Page 1 of 32
Assembly Guide for RedBot with Shadow
Chassis
Introduction
The SparkFun RedBot is a platform for teaching basic robotics and sensor
integration! It is based on the SparkFun RedBoard and fully programmable
using Arduino. This guide describes the assembly of the new Shadow
Chassis for the RedBot. If you want to learn how to program your robot, see
the Experiment Guide for RedBot.
NOTE: We recommend that you read all of the directions first, before
building your RedBot.
RedBot Basic Kit vs. SIK for RedBot
This tutorial will cover how to install all the parts in the SparkFun RedBot
Basic Kit and the SparkFun Inventor’s Kit for RedBot (SIK for RedBot).
The SIK for RedBot contains additional parts to the RedBot Basic Kit.
If you have the RedBot Basic Kit, please ignore sections pertaining to
these extra parts. These sections are marked with the label (SIK).
SparkFun RedBot Basic Kit
We have two flavors of the RedBot available - the Basic kit and the
SparkFun Inventor’s Kit for RedBot. If you have the SparkFun RedBot Basic
Kit, you can skip the sections marked with (SIK).
Page 2 of 32
Alternatively, you can pick up additional sensors to install on your RedBot.
These parts include the Wheel Encoder Kit, RedBot Buzzer, and two
RedBot Mechanical Bumpers. Follow the sections in this guide that covers
any of the extra sensors you might have.
RedBot Extra Sensors SparkFun Wish List
SparkFun USB Mini-B Cable - 6 Foot
CAB-11301
This is a USB 2.0 type A to Mini-B 5-pin cable. You know, the mini-B…
(2) Jumper Wire - 0.1", 3-pin, 6" (Black, Red, White)
PRT-13164
This is a simple three wire cable. Each cable is 6" long and is great fo…
SparkFun RedBot Buzzer
ROB-12567
This buzzer is an add-on for your RedBot that gives your robot the abi…
Wheel Encoder Kit
ROB-12629
This is the Wheel Encoder Kit from DAGU, a simple add-on to any wh…
(2) SparkFun RedBot Sensor - Mechanical Bumper
SEN-11999
These simple switches are the Mechanical Bumper sensor for the Sp…
SIK for RedBot
The SIK for RedBot has a few extra parts that you won’t see in the Basic
Kit. These include the mechanical bump sensors (whiskers), the buzzer,
and wheel encoders. If you have the SIK for RedBot, you can follow all the
sections in this guide, including those marked with (SIK).
Materials
The SparkFun RedBot Basic Kit contains the following pieces. SIK-only
parts are noted with an asterisk (*). Note that several of the parts need to
be snapped out of the main chassis boards.
Page 3 of 32
Part
Qty
A
Bottom Chassis Plate
1
B
Top Chassis Plate
1
C
Front Motor Mount
2
D
Rear Motor Mount
2
E
Side Strut
4
F
Encoder Mount
2
G
Mainboard Mount
2
H
Battery Pack Clip
1
I
Line Follower Mount
1
J
Line Follower Mount Plate
1
K
Motor
2
L
Wheel
2
M
Nub Caster
1
N*
Encoder Magnet Plate (SIK)
2
O*
Encoder Hall Effect Sensor (SIK)
2
P
RedBot Mainboard
1
Q
Line Follower Board
3
R
Accelerometer Board
1
S*
Buzzer Board (SIK)
1
T*
Bumper Board (SIK)
2
U*
Bumper Whisker (SIK)
2
V*
#4-40 x 3/8" Screw (SIK)
6
W*
#4-40 Nylon Standoff (SIK)
2
X*
#4-40 Hex Nut (SIK)
2
Y
3-Wire Jumper Cable (SIK)
3 (5*)
Z
Battery Holder
1
Page 4 of 32
AA*
AA Batteries (SIK)
4
AB*
Screwdriver (SIK) (Not Shown)
1
AC*
USB Mini-B Cable (SIK) (Not Shown)
1
* Indicates parts included in the SIK for RedBot
IMPORTANT: If you have the RedBot Basic Kit, you will need 4x AA
batteries.
Recommended Tools
None! The RedBot Basic Kit does not require any additional tools. The SIK
for RedBot comes with a screwdriver, which you will need to mount the
Bumper Boards. If you bought the Bumper Boards separately, you will need
a Phillips screwdriver.
WARNING: Do not attempt to remove chassis parts by squeezing them
with pliers. You will break them, and the robot will be sad.
A Note About Directions
When we talk about the “front,” “left,” “right,” and “back” of the RedBot, we
are referring to specific sides of the robot when viewed from above.
Notice that we consider the Mainboard to be on the “back” of the RedBot
and the Bumper Whiskers and Line Follower Boards to be in the “front.”
1. Wheel Encoders (SIK)
Read on if you have the SIK for RedBot or are using the Wheel
Encoder Kit. If not, skip to the next section.
Page 5 of 32
The Wheel Encoder Kit is a simple add-on sensor that can be used to
detect how far each wheel rotates. The wheel encoders will allow you to
monitor and control the distance the robot travels. The Wheel Encoder Kit
uses a multi-pole diametric ring magnet attached to the motor shaft. As the
motor spins, the ring magnet spins as well. This is detected by a small
magnetic sensor called a hall effect sensor. The RedBot can use this
sensor input to count / track the number of rotations of the motor and hence
how far the wheel moves.
