KIT-11470
KIT-11470
    SPARKFUNELECTRONICS
    ARDUSENSORLEARNINGKITARDUINO
KIT-11470 数据手册
Page 1 of 2   Qtechknow ArduSensor Learning Kit KIT -1 1470 RO HS   Description: Have you always been curious about sensors but never knew where to start? The Qtechknow ArduSensor Learning Kit for Arduino is a fantastic option! Inside the kit are two boards, one an ArduSensor shield and the other a conglomeration of eight smaller boards that are v-scored between one another making it easier for you to solder all the sensors in first and then break apart at your own leisure. This kit boasts eight different types of sensors, including button, flex, force, magnet, temperature, light, knock, and (of course) fart. These sensors, once soldered, can easily be placed onto the ArduSensor Shield in one of four designated areas with readings from an RGB LED, a buzzer, and an LED bar graph relaying the information to you. This comes in kit form and must be soldered together by the end user. Please note we do not ship assembly instructions, but you can find an assembly guide below! Note: The silk labels for ArduSensor A2 and A3 are reversed. The actual pin labels are correct next to the headers, use those for reference. Note: This product is a collaboration with Quin at Qtechknow.com. A portion of each sales goes back to him for product support and continued development. Kit Includes: • 1x ArduSensor Shield PCB • 1x ArduSensor v-scored PCB • 1x Methane CNG Gas (Fart) Sensor Page 2 of 2 • • • • • • • • • • • • • • • • 1x Piezo Element (Knock) 1x Mini Photocell (Light) 1x TMP36 Sensor (Temperature) 1x Reed Switch (Magnet) 1x Force Sensitive Resistor (Force) 1x Flex Sensor (Flex) 1x LED Bar Graph 1x Piezo Speaker 2.048 KHz 1x RGB LED 2x Push Button Switch 1x 1M Ohm Resistor 3x 330 Ohm Resistor 6x 10k Ohm Resistor 2x 330 Ohm Resistor Network - 6-pin 4x M/F Headers - 6-pin 12x M/M Headers (1x 10-pin, 2x 8-pin, 9x 6-pin) https://www.sparkfun.com/products/11470 8/5/2016
KIT-11470 价格&库存
很抱歉,暂时无法提供与“KIT-11470”相匹配的价格&库存,您可以联系我们找货
