A000028
A000028
    ARDUINO
    KIT BASE WORKSHOP W/O ARDUINO BD
A000028 数据手册
1050-1011-ND, Arduino A000028 Kit Contents Quantity 1 1 1 1 5 5 10 5 5 5 3 1 1 3 1 1 1 2 1 5 2 2 1 1 Part USB cable Straight single line Pinhead Connector 2,54 40x1 Breadboard, 840 tie points Set of 70 Breadboard Jumper Wires 10K Ohm Resistors 1/4W 2.2K Ohm Resistors 1/4W 220 Ohm Resistors 1/4W 330K Ohm Resistors 1/4W 100nF Capacitors Polyester 10nF Capacitors Polyester 100uF Electrolytic Capacitors 25Vdc 4.7K Ohm Thermistor 70..100K Ohm LDR VT90N2 5mm Red LEDs 5mm Green LED 5mm Yellow LED 10K Ohm Potentiometer, PCB terminals BC547 Transistors, TO92 Package Piezo Buzzer PCB Pushbuttons, 12x12mm size 4N35 Optocouplers, DIL-6 package Tilt Sensors Diode 1N4007 MOS IRF520 May 19, 2011
A000028 价格&库存
很抱歉,暂时无法提供与“A000028”相匹配的价格&库存,您可以联系我们找货
