110060004
110060004
    SEEED(矽递科技)
    ARDX THE STARTER KIT FOR ARDUINO
110060004 数据手册
ABOUT THIS KIT The overall goal of this kit is fun. Beyond this, the aim is to get you comfortable using a wide range of electronic components through small, simple and easy circuits. The focus is to get each circuit working then giving you the tools to figure out why. If you encounter any problems, want to ask a question, or would like to know more about any part, extra help is only an e-mail away help@oomlout.com. ABOUT OPEN SOURCE HARDWARE All of the projects at SparkFun and .:oomlout:. are open source. What does this mean? It means everything involved in making this kit, be it this guide, 3D models, or code is available for free download. But it goes further, you're also free to reproduce and modify any of this material, then distribute it for yourself. The catch? Quite simple, it is released under a Creative Commons (By Share Alike) license. This means you must credit .:oomlout:. in your design and share your developments in a similar manner. Why? We grew up learning and playing with open source software and the experience was good fun, we think it would be lovely if a similar experience was possible with physical things. More details on the Creative Commons CC (By - Share Alike) License can be found at http://ardx.org/CCLI ABOUT .: OOMLOUT :. We’re a plucky little design company focusing on producing “delightfully fun open source products” To check out what we are up to http://www.oomlout.com ABOUT SEEED STUDIO Seeed Studio is an open hardware facilitator based in China, who help designers turn their ideas into products. http://www.seeedstudio.com/ ABOUT PROBLEMS We strive to deliver the highest level of quality in each and every thing we produce. If you ever find an ambiguous instruction, a missing piece, or would just like to ask a question, we’ll try our best to help out. help@oomlout.com (we like hearing about problems it helps us improve future versions) Thanks For Choosing .:oomlout:. and Seeed Studio .: WHERE TO FIND EVERYTHING :. TBCN table of contents Before We Start {ASEM} Assembling the Pieces 02 {INST} Installing the Software 03 {PROG} A Small Programming Primer 04 {ELEC} A Small Electronics Primer 06 The Circuits {CIRC01} Getting Started - (Blinking LED) 08 {CIRC02} 8 LED Fun - (Multiple LEDs) 10 {CIRC03} Spin Motor Spin - (Transistor and Motor) 12 {CIRC04} A Single Servo - (Servos) 14 {CIRC05} 8 More LEDs - (74HC595 Shift Register) 16 {CIRC06} Music - (Piezo Elements) 18 {CIRC07} Button Pressing - (Pushbuttons) 20 {CIRC08} Twisting - (Potentiometers) 22 {CIRC09} Light - (Photo Resistors) 24 {CIRC10} Temperature - (TMP36 Temperature Sensor) 26 {CIRC11} Larger Loads - (Relays) 28 {CIRC12} Colorful Lights - (RGB LEDs) 30 {CIRC13} Vibration - (Piezo Vibration Sensor) 32 01 01 ASEM assembling the pieces .: PUTTING IT TOGETHER :. Arduino Holder x1 Breadboard x1 3mm Plastic Rivet x4 02 .: For an introduction to what an Arduino is, visit :. .: http://ardx.org/INTR :. Arduino x1 .: INSTALLING THE IDE :. 02 INST installing This is the program used to write code for the Arduino. It may seem a little daunting at first but once you have it installed and start playing around, its secrets will reveal themselves. (software and hardware) Step 1: Download the software Go to http://arduino.cc/en/Main/Software download the software for your operating system Windows® XP Mac OS X® Step 2: Unzip the Software Step 2: Open The .dmg Unzip -windows.zip (r - version #) arduino-1.r Recommended Path c:\Program Files\ Open (mount) arduino-1.r -macosx.zip (r - version #) Step 3: Shortcut Icon Open c:\program files\arduino-1.r \ (r - version #) Right Click Arduino.exe (send to>Desktop (create shortcut)) Step 4: Plug In Your Arduino Step 3: Copy The Application Go to "Arduino" (in the devices section of finder) Move "Arduino" Application to the "Applications" folder Plug your Arduino in: Using the included USB cable, plug your Arduino board into a free USB port. Wait for a box to pop up Step 5: Add new Hardware Skip searching the internet (click the next box when prompted to do so) Install from a specific location Step 4: Plug In Your Arduino Plug your Arduino in: Using the included USB cable, plug your Arduino board into a free USB port. Finished (click “Install from a list or specific location (Advanced)") Choose the Location c:\program files\arduino-00r r \drivers\ Finished Windows Vista® Windows 7 Step 5: Add new Hardware Run Device Manager Start > Run > devmgmt.msc Choose the Arduino Other Devices > Arduino Uno (Uno) Update Driver click “Update Driver” Select Driver click “Browse My Computer for Driver Software” c:\program files\arduino-1.r \drivers\ Finished .: NOTE: :. .: Encountering problems? :. .: Would like more details? Using Linux? :. .: http://ardx.org/LINU :. 03 03 PROG programming primer .:A Small Programming Primer:. ARDUINO PROGRAMMING IN BRIEF The Arduino is programmed in the C language. This is a quick little primer targeted at people who have a little bit of programing experience and just need a briefing on the idiosyncracies of C and the Arduino IDE. If you find the concepts a bit daunting, don't worry, you can start going through the circuits and pick up most of it along the way. For a more in-depth intro, the Arduino.cc website is a great resource. STRUCTURE Each Arduino program (often called a sketch) has two required functions (also called routines). void setup(){ } All the code between the two curly brackets will be run once when your Arduino program first runs. void loop(){ } This function is run after setup has finished. After it has run once it will be run again, and again, until power is removed. SYNTAX One of the slightly frustrating elements of C is its formatting requirements (this also makes it very powerful). If you remember the following you should be alright. // (single line comment) It is often useful to write notes to yourself as you go along about what each line of code does. To do this type two forward slashes and everything until the end of the line will be ignored by your program. /* */(multi line comment) If you have a lot to say you can span several lines as a comment. Everything between these two symbols will be ignored in your program. { } (curly brackets) Used to define when a block of code starts and ends (used in functions as well as loops). ; (semicolon) Each line of code must be ended with a semicolon (a missing semicolon is often the reason for a program refusing to compile). int (integer) The main workhorse, stores a number in 2 bytes (16 bits). Has no decimal places and will store a value between -32,768 and 32,767. long (long) Used when an integer is not large enough. Takes 4 bytes (32 bits) of RAM and has a range between -2,147,483,648 and 2,147,483,647. float (float) Used for floating point math (decimals). Takes 4 bytes (32 bits) of RAM and has a range between -3.4028235E+38 and 3.4028235E+38. char (character) Stores one character using the ASCII code (ie 'A' = 65). Uses one byte (8 bits) of RAM. The Arduino handles strings as an array of chars. VARIABLES A program is nothing more than instructions to move numbers around in an intelligent way. Variables are used to do the moving. boolean (boolean) A simple True or False variable. Useful because it only uses one bit of RAM. 04 .:For a full programming reference visit:. http://ardx.org/PROG 03 PROG programming primer MATHS OPERATORS Operators used for manipulating numbers. (they work like simple maths). = (assignment) makes something equal to something else (eg. x = 10 * 2 (x now equals 20)) % (modulo) gives the remainder when one number is divided by another (ex. 12 % 10 (gives 2)) + (addition) (subtraction) * (multiplication) / (division) COMPARISON OPERATORS Operators used for logical comparison. == != < > (equal to) (eg. 12 == 10 is FALSE or 12 == 12 is TRUE) (not equal to) (eg. 12 != 10 is TRUE or 12 != 12 is FALSE) (less than) (eg. 12 < 10 is FALSE or 12 < 12 is FALSE or 12 < 14 is TRUE) (greater than) (eg. 12 > 10 is TRUE or 12 > 12 is FALSE or 12 > 14 is FALSE) CONTROL STRUCTURE Programs are reliant on controlling what runs next, here are the basic control elements (there are many more online). if(condition){ } else if( condition ){ } else { } This will execute the code between the curly brackets if the condition is true, and if not it will test the else if condition if that is also false the else code will execute. for(int i = 0; i < #repeats; i++){ } Used when you would like to repeat a chunk of code a number of times (can count up i++ or down i-- or use any variable) DIGITAL pinMode(pin, mode); digitalWrite(pin, value); int digitalRead(pin); Used to set a pin's mode, pin is the pin number you would like to address 0-19 (analog 05 are 14-19). The mode can either be INPUT or OUTPUT. Once a pin is set as an OUTPUT, it can be set either HIGH (pulled to +5 volts) or LOW (pulled to ground). Once a pin is set as an INPUT you can use this to return whether it is HIGH (pulled to +5 volts) or LOW (pulled to ground). int analogWrite(pin, value); int analogRead(pin); ANALOG The Arduino is a digital machine but it has the ability to operate in the analog realm (through tricks). Here's how to deal with things that aren't digital. Some of the Arduino's pins support pulse width modulation (3, 5, 6, 9, 10, 11). This turns the pin on and off very quickly making it act like an analog output. The value is any number between 0 (0% duty cycle ~0v) and 255 (100% duty cycle ~5 volts). When the analog input pins are set to input you can read their voltage. A value between 0 (for 0 volts) and 1024 (for 5 volts) will be returned. 