240-064
240-064
    DIGILENT(迪芝伦)
    STARTERKITCHIPKIT32BIT
240-064 数据手册
Page 1 of 2 Digilentinc.com Blog Learn Search chipKIT™ Starter Kit Part # 240-064-KIT Hide Details The chipKIT Starter Kit provides a wide range of sensors, actuators, and electronic components at a remarkably low cost, enabling the construction of an endless array of projects that can serve to inform beginners or empower experts. The kit has been designed for use with our chipKIT™ boards, 32-bit microcontroller-based platforms that are compatible with much of the existing Arduino code base, reference material, and other resources. The kit’s parts have been selected to facilitate the creation of fun, useful, and entertaining projects, while at the same time facilitating the exploration of multiple disciplines, from optics to mechanics, from electrical engineering to computer science. Projects can range from as simple as blinking LEDs, to performing tracking based on optical information, to much more! Note: This kit can be bundled along with a chipKIT™ Uno32, Max32, WF32, or uC32 for a discount! Complete parts list: Qty. Description: Qty. Description: Integrated Circuits: Electro-Mechanical: 2 IC TCA0372, Op Amp, dual, 1A, DIP8 1 Speaker Buzzer, 3.1KHz, 4-6V, Ext Drv, PCB Mount 1 IC NE555P, Timer, DIP8 1 Mechanical 1/102 DC motor 1 IC MCP4902-E/P 1 Mechanical TPRO Servo SG92R 1 IC Darlington pair array, HV, DIP18 1 Mechanical Stepper motor, 5V 1 IC L293DNE, motor driver, Quad half-bridge, DIP16 4 Switch TSA12111, 12mm SPST button 1 IC MCP9700-E/TO, thermal sensor, 2.3V, TO-92 4 Switch SPST, momentary push button, PC mount 1 IC MCP6546-E/P 4 Switch SPDT, slide, PC mount 1 IC SN74HC4851N, MUX/DEMUX, 8x1, DIP16 4 Potentiometer 10K ohm w/thumbwheel 1 IC 74HC7014N,112; buffer, hex schmitt trigger, DIP14 1 Relay JZC-11F-5VDC-1Z Relay 3 IC SN74HC595N, 8 bit shift register, DIP16 1 IC MCP23008-E/P 1 IC SN74HC139N, decoder/DEMUX, DL 2-4L, DIP16 1 Inductor TK4460-ND, FIXED 1000UH TYPE 8RHB 1 IC UA78L05ACLPR, 5V regulator, 100ma, TO-92 10 Capacitor 0.01uF, ceramic disc, radial 10 Capacitor 0.1uF, ceramic disc, radial Passive Components: Active Components: 5 Capacitor 10uF, electrolytic, 50V, radial 4 Transistor ZVN2110A, N-FET 25 Resistor 10K ohm, carbon film, 1/4W, 5% 4 Transistor ZVP2110A, P-FET 25 Resistor 220 ohm, resistor, axial, 1/4W, 5% 4 Diode 1N4001, rectifier, 50PIV, 1A DO-41 2 Resistor FSR 402 round force sensing resistor, circ w/tab Learn more about Digilent Design Contest 2014! Sensors: 3 Resistor 1.0M ohm, carbon film, 1/4W, 5% 3 Resistor 10 Mohm Resistor, axial, 1/4W, 5% 1 Thermistor 10K ohm, %5 NTC 450mW, radial 1 Sensor Piezo sensor, 1.4 V/g, SPST, solder lug 2 Sensor 5K-20K ohm photocell, 4.20mm 1 Wire Kit 70 piece, 22AWG Round Tips 1 Photo Transistor QSC114, IR Photo Trans, T1, 880nm 2 Cable, 22AWG, 1x6 pin Red-Black-Yellow-Blue-Green-Brown 1 Kit 6 Pin Male header, 5 Pack 1 Battery Holder 4xAA Battery Holder, Wire Leads, 2 Pin MTE 1 Solderless Breadboard 1030 Tie-Point Opto-Electronics: 1 Display LED, 7-segment, 4 digit, CA, 0.56, hi-bright Accessories: Page 2 of 2 Qty. Description: Qty. Description: 1 1 Display LCM-S01602DSF (SC1602ZS*B-XA-GS-G01), 16x2 character, no backlight 1 LED Straw hat Tricolor LED 12 LED Orange/yellow, T 1-3/4 12 LED Green, T 1-3/4 12 LED Red, T 1-3/4, with flange 1 LED QED123, IR Emitter, T 1-3/4, 880nm Digilent, Inc. | P.O. Box 428 Pullman, WA 99163-0428 | (509) 334-6306 (voice) Box E-201 Component Box (509) 334-6300 (fax) | Contact us http://www.digilentinc.com/Products/Detail.cfm?NavPath=2,719,1232&Prod=CHIPKIT-STARTERKIT 5/2/2014
240-064 价格&库存
很抱歉,暂时无法提供与“240-064”相匹配的价格&库存,您可以联系我们找货
