KIT-13154
KIT-13154
    SPARKFUNELECTRONICS
    INVENTOR KIT FOR ARDUINO UNO
KIT-13154 数据手册
Page 1 of 2   SparkFun Inventor's Kit (for Arduino Uno) V3.2 KIT -1 3154 RO HS   Description: The SparkFun Inventor’s Kit (SIK) is a great way to get started with programming and hardware interaction with the Arduino programming language. The SIK includes everything you need to complete 16 circuits that will teach you how to read sensors, display information on an LCD, drive motors, and more. You don’t need any previous programming or electronics experience to use this kit. The on-line SIK Digital Guide (in the Documents section below) contains step by step instructions of how to connect each circuit with the included parts. Full example code is provided and explained and even includes troubleshooting tips if something goes wrong. The kit does not require any soldering and is recommended for beginners ages 10 and up. This International version includes the new Simon Says circuit experiment found in the V3.2 SIK with all the LEDs and tactile buttons you will need to complete it, the kit also replaces the SparkFun RedBoard for the tried and true Arduino Uno and removes the SIK Guidebook and carrying case. With these parts being swapped and removed we were able to reduce the overall size and weight of the kit making shipping cheaper and easier for anyone ordering it internationally. Note: As stated above, this SIK does NOT include a carrying case. If you would like to purchase one separately they can be found in the Recommended Products below. Page 2 of 2 Circuit Examples: • • • • • • • • • • • • • • • • Circuit 1: Blinking an LED Circuit 2: Reading a Potentiometer Circuit 3: Driving and RGB LED Circuit 4: Driving Multiple LEDs Circuit 5: Push Buttons Circuit 6: Reading a Photo Resistor Circuit 7: Reading a Temperature Sensor Circuit 8: Driving a Servo Motor Circuit 9: Using a Flex Sensor Circuit 10: Reading a Soft Potentiometer Circuit 11: Using a Buzzer Circuit 12: Driving a Motor Circuit 13: Using Relays Circuit 14: Using a Shift Register Circuit 15: Using an LCD Circuit 16: Simon Says Kit Includes: • • • • • • • • • • • • • • • • • • • • • • • Arduino Uno - R3 SMD Arduino and Breadboard Holder White Solderless Breadboard SparkFun Mini Screwdriver 16x2 White on Black LCD (with headers) 74HC595 Shift Register 2N2222 Transistors 1N4148 Diodes DC Motor with Gear Small Servo SPDT 5V Relay TMP36 Temp Sensor Flex sensor Softpot 6' SparkFun USB Cable Jumper Wires Photocell Tri-color LED Red, Blue, Yellow, and Green LEDs Red, Blue, Yellow, and Green Tactile Buttons 10K Trimpot Piezo Speaker 330 and 10K Resistors https://www.sparkfun.com/products/13154 8/5/2016
KIT-13154 价格&库存
很抱歉,暂时无法提供与“KIT-13154”相匹配的价格&库存,您可以联系我们找货