05 04 ELEC electronics primer .:A Small Electronics Primer:. ELECTRONICS IN BRIEF No previous electronic experience is required to have fun with this kit. Here are a few details about each component to make identifying, and perhaps understanding them, a bit easier. If at any point you are worried about how a component is used or why it's not working the internet offers a treasure trove of advice, or we can be contacted at help@oomlout.com COMPONENT DETAILS LED (Light Emitting Diode) Diode Resistors Transistor What it Does: Emits light when a small current is passed through it. (only in one direction) Identifying: Looks like a mini light bulb. No. of Leads: 2 (one longer, this one connects to positive) Things to watch out for: - Will only work in one direction - Requires a current limiting resistor More Details: http://ardx.org/LED What it Does: The electronic equivalent of a one way valve. Allowing current to flow in one direction but not the other. Identifying: Usually a cylinder with wires extending from either end. (and an off center line indicating polarity) No. of Leads: 2 Things to watch out for: - Will only work in one direction What it Does: Restricts the amount of current that can flow through a circuit. Identifying: Cylinder with wires extending from either end. The value is displayed using a color coding system (for details see next page) No. of Leads: 2 Things to watch out for: - Easy to grab the wrong value What it Does: Uses a small current to switch or amplify a much larger current. Identifying: Comes in many different packages but you can read the part number off the package. No. of Leads: 3 (Base, Collector, Emitter) Things to watch out for: - Plugging in the right way round (also a (P2N2222AG in this kit and find a datasheet online) Hobby Servo DC Motor 06 What it Does: Takes a timed pulse and converts it into an angular position of the output shaft. Identifying: A plastic box with 3 wires coming out one side and a shaft with a plastic horn out the top. What it Does: Spins when a current is passed through it. Identifying: This one is easy, it looks like a motor. Usually a cylinder with a shaft coming out of one end. (current will flow if end with the line is connected to ground) More Details: http://ardx.org/DIOD (double check the colors before using) More Details: http://ardx.org/RESI current limiting resistor is often needed on the base pin) More Details: http://ardx.org/TRAN No. of Leads: 3 Things to watch out for: - The plug is not polarized so make sure it is plugged in the right way. More Details: http://ardx.org/SERV No. of Leads: 2 Things to watch out for: - Using a transistor or relay that is rated for the size of motor you're using. More Details: http://ardx.org/MOTO 04 ELEC electronics primer COMPONENT DETAILS (CONT.) Piezo Element What it Does: A pulse of current will cause it to click. A stream of pulses will cause it to emit a tone. Identifying: In this kit it comes in a little black barrel, but sometimes they are just a gold disc. IC (Integrated Circuit) What it Does: Packages any range of complicated electronics inside an easy to use package. Identifying: The part ID is written on the outside of the package. (this sometimes requires a lot of light or a magnifying glass to read). Pushbutton What it Does: Completes a circuit when it is pressed. Identifying: A little square with leads out the bottom and a button on the top. Potentiometer What it Does: Produces a variable resistance dependent on the angular position of the shaft. Identifying: They can be packaged in many different form factors, look for a dial to identify. Photo Resistor What it Does: Produces a variable resistance dependent on the amount of incident light. Identifying: Usually a little disk with a clear top and a curvy line underneath. RESISTOR COLOR CODE Examples: green-blue-brown - 560 ohms red-red-red - 2 200 ohms (2.2k) brown-black-orange - 10 000 ohms (10k) 0 1 2 3 4 - Black Brown Red Orange Yellow 5 6 7 8 9 - Green Blue Purple Grey White first digit second digit # of zeros tolerance 20% - none 10% - silver 5% - gold No. of Leads: 2 Things to watch out for: - Difficult to misuse. More Details: http://ardx.org/PIEZ No. of Leads: 2 - 100s (in this kit there is one with 3 (TMP36) and one with 16 (74HC595) Things to watch out for: - Proper orientation. (look for marks showing pin 1) More Details: http://ardx.org/ICIC No. of Leads: 4 Things to watch out for: - these are almost square so can be inserted 90 degrees off angle. More Details: http://ardx.org/BUTT No. of Leads: 3 Things to watch out for: - Accidentally buying logarithmic scale. More Details: http://ardx.org/POTE No. of Leads: 2 Things to watch out for: - Remember it needs to be in a voltage divider before it provides a useful input. More Details: http://ardx.org/PHOT LEAD CLIPPING Some components in this kit come with very long wire leads. To make them more compatible with a breadboard a couple of changes are required. LEDs: Clip the leads so the long lead is ~10mm (3/8”) long and the short one is ~7mm (9/32”). Resistors: Bend the leads down so they are 90 degrees to the cylinder. Then snip them so they are ~6mm (1/4”) long. Other Components: Other components may need clipping. Use your discretion when doing so. 07 CIRC-01 .:Getting Started:. .:(Blinking LED):. WHAT WE’RE DOING: LEDs (light emitting diodes) are used in all sorts of clever things which is why we have included them in this kit. We will start off with something very simple, turning one on and off, repeatedly, producing a pleasant blinking effect. To get started, grab the parts listed below, pin the layout sheet to your breadboard and then plug everything in. Once the circuit is assembled you'll need to upload the program. To do this plug the Arduino board into your USB port. Then select the proper port in Tools > Serial Port > (the comm port of your Arduino). Next upload the program by going to File > Upload to I/O Board (ctrl+U). Finally, bask in the glory and possibility that controlling lights offers. If you are having trouble uploading, a full troubleshooting guide can be found here: http://ardx.org/TRBL THE CIRCUIT: Parts: CIRC-01 Breadboard Sheet x1 560 Ohm Resistor Green-Blue-Brown x1 Schematic Arduino pin 13 longer lead + LED (light emitting diode) resistor (560ohm) (green-blue-brown) gnd (ground) (-) The Internet .:download:. breadboard layout sheet http://ardx.org/BBLS01 .:view:. assembly video http://ardx.org/VIDE01 08 2 Pin Header x4 10mm LED x1 Wire CODE CIRC-01 (no need to type everything in, just click) File > Examples > 1.Basic > Blink (example from the great arduino.cc site, check it out for other ideas) /* Blink * Turns on an LED on for one second, then off for one second, * repeatedly. * Created 1 June 2005 By David Cuartielles * http://arduino.cc/en/Tutorial/Blink * based on an orginal by H. Barragan for the Wiring i/o board */ int ledPin = 13; // LED connected to digital pin 13 // The setup() method runs once, when the sketch starts void setup() { // initialize the digital pin as an output: pinMode(ledPin, OUTPUT); } // the loop() method runs over and over again, // as long as the Arduino has power void loop() { digitalWrite(ledPin, HIGH); // set the LED on delay(1000); // wait for a second digitalWrite(ledPin, LOW); // set the LED off delay(1000); // wait for a second } NOT WORKING? (3 things to try) LED Not Lighting Up? LEDs will only work in one Program Not Uploading This happens sometimes, Still No Success? the most likely cause is a A broken circuit is no fun, send direction. Try taking it out and twisting it 180 degrees. (no need to worry, installing it confused serial port, you backwards does no permanent can change this in harm). tools>serial port> us an e-mail and we will get back to you as soon as we can. help@oomlout.com MAKING IT BETTER Changing the pin: The LED is connected to pin 13 but we can use any of Control the brightness: Along with digital (on/off) control the Arduino can control the Arduino’s pins. To change it take the wire plugged some pins in an analog (brightness) fashion. (more details on into pin 13 and move it to a pin of your choice (from 0- this in later circuits). To play around with it. 13) (you can also use analog 0-5, analog 0 is 14...) Change the LED to pin 9: (also change the wire) ledPin = 13; -> int ledPin = 9; Then in the code change the line: int ledPin = 13; -> int ledPin = newpin; Replace the code inside the { }'s of loop() with this: analogWrite(ledPin, new number); Then upload the sketch: (ctrl-u) Change the blink time: Unhappy with one second on one second off? (new number) = any number between 0 and 255. 