1308
1308
    ADAFRUIT
    KIT CALCULATOR SPEKENZIELABS
1308 数据手册
Page 1 of 2 KITS & PROJECTS / SPIKENZIE SpikenzieLabs Calculator Kit PRODUCT ID: 1308 Page 2 of 2 DESCRIPTION - The SpikenzieLabs Calculator Kit another one of a kind, 100% original SpikenzieLabs' kit. Easy to solder with through hole parts that it is both useful and super cool! Comes as a kit of electronic and plastic parts, after it is assembled you will have a lovely battery-powered pocket calculator. If you're feeling extraadventurous, the chip is programmed with an Arduino-compatible bootloader so it's very hackable as well. Some tools are required to assemble: soldering iron, solder, and wire cutters. You'll also want some masking tape and a hex wrench (although we just used pliers assemble the screws) Features: • • • • • • • Add, subtract, multiply & divide. No computer is required, ships pre-programmed. It is easily modified using the Arduino IDE. Six bright red 7 segment LED modules. Powered by a single CR2032 battery. Instant-on, automatic sleep, extra long battery life. Layered laser cut acrylic case. http://www.adafruit.com/products/1308 7/24/2015
很抱歉,暂时无法提供与“1308”相匹配的价格&库存,您可以联系我们找货
