3241
    ADAFRUIT
    WASHER SHOULDER 3/8 FIBRE
3241 数据手册
Raspberry Pi 3 Model B Starter Pack (Without Raspberry Pi) PRODUCT ID: 3241 Description *RWWDVD\WKLVQHZ3LLVIO\¬$OOWKHFRRONLGVDUHJRLQJWRKDYHLWEXWDOOWKHFRROHVWNLGVDUH DOVRJRLQJWRKDYHDELJSDFNRIVXSHUFRRODFFHVVRULHV :H YHKDQGFKRVHQWKHVHDFFHVVRULHVDVWKHSHUIHFWDFFRPSDQLPHQWWR\RXUQHZ5DVSEHUU\3L 0RGHO%¬,W VHYHU\WKLQJ\RXQHHGWRJHWJRLQJZLWKDKLJKTXDOLW\SRZHUVXSSO\5DVSELDQ* 122%V6'FDUG¬ QHZO\XSGDWHGWRZRUNRQWKH3L ORYHO\FDVHKDQG\FRQVROHFDEOHDQGORWVRI SURWRW\SLQJHVVHQWLDOV¬,W VD¬JUHDWMXPSLQJRIISRLQWIRUWKHUHVWRIRXUH[WHQVLYHDFFHVVRU\DQG pack collection. Note.HHSLQPLQGWKDWWKHIRUPRIWKH3LGLGQ WFKDQJHPXFKVRPDQ\RIWKH LPSRUWDQW¬DFFHVVRULHVKDYHQ WFKDQJHG¬7KHELJFKDQJHVDUHWKHEXLOWLQ:L)LRQERDUG%OXHIUXLW /RZ(QHUJ\DQGRIFRXUVHPRUHVSHHHHHHHHG 7KLVSDFN'2(6127LQFOXGHD5DVSEHUU\3L&RPSXWHU 7KLVSDFN¬FRQWDLQV Adafruit Raspberry Pi B+ Case - Smoke Base / Clear Top - We think it's the Single Greatest Raspberry Pi 2 Model B Case Ever. This will still work with your Pi 3. $GDIUXLW$VVHPEOHG3L&REEOHU3OXV7KLVLVWKHVROGHUHGWRJHWKHUYHUVLRQRIRXUSRSXODUPi Cobbler Plus Kit¬&RPHVZLWKDEUHDNRXWERDUGWKDW VSHUIHFWIRUFREEOLQJSURWRW\SHV¬DVZHOODV DSLQ*3,2FDEOHIRU\RXU3L VSLQV¬6WLOOZRUNVZLWKWKH3L &Ƶůů^ŝnjĞƌĞĂĚďŽĂƌĚ - In the past, we've used the half-size breadboard for a lot of Pi projects - but no longer! WIth 40 pins to break out, you're going to need some space - and that's why we're including a full size breadboard in this pack. Premium Male/Male Jumper Wires - 20 x 6" (150mm) - These jumper wires are great for making wire harness or jumpering between headers on PCBs. We include the longer ones so they work well with the full-size breadboard. USB to TTL Serial Cable - An old standby, this cable's pretty much the easiest way to connect your Raspberry Pi to a USB port to log into the debugging/login console. Ideal for running the Pi 'headless' 8 GB SD Card pre-installed with Raspbian Jessie - 8GB microSDHC card programmed with the latest Raspberry Pi Jessie distribution. This SD card contains the March 18th 2016 version of Jessie, updated to include the latest support for the Pi 3 w/Wifi 5V 2.4A Switching Power Supply w/ 6' MicroUSB Cable - The 5V 2A power adapter is the perfect choice for powering your Raspberry Pi B+ with 2 Amps of current output, and an extra long cord. Note: As of March 28th, 2016 we've updated our power supply to be 5V 2.4A. Embroidered Raspberry Pi Badge - Now that you're getting started, show off your Pi Pride with this beautifully embroidered, jewel toned, iron-on badge. BONUS PARTS! Everyone loves bonuses so we include some parts that will get you through some of the tutorials on the Adafruit Learning System. These include: 1x Photo Cell [.:5HVLVWRU [RKP:5HVLVWRU ['LIIXVHGPP%OXH/(' [(OHFWURO\WLF&DSDFLWRUX) ['LIIXVHGPP5HG/(' ['LIIXVHGPP*UHHQ/(' [PP7DFWLOH6ZLWFKHV Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3241”相匹配的价格&库存,您可以联系我们找货
