TW-DIY-5052
TW-DIY-5052
    TWIN
    KIT FLASHER 5 ULT BRIGHT LED DIY
TW-DIY-5052 数据手册
title Page 1 of 2 Home | About Us | Sitemap Enter Keyword to Search Product Custom Design Find A Distributor Online Specials Contact Us Shopping Cart Product Details Prototyping Boards PCI Express Products CompactPCI Products VME / VME64x / VPX Products TW-DIY-5052 Five Ultra Bright LED's flashing in random or in sequence. Uses a COB (Chip-on-board) PCB measuring 3cm x 1.5 cm. The flashing freque set by a single external resistor between 300K and 1M ohm. A pad connected high determines the random or sequential flash pattern. A se pad connected low determines whether the flashing is continuous or set by a toggle switch. Excellent project for schools since the projec very safe - uses 2 x 1.5V batteries, can be easily put together within 30 minutes, teaches the latest electronic technology as found in game toys and give an strong visual result when it is finished. Comes with a motherboard to aid attaching the components to the COB PCB. PMC Products Five Ultra Bright LED Flasher Kit - DI FPGA Development Boards This cmos VLSI single chip-on-boa designed for electronic toy and warning applications. Five LED's flash on/off pseudo-random or sequential depending on whether a switch is op connected high. PCI Products SMT & BGA Adapters ExpressCard / PCMCIA / SD Continuous flashing mode or toggle on selectable by another switch. The flas is controlled by a trimpot. ISA Products Data Acquisition Products • KIT COMPONENTS Do It Yourself (DIY) Solder Kits Motherboard 1 Project Boxes+Protoboards 3V battery snap 1 Koa trimpot 500K - 1M 1 Lead Free Prototyping Products 100R resistor brown black brow SPDT switch 2 5mm ultra bright LED 5 Kit 52 COB PCB 1 zoom photo http://twinind.com/catalog_detail.php?id=237 2-pin post header 1 5/14/2012
TW-DIY-5052
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款红外遥控接收器,用于接收红外信号并转换成电信号输出。
3. 引脚分配:EL817共有3个引脚,分别为VCC、OUT和GND。
4. 参数特性:工作电压范围为3V至5.5V,工作电流为1.5mA,接收频率为38kHz。
5. 功能详解:EL817能够接收38kHz红外信号,并输出TTL电平信号。
6. 应用信息:广泛应用于家用电器、汽车电子等领域。
7. 封装信息:EL817采用SOP-8封装。
TW-DIY-5052 价格&库存
很抱歉,暂时无法提供与“TW-DIY-5052”相匹配的价格&库存,您可以联系我们找货
