K030007
K030007
    ARDUINO
    ARDUINOSTARTERKITSPANISH
K030007 数据手册
  Arduino Starter kit SPANISH SPANISH EDITION - SPANISH LANGUAGE Arduino Starter kit SPANISH   This kit walks you through the basics in a hands-on way, with creative projects you build by learning, thanks to a selection of the most common and useful electronic components with a selection of 15 projects that start from a low complexity, in order to let you learn the basic of electronic, to a major one, using components that let you control the physical world throw different kind of sensor. Once you have mastered this knowledges, you will have a palette of software and circuits that you can use to create something beautiful, and make someone smile with what you invent, that is the reason why you will find more components than the required from the projects of the book. Then build it, hack it and share it. Because arduino is you! The kit includes: 1 1 1 1 1 1 70 2 6 3 10 1 1 1 1 1 8 8 8 3 1 1 1 1 2 5 2 5 3 5 5 3 1 20 5 5 5 10 5 5 Arduino Projects Book (170 pages) - Spanish Arduino UNO board rev.3 USB cable Breadboard Easy-to-assemble wooden base 9v battery snap Solid core jumper wires Stranded jumper wires Photoresistor Potentiometer 10kilohm Pushbuttons Temperatursensor Tilt sensor LCD alphanumeric (16x2 characters) LED (bright white) LED (RGB) LEDs (red) LEDs (green) LEDs (yellow) LEDs (blue) Small DC motor 6/9V Small servo motor Piezo capsule H-bridge motor driver Optocouplers Transistor Mosfet transistors Capacitors 100nF Capacitors 100uF 100pF capacitor Diodes Trasparent gels (red, green, blue) Male pins strip (40x1) Resistors 220 ohm Resistors 560 ohm Resistors 1 kilohm Resistors 4.7 kilohm Resistors 10 kilohm Resistors 1 megohm Resistors 10 megohm   Model: K030007 Shipping Weight: 0.9667Kg  Origin: Italy     http://www.arduinosrl.it/catalog/index.php?main_page=product_info&products_id=424 3/27/2017
K030007 价格&库存
很抱歉,暂时无法提供与“K030007”相匹配的价格&库存,您可以联系我们找货
K030007
    • 1+836.89760
    • 10+813.64351
    • 25+789.23347
    库存:27
    K030007
      库存:25
      K030007
        库存:28
        K030007
        • 1+968.350341+121.11844
        • 10+948.9487210+118.69175
        • 25+932.5354325+116.63882
        • 50+907.8676250+113.55344
        • 100+866.69288100+108.40342
        库存:3