0 = off, 255 = on, in between = different brightness In the code change the lines: digitalWrite(ledPin, HIGH); delay(time on); //(seconds * 1000) digitalWrite(ledPin, LOW); delay(time off); //(seconds * 1000) Fading: We will use another included example program. To open go to File > Examples > 3.Analog > Fading Then upload to your board and watch as the LED fades in and then out. MORE, MORE, MORE: More details, where to buy more parts, where to ask more questions: http://ardx.org/CIRC01 09 CIRC-02 .:8 LED Fun:. .:Multiple LEDs:. WHAT WE’RE DOING: We have caused one LED to blink, now it's time to up the stakes. Lets connect eight. We'll also have an opportunity to stretch the Arduino a bit by creating various lighting sequences. This circuit is also a nice setup to experiment with writing your own programs and getting a feel for how the Arduino works. Along with controlling the LEDs we start looking into a few simple programming methods to keep your programs small. for() loops - used when you want to run a piece of code several times. arrays[] - used to make managing variables easier (it's a group of variables). THE CIRCUIT: Parts: CIRC-02 Breadboard Sheet x1 560 Ohm Resistor Green-Blue-Brown x8 Schematic pin 2 pin 3 pin 4 pin 5 LED resistor gnd 560ohm pin 6 pin 7 pin 8 pin 9 LED resistor gnd 560ohm The Internet .:download:. breadboard layout sheet http://ardx.org/BBLS02 .:view:. assembly video http://ardx.org/VIDE02 10 2 Pin Header x4 5mm Green LED x8 Wire CODE CIRC-02 (no need to type everything in, just click) Download the Code from ( http://ardx.org/CODE02 ) (and then copy the text and paste it into an empty Arduino Sketch) //LED Pin Variables int ledPins[] = {2,3,4,5,6,7,8,9}; //An array to hold the //pin each LED is connected to //i.e. LED #0 is connected to pin 2 void setup() { for(int i = 0; i < 8; i++){ //this is a loop and will repeat eight times pinMode(ledPins[i],OUTPUT); //we use this to set LED pins to output } } void loop() // run over and over again { oneAfterAnotherNoLoop(); //this will turn on each LED one by //one then turn each oneoff //oneAfterAnotherLoop(); //this does the same as onAfterAnotherNoLoop //but with much less typing //oneOnAtATime(); //inAndOut(); } * will then turn them off void oneAfterAnotherNoLoop(){ int delayTime = 100; //the time (in milliseconds) to pause //between LEDs digitalWrite(ledPins[0], HIGH); //Turns on LED #0 //(connected to pin 2) delay(delayTime); //waits delayTime milliseconds ... ... digitalWrite(ledPins[7], HIGH); //Turns on LED #7 //(connected to pin 9) delay(delayTime); //waits delayTime milliseconds //Turns Each LED Off digitalWrite(ledPins[7], LOW); //Turns off LED #7 delay(delayTime); //waits delayTime milliseconds ... -----more code in the downloadable version------ /* * oneAfterAnotherNoLoop() - Will light one then * delay for delayTime then light the next LED it NOT WORKING? (3 things to try) Some LEDs Fail to Light It is easy to insert an LED Starting Afresh Operating out of sequence Its easy to accidentally With eight wires it's easy to cross backwards. Check the LEDs a couple. Double check that the that aren't working and ensure first LED is plugged into pin 2 and they the right way around. each pin there after. misplace a wire without noticing. Pulling everything out and starting with a fresh slate is often easier than trying to track down the problem. MAKING IT BETTER Switching to loops: In the loop() function there are 4 lines. The last three all start with a '//'. This means the line is treated as a comment (not run). To switch the program to use loops change the void loop() code to: //oneAfterAnotherNoLoop(); oneAfterAnotherLoop(); //oneOnAtATime(); //inAndOut(); Upload the program, and notice that nothing has changed. You can take a look at the two functions, each does the same thing, but use different approaches (hint: the second one uses a for loop). Extra animations: Tired of this animation? Then try the other two sample animations. Uncomment their lines and upload the program to your board and enjoy the new light animations. (delete the slashes in front of row 3 and then 4) Testing out your own animations: Jump into the included code and start changing things. The main point is to turn an LED on use digitalWrite(pinNumber, HIGH); then to turn it off use digitalWrite(pinNumber, LOW); . Type away, regardless of what you change you won't break anything. MORE, MORE, MORE: More details, where to buy more parts, where to ask more questions: http://ardx.org/CIRC02 11 CIRC-03 .:Spin Motor Spin:. .:Transistor & Motor:. WHAT WE’RE DOING: The Arduino's pins are great for directly controlling small electric items like LEDs. However, when dealing with larger items (like a toy motor or washing machine), an external transistor is required. A transistor is incredibly useful. It switches a lot of current using a much smaller current. A transistor has 3 pins. For a negative type (NPN) transistor, you connect your load to collector and the emitter to ground. Then when a small current flows from base to the emitter, a current will flow through the transistor and your motor will spin (this happens when we set our Arduino pin HIGH). There are literally thousands of different types of transistors, allowing every situation to be perfectly matched. We have chosen a P2N2222AG a rather common general purpose transistor. The important factors in our case are that its maximum voltage (40v) and its maximum current (600 milliamp) are both high enough for our toy motor (full details can be found on its datasheet http://ardx.org/2222). (The 1N4001 diode is acting as a flyback diode for details on why its there visit: http://ardx.org/4001) THE CIRCUIT: Parts: CIRC-03 Breadboard Sheet x1 2 Pin Header x4 Transistor P2N2222AG (TO92) x1 Toy Motor x1 Diode (1N4001) x1 2.2k Ohm Resistor Red-Red-Red x1 Schematic Arduino pin 9 resistor (2.2kohm) Base Collector Diode Wire The transistor will have P2N2222AG printed on it (some variations will have different pin assignments!) Transistor P2N2222AG Emitter Motor gnd (ground) (-) +5 volts The Internet .:download:. breadboard layout sheet http://ardx.org/BBLS03 .:view:. assembly video http://ardx.org/VIDE03 12 .:NOTE: if your arduino is resetting you need to install the optional capacitor:. CODE CIRC-03 (no need to type everything in, just click) Download the Code from ( http://ardx.org/CODE03 ) (then simply copy the text and paste it into an empty Arduino Sketch) int motorPin = 9; //pin the motor is connected to void setup() //runs once { pinMode(motorPin, OUTPUT); } void loop() // run over and over again { motorOnThenOff(); //motorOnThenOffWithSpeed(); //motorAcceleration(); } /* * motorOnThenOff() - turns motor on then off * (notice this code is identical to the code we used for * the blinking LED) */ void motorOnThenOff(){ int onTime = 2500; //on time int offTime = 1000; //off time digitalWrite(motorPin, HIGH); // turns the motor On delay(onTime); // waits for onTime milliseconds digitalWrite(motorPin, LOW); // turns the motor Off delay(offTime);// waits for offTime milliseconds } NOT WORKING? void motorOnThenOffWithSpeed(){ int onSpeed = 200;// a number between //0 (stopped) and 255 int onTime = 2500; int offSpeed = 50;// a number between //0 (stopped) and 255 int offTime = 1000; analogWrite(motorPin, onSpeed); // turns the motor On delay(onTime); // waits for onTime analogWrite(motorPin, offSpeed); // turns the motor Off delay(offTime); // waits for offTime } (full speed) (full speed) milliseconds milliseconds void motorAcceleration(){ int delayTime = 50; //time between each speed step for(int i = 0; i < 256; i++){ //goes through each speed from 0 to 255 analogWrite(motorPin, i); //sets the new speed delay(delayTime);// waits for delayTime milliseconds } for(int i = 255; i >= 0; i--){ //goes through each speed from 255 to 0 analogWrite(motorPin, i); //sets the new speed delay(delayTime);//waits for delayTime milliseconds } } (3 things to try) Motor Not Spinning? If you sourced your own transistor, double check with the data sheet that the pinout is compatible with a P2N2222A (many are reversed). Still No Luck? If you sourced your own motor, double check that it will work with 5 volts and that it does not draw too much Still Not Working? Sometimes the Arduino board will disconnect from the computer. Try un-plugging and then re-plugging it into your power. USB port. MAKING IT BETTER Controlling speed: We played with the Arduino's ability to control the brightness of an LED earlier now we