无法提供与“K000001”相匹配的价格&库存,您可以联系我们找货
