Page 1 of 2
SparkFun ISP Pogo Adapter
KIT -1 1591 RO HS
Description: Pogo pins make life so much easier when you are trying to program
without having to solder a single thing, and when you attach them to an In-system
programming (ISP) adapter they become instantly better, this simple kit allows you to
do just that. Introducing the ISP Pogo Adapter, a simple and easy way to adapt pogo
pins to a 6-pin ISP header allowing you to program an IC still without soldering a
header to do so.
We’ve also included a labeled SIP header row and a 6-pin molex cable for you to be
able to use your Arduino (or other single-board microcontroller) as an ISP device!
This adapter does come as a kit and assembly will be required.
Page 2 of 2
Kit Includes:
1x ISP Pogo Adapter PCB
1x Molex Jumper 6 Wire Assembly
1x JST Right Angle Connector
1x Male ISP Header
2x 3/8" Plastic Standoff
4x ¼" Phillips Head Screw
6x Pogo Pin with Pointed Tip
https://www.sparkfun.com/products/11591
8/5/2016
很抱歉,暂时无法提供与“KIT-11591”相匹配的价格&库存,您可以联系我们找货