will use the same feature to control the speed of our motor. The Arduino does this using something called Pulse Width Modulation (PWM). This relies on the Arduino's ability to operate really, really fast. Rather than directly controlling the voltage coming from the pin the Arduino will switch the pin on and off very quickly. In the computer world this is going from 0 to 5 volts many times a second, but in the human world we see it as a voltage. For example if the Arduino is PWM'ing at 50% we see the light dimmed 50% because our eyes are not quick enough to see it flashing on and off. The same feature works with transistors. Don't believe me? Try it out. In the loop() section change it to this // motorOnThenOff(); motorOnThenOffWithSpeed(); // motorAcceleration(); Then upload the programme. You can change the speeds by changing the variables onSpeed and offSpeed. Accelerating and decelerating: Why stop at two speeds, why not accelerate and decelerate the motor. To do this simply change the loop() code to read // motorOnThenOff(); // motorOnThenOffWithSpeed(); motorAcceleration(); Then upload the program and watch as your motor slowly accelerates up to full speed then slows down again. If you would like to change the speed of acceleration change the variable delayTime (larger means a longer acceleration time). MORE, MORE, MORE: More details, where to buy more parts, where to ask more questions: http://ardx.org/CIRC03 13 CIRC-04 .:A Single Servo:. .:Servos:. WHAT WE’RE DOING: Spinning a motor is good fun but when it comes to projects where motion control is required they tend to leave us wanting more. The answer? Hobby servos. They are mass produced, widely available and cost anything from a couple of dollars to hundreds. Inside is a small gearbox (to make the movement more powerful) and some electronics (to make it easier to control). A standard servo is positionable from 0 to 180 degrees. Positioning is controlled through a timed pulse, between 1.25 milliseconds (0 degrees) and 1.75 milliseconds (180 degrees) (1.5 milliseconds for 90 degrees). Timing varies between manufacturer. If the pulse is sent every 25-50 milliseconds the servo will run smoothly. One of the great features of the Arduino is it has a software library that allows you to control two servos (connected to pin 9 or 10) using a single line of code. THE CIRCUIT: Parts: CIRC-04 Breadboard Sheet x1 Mini Servo x1 Schematic Arduino pin 9 Mini Servo signal (orange) gnd (brown/ black) +5v (red) gnd (ground) (-) +5 volts (5V) The Internet .:download:. breadboard layout sheet http://ardx.org/BBLS04 .:view:. assembly video http://ardx.org/VIDE04 14 2 Pin Header x4 3 Pin Header x1 Wire CODE CIRC-04 (no need to type everything in, just click) File > Examples > Servo > Sweep (example from the great arduino.cc site, check it out for other great ideas) // Sweep // by BARRAGAN #include Servo myservo; // create servo object to control a servo int pos = 0; // variable to store the servo position void setup() { myservo.attach(9); } // attaches the servo on pin 9 to the servo object void loop() { for(pos = 0; pos < 180; pos += { myservo.write(pos); delay(15); } for(pos = 180; pos>=1; pos-=1) { myservo.write(pos); delay(15); } } NOT WORKING? 1) // goes from 0 degrees to 180 degrees // in steps of 1 degree // tell servo to go to position in variable 'pos' // waits 15ms for the servo to reach the position // goes from 180 degrees to 0 degrees // tell servo to go to position in variable 'pos' // waits 15ms for the servo to reach the position (3 things to try) Still Not Working Servo Not Twisting? Even with colored wires it is still shockingly easy to plug a servo in backwards. This might be the case. A mistake we made a time or two was simply forgetting to connect the power (red and brown wires) to +5 volts and ground. Fits and Starts If the servo begins moving then twitches, and there's a flashing light on your Arduino board, the power supply you are using is not quite up to the challenge. Using a fresh battery instead of USB should solve this problem. MAKING IT BETTER Potentiometer control: We have yet to experiment with inputs but if you would like to read ahead, there is an example program File > Servo > Knob. This uses a potentiometer (CIRC08) to control the servo. You can find instructions online here: void loop() { int pulseTime = 2100; //(the number of microseconds //to pause for (1500 90 degrees // 900 0 degrees 2100 180 degrees) digitalWrite(servoPin, HIGH); delayMicroseconds(pulseTime); digitalWrite(servoPin, LOW); delay(25); http://ardx.org/KNOB } Self timing: While it is easy to control a servo using the Arduino's included Great ideas: Servos can be used to do all sorts of great things, here are a few of library sometimes it is fun to figure out how to program our favorites. something yourself. Try it. We're controlling the pulse directly so you could use this method to control servos on any of the Arduino's 20 available pins (you need to highly optimize this code before doing that). Xmas Hit Counter http://ardx.org/XMAS Open Source Robotic Arm (uses a servo controller as well as the Arduino) http://ardx.org/RARM int servoPin = 9; Servo Walker http://ardx.org/SEWA void setup(){ pinMode(servoPin,OUTPUT); } MORE, MORE, MORE: More details, where to buy more parts, where to ask more questions: http://ardx.org/CIRC04 15 .:8 More LEDs:. CIRC-05 .:74HC595 Shift Register:. WHAT WE’RE DOING: Time to start playing with chips, or integrated circuits (ICs) as they like to be called. The external packaging of a chip can be very deceptive. For example, the chip on the Arduino board (a microcontroller) and the one we will use in this circuit (a shift register) look very similar but are in fact rather different. The price of the ATMega chip on the Arduino board is a few dollars while the 74HC595 is a couple dozen cents. It's a good introductory chip, and once you're comfortable playing around with it and its datasheet (available online http://ardx.org/74HC595 ) the world of chips will be your oyster. The shift register (also called a serial to parallel converter), will give you an additional 8 outputs (to control LEDs and the like) using only three Arduino pins. They can also be linked together to give you a nearly unlimited number of outputs using the same four pins. To use it you “clock in” the data and then lock it in (latch it). To do this you set the data pin to either HIGH or LOW, pulse the clock, then set the data pin again and pulse the clock repeating until you have shifted out 8 bits of data. Then you pulse the latch and the 8 bits are transferred to the shift registers pins. It sounds complicated but is really simple once you get the hang of it. (for a more in depth look at how a shift register works visit: http://ardx.org/SHIF) THE CIRCUIT: Parts: CIRC-05 Breadboard Sheet x1 2 Pin Header x4 Red LED x8 560 Ohm Resistor Green-Blue-Brown x8 Shift Register 74HC595 x1 Wire The Internet .:download:. breadboard layout sheet http://ardx.org/BBLS05 .:view:. assembly video http://ardx.org/VIDE05 16 (ground) (-) +5V 0 1 2 data 3 clock 4 latch 5 6 gnd 7 gnd 74HC595 LED resistor pin pin pin +5 volts 4 3 2 (560ohm) Schematic There is a half moon cutout, this goes at the top CODE CIRC-05 (no need to type everything in, just click) Download the Code from ( http://ardx.org/CODE05 ) (copy the text and paste it into an empty Arduino Sketch) //Pin Definitions //The 74HC595 uses a serial communication //link which has three pins int data = 2; int clock = 3; int latch = 4; void setup() //runs once { pinMode(data, OUTPUT); pinMode(clock, OUTPUT); pinMode(latch, OUTPUT); digitalWrite(latch, LOW); //Pulls the chips latch low shiftOut(data, clock, MSBFIRST, value); //Shifts out 8 bits to the shift register digitalWrite(latch, HIGH); //Pulls the latch high displaying the data } } void loop() // run over and over again { int delayTime = 100; //delay between LED updates for(int i = 0; i < 256; i++){ updateLEDs(i); delay(delayTime); } } ---------- More Code Online ---------- /* * updateLEDs() - sends the LED states set * in value to the 74HC595 sequence */ void updateLEDs(int value){ NOT WORKING? (3 things to try) The Arduino’s power LED goes out This happened to us a couple of times, it happens when the chip is inserted backwards. If you fix it quickly nothing will break. Not Quite Working Sorry to sound like a broken record but it is probably something as simple as a crossed wire. Frustration? Shoot us an e-mail, this circuit is both simple and complex at the same time. We want to hear about problems you have so we can address them in future editions. help@oomlout.com MAKING IT BETTER Doing it the hard way: An Arduino makes rather complex actions very easy, shifting out data is one of these cases. However one of the nice features of an Arduino is you can make things as easy or difficult as you like. Let's try an example of this. In your loop switch the line: