110060157
110060157
    SEEED(矽递科技)
    GROVE STARTER KIT FOR 96BOARDS
110060157 数据手册
Page 1 of 3 (images/product/110060157 1.jpg) Grove Starter Kit for 96Boards SKU: 110060157 Page 2 of 3 Description The 96Boards Sensors starter kit contains everything you need to wire up sensors and devices to a 96Boards single board computer. It contains the 96Boards Sensors mezzanine board with a selection of Grove modules that you can use to start experimenting and prototyping with the 96Boards platform. Sample projects are provided for all of the included modules, and additional Grove modules can be purchased separately and used with this kit. Please note: A 96Boards baseboard is not included. This kit has been tested and works with the Qualcomm Dragonboard 410c and the LeMaker HiKey boards. Features 96Boards Sensors Adapter features: • Integrated ATMEGA328p microcontroller (Arduino compatible) • 18 Grove connectors • • • • • • • • • • http://www.seeedstudio.com/wiki/Grove_System 5x baseboard GPIO ports 5x I2C ports (1 for baseboard, 2 for microcontroller) 5 digital ports (for microcontroller) 3x analog ports (for microcontroller) 2x SPI connectors (1 to baseboard, 1 to microcontroller) Arduino UNO compatible shield connectors LED: Power, Reset, 2x baseboard GPIO, 1x microcontroller IO UART interface between baseboard and microcontroller USB-UART connector for baseboard console and control Part List • 1 x 96Boards Sensors Board (part # 96B-05GROVE-C) • 1x Grove - LCD RGB Backlight (http://www.seeedstudio.com/depot/Grove-LCD-RGBBacklight-p-1643.html?cPath=34_36) • 1x Grove - Smart Relay (http://www.seeedstudio.com/depot/grove-relay-p-769.html? cPath=156_160) • 1x Grove - Buzzer (http://www.seeedstudio.com/depot/grove-buzzer-p-768.html? cPath=156_159) • 1x Grove - Sound Sensor (http://www.seeedstudio.com/depot/grove-sound-sensor-p752.html?cPath=144_148) • 1x Grove - Touch Sensor (http://www.seeedstudio.com/depot/grove-touch-sensor-p747.html?cPath=156_160) Page 3 of 3 • 1x Grove - Rotary Angle Sensor (http://www.seeedstudio.com/depot/grove-rotary-anglesensor-p-p-1242.html?cPath=156_160) • 1x Grove - Temperature Sensor (http://www.seeedstudio.com/depot/grove-temperaturesensor-p-774.html?cPath=144_147) • 1x Grove - LED (http://www.seeedstudio.com/depot/Grove-LED-p-767.html?cPath=81_35) • 1x Grove - Light Sensor (http://www.seeedstudio.com/depot/Grove-Light-Sensor-p746.html?cPath=25_27) • 1x Grove – Button (http://www.seeedstudio.com/depot/grove-button-p-766.html? cPath=156_160) • 1x DIP LED Blue-Blue • 1x DIP LED Green-Green • 1x DIP LED Red-Red • 1x Mini Servo • 10 x Grove Cables • 4 x M2.5 8mm nylon spacer • 4 x M2.5 nylon screw • 1x Green Plastic Box For any technical support or suggestion, please kindly go to our forum (https://www.96boards.org/forums/). http://www.seeedstudio.com/depot/Grove-Starter-Kit-for-96Boards-p-2618.html 3/29/2016
110060157 价格&库存
很抱歉,暂时无法提供与“110060157”相匹配的价格&库存,您可以联系我们找货
  • 10000+608.2915310000+78.52534