updateLEDs(i) -> updateLEDsLong(i); Upload the program and notice nothing has changed. If you look at the code you can see how we are communicating with the chip one bit at a time. (for more details http://ardx.org/SPI ). Controlling individual LEDs: Time to start controlling the LEDs in a similar method as we did in CIRC02. As the eight LED states are stored in one byte (an 8 bit value) for details on how this works try http://ardx.org/BINA. An Arduino is very good at manipulating bits and there are an entire set of operators that help us out. Details on bitwise maths ( http://ardx.org/BITW ). Our implementation. Replace the loop() code with int delayTime = 100; //the number of milliseconds //to delay //between LED updates for(int i = 0; i < 8; i++){ changeLED(i,ON); delay(delayTime); } for(int i = 0; i < 8; i++){ changeLED(i,OFF); delay(delayTime); } Uploading this will cause the lights to light up one after another and then off in a similar manner. Check the code and wikipedia to see how it works, or shoot us an e-mail if you have questions. More animations: Now things get more interesting. If you look back to the code from CIRC02 (8 LED Fun) you see we change the LEDs using digitalWrite(led, state), this is the same format as the routine we wrote changeLED(led, state). You can use the animations you wrote for CIRC02 by copying the code into this sketch and changing all the digitalWrite()'s to changeLED()'s. Powerful? Very. (you'll also need to change a few other things but follow the compile errors and it works itself out). MORE, MORE, MORE: More details, where to buy more parts, where to ask more questions: http://ardx.org/CIRC05 17 CIRC-06 .:Music:. .:Piezo Elements:. WHAT WE’RE DOING: To this point we have controlled light, motion, and electrons. Let's tackle sound next. But sound is an analog phenomena, how will our digital Arduino cope? We will once again rely on its incredible speed which will let it mimic analog behavior. To do this, we will attach a piezo element to one of the Arduino's digital pins. A piezo element makes a clicking sound each time it is pulsed with current. If we pulse it at the right frequency (for example 440 times a second to make the note middle A) these clicks will run together to produce notes. Let's get to experimenting with it and get your Arduino playing "Twinkle Twinkle Little Star". THE CIRCUIT: Parts: CIRC-06 Breadboard Sheet x1 Schematic Arduino pin 9 Piezo Element gnd (ground) (-) The Internet .:download:. breadboard layout sheet http://ardx.org/BBLS06 .:view:. assembly video http://ardx.org/VIDE06 18 2 Pin Header x4 Piezo Element x1 Wire CODE CIRC-06 (no need to type everything in, just click) Download the Code from ( http://ardx.org/CODE06 ) (copy the text and paste it into an empty Arduino Sketch) /* Melody * (cleft) 2005 D. Cuartielles for K3 * * This example uses a piezo speaker to play melodies. It sends * a square wave of the appropriate frequency to the piezo, * generating the corresponding tone. * * The calculation of the tones is made following the * mathematical operation: * * timeHigh = period / 2 = 1 / (2 * toneFrequency) * * where the different tones are described as in the table: * * note frequency period timeHigh * c 261 Hz 3830 1915 * d 294 Hz 3400 1700 * e 329 Hz 3038 1519 * f 349 Hz 2864 1432 * g 392 Hz 2550 1275 * a 440 Hz 2272 1136 * b 493 Hz 2028 1014 * C 523 Hz 1912 956 * * http://www.arduino.cc/en/Tutorial/Melody */ int speakerPin = 9; int length = 15; // the number of notes char notes[] = "ccggaagffeeddc "; // a space represents a rest int beats[] = { 1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 4 }; int tempo = 300; void playTone(int tone, int duration) { for (long i = 0; i < duration * 1000L; i += tone * 2) { digitalWrite(speakerPin, HIGH); delayMicroseconds(tone); NOT WORKING? digitalWrite(speakerPin, LOW); delayMicroseconds(tone); } } void playNote(char note, int duration) { char names[] = { 'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C' }; int tones[] = { 1915, 1700, 1519, 1432, 1275, 1136, 1014, 956 }; // play the tone corresponding to the note name for (int i = 0; i < 8; i++) { if (names[i] == note) { playTone(tones[i], duration); } } } void setup() { pinMode(speakerPin, OUTPUT); } void loop() { for (int i = 0; i < length; i++) { if (notes[i] == ' ') { delay(beats[i] * tempo); // rest } else { playNote(notes[i], beats[i] * tempo); } // pause between notes delay(tempo / 2); } } (3 things to try) No Sound Given the size and shape of the piezo element it is easy to miss the right holes on the breadboard. Try double Can't Think While the Melody is Playing? Just pull up the piezo element whilst you think, upload your program then plug it back in. checking its placement. Tired of Twinkle Twinkle Little Star? The code is written so you can easily add your own songs, check out the code below to get started. MAKING IT BETTER Playing with the speed: The timing for each note is calculated based on variables, as such we can tweak the sound of each note or the timing. To change the speed of the melody you need to change only one line. int tempo = 300; ---> int tempo = (new #) Change it to a larger number to slow the melody down, or a smaller number to speed it up. Tuning the notes: If you are worried about the notes being a little out of tune this can be fixed as well. The notes have been calculated based on a formula in the comment block at the top of the program. But to tune individual notes just adjust their values in the tones[] array up or down until they sound right. (each note is matched by its name in the names[] (array ie. c = 1915 ) char names[] = { 'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C' }; int tones[] = { 1915, 1700, 1519, 1432, 1275, 1136, 1014, 956 }; Composing your own melodies: The program is pre-set to play 'Twinkle Twinkle Little Star' however the way it is programmed makes changing the song easy. Each song is defined in one int and two arrays, the int length defines the number of notes, the first array notes[] defines each note, and the second beats[] defines how long each note is played. Some Examples: Twinkle Twinkle Little Star int length = 15; char notes[] = {"ccggaagffeeddc "}; int beats[] = { 1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 4 }; Happy Birthday (first line) int length = 13; char notes[] = {"ccdcfeccdcgf "}; int beats[] = {1,1,1,1,1,2,1,1,1,1,1,2,4}; MORE, MORE, MORE: More details, where to buy more parts, where to ask more questions: http://ardx.org/CIRC06 19 .:Button Pressing:. CIRC-07 .:Pushbuttons:. WHAT WE’RE DOING: Up to this point we have focused entirely on outputs, time to get our Arduino to listen, watch and feel. We'll start with a simple pushbutton. Wiring up the pushbutton is simple. There is one component, the pull up resistor, that might seem out of place. This is included because an Arduino doesn't sense the same way we do (i.e. button pressed, button unpressed). Instead it looks at the voltage on the pin and decides whether it is HIGH or LOW. The button is set up to pull the Arduino's pin LOW when it is pressed, however, when the button is unpressed the voltage of the pin will float (causing occasional errors). To get the Arduino to reliably read the pin as HIGH when the button is unpressed, we add the pull up resistor. (note: the first example program uses only one of the two buttons) THE CIRCUIT: Parts: CIRC-07 Breadboard Sheet x1 10k Ohm Resistor Brown-Black-Orange x2 Schematic Arduino Arduino pin 2 pin 13 resistor LED resistor (560ohm) (10k ohm) pushbutton gnd (ground) (-) The Internet .:download:. breadboard layout sheet http://ardx.org/BBLS07 .:view:. assembly video http://ardx.org/VIDE07 20 pin 3 +5 volts 2 Pin Header x4 560 Ohm Resistor Green-Blue-Brown x1 Pushbutton x2 Wire Red LED x1 CODE CIRC-07 (no need to type everything in, just click) File > Examples > 2.Digital > Button (example from the great arduino.cc site, check it out for other great ideas) /* * Button * by DojoDave * * Turns on and off a light emitting diode(LED) connected to digital * pin 13, when pressing a pushbutton attached to pin 7. * http://www.arduino.cc/en/Tutorial/Button */ int ledPin = 13; // choose the pin for the LED int inputPin = 2; // choose the input pin (for a pushbutton) int val = 0; // variable for reading the pin status void setup() { pinMode(ledPin, OUTPUT); pinMode(inputPin, INPUT); } void loop(){ val = digitalRead(inputPin); if (val == HIGH) { digitalWrite(ledPin, LOW); } else { digitalWrite(ledPin, HIGH); } } NOT WORKING? // declare LED as output // declare pushbutton as input // read input value // check if the input is HIGH // turn LED OFF // turn LED ON (3 things to try) Light Not Turning On Light Not Fading Underwhelmed? A bit of a silly mistake we No worries these circuits are all and because of this it is easy constantly made, when you super stripped down to make to put it in the wrong way. switch from simple on off to playing with the components Give it a 90 degree twist and fading remember to move the easy, but once you throw them see if it starts working. LED wire from pin 13 to pin 9. together the sky is the limit. The pushbutton is square MAKING IT BETTER On button off button: The initial example may be a little underwhelming (i.e. I Fading up and down: Lets use the buttons to control an analog signal. To do this don't really need an Arduino to do this), let’s make it a you will need to change the wire connecting the LED from pin little more complicated. One button will turn the LED on 13 to pin 9, also change this in code. int ledPin = 13; ----> int ledPin = 9; Next change the loop() code to read. the other will turn the LED off. Change the code to: int ledPin = 13; int inputPin1 = 3; int inputPin2 = 2; // choose the pin for the LED // button 1 // button 2 void setup() { pinMode(ledPin, OUTPUT); // declare LED as output pinMode(inputPin1, INPUT); // make button 1 an input pinMode(inputPin2, INPUT); // make button 2 an input } void loop(){ if (digitalRead(inputPin1) == LOW) { digitalWrite(ledPin, LOW); // turn LED OFF } else if (digitalRead(inputPin2) == LOW) { digitalWrite(ledPin, HIGH); // turn LED ON } } Upload the program to your board, and start toggling the LED on and off. int value = 0; void loop(){ if (digitalRead(inputPin1) == LOW) { value--; } else if (digitalRead(inputPin2) == LOW) { value++; } value = constrain(value, 0, 255); analogWrite(ledPin, value); delay(10); } Changing fade speed: If you would like the LED to fade faster or slower, there is only one line of code that needs changing; delay(10); ----> delay(new #); To fade faster make the number smaller, slower requires a larger number. MORE, MORE, MORE: More details, where to buy more parts, where to ask more questions: http://ardx.org/CIRC07 21 .:Twisting:. CIRC-08 .:Potentiometers:. WHAT WE’RE DOING: Along with the digital pins, the Arduino also has 6 pins which can be used for analog input. These inputs take a voltage (from 0 to 5 volts) and convert it to a digital number between 0 (0 volts) and 1023 (5 volts) (10 bits of resolution). A very useful device that exploits these inputs is a potentiometer (also called a variable resistor). When it is connected with 5 volts across its outer pins the middle pin will read some value between 0 and 5 volts dependent on the angle to which it is turned (ie. 2.5 volts in the middle). We can then use the returned values as a variable in our program. THE CIRCUIT: Parts: CIRC-08 Breadboard Sheet x1 2 Pin Header x4 Green LED x1 560 Ohm Resistor Green-Blue-Brown x1 Schematic Arduino +5 volts pin 13 LED Arduino Potentiometer (light emitting diode) resistor (560ohm) (green-blue-brown) gnd (ground) (-) The Internet .:download:. breadboard layout sheet http://ardx.org/BBLS08 .:view:. assembly video http://ardx.org/VIDE08 22 analog pin 0 Potentiometer 10k ohm x1 Wire CODE (no need to type everything in, just click) File > Examples > 3.Analog > AnalogInput CIRC-08 (example from the great arduino.cc site, check it out for other great ideas) /* Analog Input * Demonstrates analog input by reading an analog sensor on analog * pin 0 and turning on and off a light emitting diode(LED) connected to digital pin 13. * The amount of time the LED will be on and off depends on the value obtained by * analogRead(). * Created by David Cuartielles * Modified 16 Jun 2009 * By Tom Igoe * http://arduino.cc/en/Tutorial/AnalogInput */ int sensorPin = 0; int ledPin = 13; int sensorValue = 0; // select the input pin for the potentiometer // select the pin for the LED // variable to store the value coming from the sensor void setup() { pinMode(ledPin, OUTPUT); } //declare the ledPin as an OUTPUT: void loop() { sensorValue = analogRead(sensorPin);// digitalWrite(ledPin, HIGH); // delay(sensorValue); // digitalWrite(ledPin, LOW); // delay(sensorValue); // } NOT WORKING? read turn stop turn stop the the the the the value from the sensor: ledPin on program for milliseconds: ledPin off: program for for milliseconds: (3 things to try) Not Working Sporadically Working This is most likely due to a Make sure you haven't slightly dodgy connection with accidentally connected the the potentiometer's pins. This potentiometer's wiper to digital can usually be conquered by pin 0 rather than analog pin 0. taping the potentiometer down. (the row of pins beneath the Still Backward You can try operating the circuit upside down. Sometimes this helps. power pins) MAKING IT BETTER Threshold switching: Sometimes you will want to switch an output when a value exceeds a certain threshold. To do this with a potentiometer change the loop() code to. void loop() { int threshold = 512; if(analogRead(sensorPin) > threshold){ digitalWrite(ledPin, HIGH);} else{ digitalWrite(ledPin, LOW);} } This will cause the LED to turn on when the value is above 512 (about halfway), you can adjust the sensitivity by changing the threshold value. Fading: Let’s control the brightness of an LED directly from the potentiometer. To do this we need to first change the pin the LED is connected to. Move the wire from pin 13 to pin 9 and change one line in the code. Then change the loop code to. void loop() { int value = analogRead(potPin) / 4; analogWrite(ledPin, value); } Upload the code and watch as your LED fades in relation to your potentiometer spinning. (Note: the reason we divide the value by 4 is the analogRead() function returns a value from 0 to 1023 (10 bits), and analogWrite() takes a value from 0 to 255 (8 bits) ) Controlling a servo: This is a really neat example and brings a couple of circuits together. Wire up the servo like you did in CIRC-04, then open the example program Knob (File > Examples > Servo > Knob ), then change one line of code. int potpin = 0; ----> int potpin = 2; Upload to your Arduino and then watch as the servo shaft turns as you turn the potentiometer. int ledPin = 13; ----> int ledPin = 9; MORE, MORE, MORE: More details, where to buy more parts, where to ask more questions: http://ardx.org/CIRC08 23 CIRC-09 .:Light:. .:Photo Resistors:. WHAT WE’RE DOING: Whilst getting input from a potentiometer can be useful for human controlled experiments, what do we use when we want an environmentally controlled experiment? We use exactly the same principles but instead of a potentiometer (twist based resistance) we use a photo resistor (light based resistance). The Arduino cannot directly sense resistance (it senses voltage) so we set up a voltage divider (http://ardx.org/VODI). The exact voltage at the sensing pin is calculable, but for our purposes (just sensing relative light) we can experiment with the values and see what works for us. A low value will occur when the sensor is well lit while a high value will occur when it is in darkness. THE CIRCUIT: Parts: CIRC-09 Breadboard Sheet x1 10k Ohm Resistor Brown-Black-Orange x1 Schematic Arduino pin 13 +5 volts resistor LED (10k ohm) Arduino analog pin 0 resistor (560ohm) photo resistor gnd (ground) (-) The Internet .:download:. breadboard layout sheet http://ardx.org/BBLS09 .:view:. assembly video http://ardx.org/VIDE09 24 2 Pin Header x4 560 Ohm Resistor Green-Blue-Brown x1 Photo-Resistor x1 Green LED x1 Wire CODE CIRC-09 (no need to type everything in, just click) Download the Code from ( http://ardx.org/CODE09 ) (copy the text and paste it into an empty Arduino Sketch) /* * A simple programme that will change the * intensity of an LED based on the amount of * light incident on the photo resistor. * */ //PhotoResistor Pin int lightPin = 0; //the analog pin the //photoresistor is //connected to //the photoresistor is not //calibrated to any units so //this is simply a raw sensor //value (relative light) //LED Pin int ledPin = 9;//the pin the LED is connected to //we are controlling brightness so //we use one of the PWM (pulse //width modulation pins) //output } /* * loop() - this function will start after setup * finishes and then repeat */ void loop() { int lightLevel = analogRead(lightPin); //Read the // lightlevel lightLevel = map(lightLevel, 0, 900, 0, 255); //adjust the value 0 to 900 to 0 to 255 lightLevel = constrain(lightLevel, 0, 255); //make sure the value is between 0 and 255 analogWrite(ledPin, lightLevel); //write the value } void setup() { pinMode(ledPin, OUTPUT); //sets the led pin to NOT WORKING? (3 things to try) It Isn't Responding to Still not quite working? This is a mistake we continue Changes in Light. You may be in a room which is to make time and time again, Given that the spacing of the LED Remains Dark if only they could make an LED that worked both ways. Pull it up and give it a twist. wires on the photo-resistor is not standard, it is easy to misplace it. Double check its in either too bright or dark. Try turning the lights on or off to see if this helps. Or if you have a flashlight near by give that a the right place. MAKING IT BETTER Reverse the response: Perhaps you would like the opposite response. Don't worry we can easily reverse this response just change: analogWrite(ledPin, lightLevel); ----> analogWrite(ledPin, 255 - lightLevel); Upload and watch the response change: Night light: Rather than controlling the brightness of the LED in response to light, let's instead turn it on or off based on a threshold value. Change the loop() code with. } void loop(){ int threshold = 300; if(analogRead(lightPin) > threshold){ digitalWrite(ledPin, HIGH); }else{ digitalWrite(ledPin, LOW); } try. Light controlled servo: Let's use our newly found light sensing skills to control a servo (and at the same time engage in a little bit of Arduino code hacking). Wire up a servo connected to pin 9 (like in CIRC-04). Then open the Knob example program (the same one we used in CIRC-08) File > Examples > Servo > Knob. Upload the code to your board and watch as it works unmodified. Using the full range of your servo: You'll notice that the servo will only operate over a limited portion of its range. This is because with the voltage dividing circuit we use the voltage on analog pin 0 will not range from 0 to 5 volts but instead between two lesser values (these values will change based on your setup). To fix this play with the val = map(val, 0, 1023, 0, 179); line. For hints on what to do, visit http://arduino.cc/en/Reference/Map . MORE, MORE, MORE: More details, where to buy more parts, where to ask more questions: http://ardx.org/CIRC09 25 CIRC-10 .:Temperature:. .:TMP36 Precision Temperature Sensor:. WHAT WE’RE DOING: What's the next phenomena we will measure with our Arduino? Temperature. To do this we'll use a rather complicated IC (integrated circuit) hidden in a package identical to our P2N2222AG transistors. It has three pins, ground, signal and +5 volts, and is easy to use. It outputs 10 millivolts per degree centigrade on the signal pin (to allow measuring temperatures below freezing there is a 500 mV offset eg. 25° C = 750 mV, 0° C = 500mV). To convert this from the digital value to degrees, we will use some of the Arduino's maths abilities. Then to display it we'll use one of the IDE's rather powerful features, the debug window. We'll output the value over a serial connection to display on the screen. Let's get to it. One extra note, this circuit uses the Arduino IDE's serial monitor. To open this, first upload the program then click the button which looks like a magnifying glass or press (ctrl + shift + m) The TMP36 Datasheet: http://ardx.org/TMP36 THE CIRCUIT: Parts: CIRC-10 Breadboard Sheet x1 TMP36 Temperature Sensor x1 2 Pin Header x4 Wire Schematic Arduino analog pin 0 +5 volts +5v signal gnd TMP36 (precision temperature sensor) gnd (ground) (-) The Internet .:download:. breadboard layout sheet http://ardx.org/BBLS10 .:view:. assembly video http://ardx.org/VIDE10 26 the chip will have TMP36 printed on it CODE CIRC-10 (no need to type everything in, just click) Download the Code from ( http://ardx.org/CODE10 ) (copy the text and paste it into an empty Arduino Sketch) /* * * * * * * * --------------------------------------------| Arduino Experimentation Kit Example Code | | CIRC-10 .: Temperature :. | --------------------------------------------A simple program to output the current temperature to the IDE's debug window For more details on this circuit: //TMP36 Pin Variables int temperaturePin = 0;//the analog pin the TMP36's //Vout pin is connected to //the resolution is //10 mV / degree centigrade //(500 mV offset) to make //negative temperatures an option void setup() { Serial.begin(9600); //Start the serial connection //with the computer //to view the result open the //serial monitor //last button beneath the file //bar (looks like a box with an //antenna) } NOT WORKING? void loop() // run over and over again { float temperature = getVoltage(temperaturePin); //getting the voltage reading from the //temperature sensor temperature = (temperature - .5) * 100;//converting from 10 mv //per degree wit 500 mV offset to //degrees ((volatge - 500mV) times 100) Serial.println(temperature); //printing the result delay(1000); //waiting a second } /* * getVoltage() - returns the voltage on the analog input * defined by pin */ float getVoltage(int pin){ return (analogRead(pin) * .004882814);//converting from a 0 //to 1024 digital range // to 0 to 5 volts //(each 1 reading equals ~ 5 millivolts } (3 things to try) Nothing Seems to Happen This program has no outward indication it is working. To see the results you must open the Arduino IDE's serial monitor. (instructions on previous page) Gibberish is Displayed This happens because the serial monitor is receiving data at a different speed than expected. Temperature Value is Unchanging Try pinching the sensor with To fix this, click the pull-down your fingers to heat it up or box that reads "*** baud" and pressing a bag of ice against it change it to "9600 baud". to cool it down. MAKING IT BETTER Outputting voltage: This is a simple matter of changing one line. Our sensor outputs 10mv per degree centigrade so to get voltage we simply display the result of getVoltage(). delete the line temperature = (temperature - .5) * 100; Outputting degrees Fahrenheit: Again this is a simple change requiring only maths. To go degrees C ----> degrees F we use the formula: ( F = C * 1.8) + 32 ) add the line temperature = (((temperature - .5) * 100)*1.8) + 32; before Serial.println(temperature); More informative output: Let's add a message to the serial output to make what is appearing in the Serial Monitor more informative. To do this first revert to the original code then change: Serial.println(temperature); ----> Serial.print(temperature); Serial.println(" degrees centigrade"); The change to the first line means when we next output it will appear on the same line, then we add the informative text and a new line. Changing the serial speed: If you ever wish to output a lot of data over the serial line time is of the essence. We are currently transmitting at 9600 baud but much faster speeds are possible. To change this change the line: Serial.begin(9600); ----> Serial.begin(115200); Upload the sketch turn on the serial monitor, then change the speed from 9600 baud to 115200 baud in the pull down menu. You are now transmitting data 12 times faster. MORE, MORE, MORE: More details, where to buy more parts, where to ask more questions: http://ardx.org/CIRC10 27 CIRC-11 .:Larger Loads:. .:Relays:. WHAT WE’RE DOING: The final circuit is a bit of a test. We combine what we learned about using transistors in CIRC03 to control a relay. A relay is an electrically controlled mechanical switch. Inside the little plastic box is an electromagnet that, when energized, causes a switch to trip (often with a very satisfying clicking sound). You can buy relays that vary in size from a quarter of the size of the one in this kit up to as big as a fridge, each capable of switching a certain amount of current. They are immensely fun because there is an element of the physical to them. While all the silicon we've played with to this point is fun sometimes you may just want to wire up a hundred switches to control something magnificent. Relays give you the ability to dream it up then control it with your Arduino. Now to using today's technology to control the past. (The 1N4001 diode is acting as a flyback diode, for details on why it's there visit: http://ardx.org/4001) THE CIRCUIT: Parts: CIRC-11 Breadboard Sheet x1 Diode (1N4001) x1 2.2k Ohm Resistor Red-Red-Red x1 560 Ohm Resistor Green-Blue-Brown x2 Transistor P2N2222AG (TO92) x1 Green LED x1 Relay (SPDT) x1 Red LED x1 2 Pin Header x4 Schematic Arduino pin 2 Diode (flyback) resistor (2.2kohm) Transistor Base P2N2222AG Collector Emitter the transistor will have P2N2222AG printed on it NC (some variations will have the pin assignment reversed) NO +5 gnd (ground) (-) The Internet .:download:. breadboard layout sheet http://ardx.org/BBLS11E .:view:. assembly video http://ardx.org/VIDE11 28 CODE CIRC-11 (no need to type everything in, just click) File > Examples > 1.Basic > Blink (example from the great arduino.cc site, check it out for other great ideas) /* * Blink * * The basic Arduino example. Turns on an LED on for one second, * then off for one second, and so on... We use pin 13 because, * depending on your Arduino board, it has either a built-in LED * or a built-in resistor so that you need only an LED. * * http://www.arduino.cc/en/Tutorial/Blink */ int ledPin = 2; // *********** CHANGE TO PIN 2 ************ void setup() { pinMode(ledPin, OUTPUT); } // run once, when the sketch starts void loop() { digitalWrite(ledPin, HIGH); delay(1000); digitalWrite(ledPin, LOW); delay(1000); } // run over and over again NOT WORKING? // sets the digital pin as output // // // // sets the LED on waits for a second sets the LED off waits for a second (3 things to try) Not Quite Working Nothing Happens The example code uses pin 13 and we have the relay connected to pin 2. Make sure you made this change in the code. No Clicking Sound The included relays are The transistor or coil portion of designed to be soldered rather the circuit isn't quite working. than used in a breadboard. As Check the transistor is plugged such you may need to press it in the right way. in to ensure it works (and it may pop out occasionally). MAKING IT BETTER Watch the Back-EMF Pulse Replace the diode with an LED. You’ll see it blink each time it “snubs” the coil voltage spike when it turns off. Controlling a Motor In CIRC-03 we controlled a motor using a transistor. However if you want to control a larger motor a relay is a good option. To do this simply remove the red LED, and connect the motor in its place (remember to bypass the 330 Ohm resistor). MORE, MORE, MORE: More details, where to buy more parts, where to ask more questions: http://ardx.org/CIRC11 29 .:Colorful Light:. CIRC-12 .:RGB LEDs:. WHAT WE’RE DOING: We've blinked an LED and controlled eight in sequence, now it's time to control color. Using an RGB LED (actual 3 LEDs in a single housing) we can generate any color our heart desires. We do this through color mixing, what’s required is delving back to your elementary art days of playing with colored cellophane to produce different colors (if you can’t remember that far back don’t worry here’s a color wheel to Color Wheels red e e blu n en gre e gre blu w llo ye ma ge nta analog red w llo ma ge nta digital cyan red ye Color Truth Table green blue yellow ON ON OFF cyan OFF ON ON magenta ON OFF ON white ON ON ON help you out). cyan THE CIRCUIT: Parts: CIRC-12 Breadboard Sheet x1 2 Pin Header x4 560 Ohm Resistor Green-Blue-Brown x3 pin 10 pin 9 green red pin 11 resistor blue green common (+5v) red Schematic Arduino (560ohm) blue longest lead +5v The Internet .:download:. breadboard layout sheet http://ardx.org/BBLS12E 30 flat side 8mm RGB LED x1 Wire CODE CIRC-12 (no need to type everything in, just click) Download the Code from (http://ardx.org/CODE12E) (copy the text and paste it into an empty Arduino Sketch) //RGB LED pins int ledDigitalOne[] = {9, 10, 11}; //the three digital pins of the digital LED //9 = redPin, 10 = greenPin, 11 = bluePin const boolean ON = LOW; //Define on as LOW (this is because we use //a common Anode RGB LED (common pin is //connected to +5 volts) const boolean OFF = HIGH; //Define off as HIGH void loop(){ setColor(ledDigitalOne, CYAN); //Set the color of the LED //randomColor() //Predefined Colors const boolean RED[] = {ON, OFF, OFF}; const boolean GREEN[] = {OFF, ON, OFF}; const boolean BLUE[] = {OFF, OFF, ON}; const boolean YELLOW[] = {ON, ON, OFF}; const boolean CYAN[] = {OFF, ON, ON}; const boolean MAGENTA[] = {ON, OFF, ON}; const boolean WHITE[] = {ON, ON, ON}; const boolean BLACK[] = {OFF, OFF, OFF}; } void randomColor(){ int rand = random(0, sizeof(COLORS) / 2); //get a random number within the range of //colors setColor(ledDigitalOne, COLORS[rand]); //Set the color of led one to a random color delay(1000); } //An Array that stores the predefined colors const boolean* COLORS[] = {RED, GREEN, BLUE,YELLOW, CYAN, MAGENTA, WHITE, BLACK}; NOT WORKING? void setup(){ for(int i = 0; i < 3; i++){ pinMode(ledDigitalOne[i], OUTPUT); //Set the three LED pins as outputs } } void setColor(int* led, boolean* color){ for(int i = 0; i < 3; i++){ digitalWrite(led[i], color[i]); } } (3 things to try) LED Remains Dark or Seeing Red Shows Incorrect Color The red diode within the RGB LED may be a bit brighter than the other two. To make your colors more balanced, try using a higher ohm resistor (or two resistors in series). With the four pins of the LED so close together, it’s sometimes easy to misplace one. Try double checking each pin is where it should be. Looking For More? (shameless plug) If you’re looking to do more why not check out all the lovely extra bits and bobs available from http://www.seeedstudio.com MAKING IT BETTER More Colors I imagine you are less than impressed by the Analog Color Control While switching between colors is good fun RGB LEDs cyan glowing LED before you. To display a really come into their own when mixed with analog different color change the color in the code to control. Using PWM (pulse width modulation) it’s one of the others. possible to produce nearly any color and fade setColor(ledDigitalOne, CYAN); ----> setColor(ledDigitalOne, **NEW COLOR**); between them. Sadly the code for this is a bit too long for the section above, for an example program (with Display a Random Color Of course we can do more than display a lots of comments). constant color, to see how we cycle through Download the code from: http://ardx.org/MABE12E random colors change the loop() code to. void loop(){ //setColor(ledDigitalOne, CYAN); randomColor() } MORE, MORE, MORE: More details, where to buy more parts, where to ask more questions: http://seeedstudio.com 31 .:Vibration:. CIRC-13 .:Piezo Vibration Sensor:. WHAT WE’RE DOING: Earlier (CIRC-06) we used a piezo element as an output. But piezo elements have dual functionality, pulsing them with electricity produces a click and manipulating them produces a voltage. Using the Arduino’s analog input we can measure the voltage generated and use it to determine whether any movement has occured. The piezo vibration sensor included in this kit, has an additional weight added this means it will flex when shaken, this lets us write programs that can respond to movement. .: or for all the technical details a datasheet can be found here:. .: http://ardx.org/VIBS :. THE CIRCUIT: Parts: CIRC-13 Breadboard Sheet x1 Green Led x1 Schematic Arduino Arduino pin 13 LED Vibration Sensor analog pin 0 (light emitting diode) resistor resistor (560ohm) (1Mohm) gnd (ground) (-) The Internet .:download:. breadboard layout sheet http://ardx.org/BBLS13E 32 2 Pin Header x4 Piezo Vibration Sensor Minisense 100 x1 560 Ohm Resistor Green-Blue-Brown x1 1 M Ohm Resistor Brown-Black-Green x1 CODE CIRC-13 (no need to type everything in, just click) Download the Code from (http://ardx.org/CODE13E) (copy the text and paste it into an empty Arduino Sketch) /* Knock Sensor void loop() { This sketch reads a piezo element to detect a knocking sound. sensorReading = analogRead(knockSensor); //read the sensor */ // if the sensor reading is greater than the // threshold: if (sensorReading >= threshold) { const int ledPin = 13; // led connected to // digital pin 13 const int knockSensor = A0; // the piezo is connected to analog pin 0 const int threshold = 100; // threshold value to decide when the // detected sound is a knock or not int sensorReading = 0; // variable to store the value read // from the sensor pin int ledState = LOW; // variable used to store the last LED // status, to toggle the light } *** This code is a modified version of the *** *** included example code *** *** Examples > 6. Sensors > Knock *** void setup() { pinMode(ledPin, OUTPUT); // declare the ledPin as an OUTPUT Serial.begin(9600); // use the serial port } NOT WORKING? } ledState = !ledState; // toggle the status of the ledPin: digitalWrite(ledPin, ledState); // update the LED pin itself: Serial.println("Knock!"); // send the string "Knock!" delay(100); // delay to avoid overloading the serial // port buffer (3 things to try) LED Not Changing? No Response Looking For More? (shameless plug) If you’re looking to do more The vibration sensor is The default threshold value is designed to be soldered rather quite high. Sometimes you than used in a breadboard. may need to flick the sensor, why not check out all the Because of this sometimes it or shake it quite hard to see lovely extra bits and bobs isn’t quite settled. Double check a response. available from http://www.seeedstudio.com its connection. MAKING IT BETTER Adjusting the Sensitivity To adjust the sensitivity simply change one line in the code: element in its place. The pin spacing is different so you will need to move a couple of wires. Once this is done, tap the plastic casing to see the LED toggle. (If it doesn’t const int threshold = 100; | const int threshold = *new number*; For greater sensitivity use a smaller number, (as low try turning it 180 degrees or changing the sensitivity in the code). Fine Tuning If you’re interested in the exact values being received as 1 will work but you may get some false readings) you can change the code to output the readings to the Using the Piezo Buzzer If you’d prefer to sense a knock rather than serial monitor. Simply download the code from http://ardx.org/MABE13E Upload to your Arduino and open the Serial Monitor vibration, you can use the piezo element supplied with the kit (used in CIRC-06). To do this simply (Ctrl+Shift+m) remove the vibration sensor and put the piezo MORE, MORE, MORE: More details, where to buy more parts, where to ask more questions: http://seeedstudio.com 33
110060004 价格&库存
很抱歉,暂时无法提供与“110060004”相匹配的价格&库存,您可以联系我们找货