NOTE: You will likely need some scissors to open the Wheel Encoder Kit.
Also, the Encoder Kit might contain some extra parts (e.g. screws and
some blue mounting bars). You won’t need those, as the Shadow Chassis
contains all the necessary mounting hardware.
Locate the Following:
1x Bottom Chassis Plate (A)
2x Encoder Mount (F)
2x Encoder Magnet Plate (N)
2x Encoder Hall Effect Sensor
(O)
Add the Magnets
Slide the Encoder Magnet Plates (N) onto the metal shaft on the back of the
Motors (K). Note that magnet side (silver) should face away from the motor.
Slide the magnet down onto the shaft, but make sure that it does not rub or
interfere with the back of the motor housing.
Repeat this for both motors.
2x Motor (K)
Page 6 of 32
Attach the Hall Effect Sensors
Left Encoder
Take one of the Encoder Mounts (F) and hold it so that the protruding slot is
on the left. Push one of the encoder sensors through the first slot on the
right.
Note: The direction of the sensor does not matter.
Loop the sensor and push it through the second (middle) slot.
Once more, push the sensor through the small protruding slot on the left.
Carefully pull the wires so there is no more slack in the mount. Make sure
the whole sensor can be seen coming out of the final slot (the sensor
should protrude between ¼" and 3/8" past the mount).
Page 7 of 32
Snap the assembled encoder mount into the back-left vertical slot of the
Bottom Chassis Plate (A).
Right Encoder
The right encoder is a mirrored assembly of the left encoder.
Take the other Encoder Mount (F) and hold it so that the protruding slot is
on the right. Push the other encoder sensor through the first slot on the left.
Page 8 of 32
Once more, push the sensor through the protruding slot on the right.
Bottom Chassis Plate (A). Note that the hall effect sensors are facing to the
outside of the chassis.
2. Motors and Wheels
The motors add some motion to the RedBot by turning the nice, rubbery
wheels.
NOTE: If you completed the previous Wheel Encoder (SIK) step, your
motors will each have an encoder magnet plate attached to their rear shaft.
However, they are not necessary to complete this step.
ALSO NOTE: Your motors might not be yellow. Worry not, they will work
just as well!
Page 9 of 32
2x Front Motor Mount (C)
2x Rear Motor Mount (D)
2x Wheel (L)
Attach Rear Motor Mounts
Hold the wires near the middle of the Motor (K), and carefully slide a Rear
Motor Mount (D) in from the side and over the two motor wires. Be careful
not to snag the wires, the cable tie, or the clear plastic strap.
Holding the motor wires, gently twist the Rear Motor Mount counter
clockwise so that it snaps in place on the motor and the wires are centered
in the gap of the motor mount. Again, be sure not to snag the wires under
the motor mount.
2x Motor (K)
Page 10 of 32
Repeat the process for the second motor.
Attach the Front Motor Mounts
Slide a Front Motor Mount (C) onto the protruding eyelet on the front of a
Motor (K). Ensure the rounded sides of the motor mounts are facing the
same way.
Page 11 of 32
Attach the Motor Assemblies to the Chassis
Snap one of the motor assemblies into the left 2 horizontal slots of the
Bottom Chassis Plate (A). Make sure that the rounded edges of the motor
mounts and the wires are facing toward the center of the chassis.
Snap the other motor assembly into the right 2 horizontal slots of the
Bottom Chassis Plate (A). Again, make sure that the rounded edges of the
motor mounts and the wires are facing the center of the chassis.
Attach the Wheels
Slide one Wheel (L) onto the plastic shaft of a Motor (K). Look at the motor
shaft. Notice it has two flat edges. Make sure to line up the flat edges of the
motor shaft with the flat edges of the wheel.
Repeat with the other wheel.
3. Line Follower
Page 12 of 32
In this section, you will be putting standoffs on the RedBot Sensor - Line
Followers. Then you will add the sensors to your chassis.
1x Line Follower Mount (I)
1x Line Follower Mount Plate
(J)
3x Line
Follower
Board (Q)
3x 3-Wire Jumper Cable (Y)
Construct the Line Follower Assembly
Attach the 3 Line Follower Boards (Q) to the Line Follower Mount (I) such
that the rectangular pegs in the Line Follower Mount poke through the
mounting holes in the Line Follower Boards. Make sure the sensors are
facing away/down from the clip of the mount.
Place the Line Follower Mount Plate (J) on top of the Line Follower Mount
(I) so that the center clip of the mount is poking through the center slot of
the plate.
Page 13 of 32
Attach the Cables
You will need to connect a 3-Wire Jumper Cable (Y) to each of the Line
Follower Boards (Q). Note the color of the wire attached to each pin.
Line Follower Connections:
Jumper Wire Color
RedBot Sensor - Line Follower
Black
GND
Red
VCC
White
OUT
Attach all 3 cables to the 3 Line Follower Boards. Notice that the white wire
should be on the right and the black wire should be on the left.
Attach the Line Follower Assembly to the
Chassis
Locate the wide, rectangular slot near the front of the chassis and snap the
line follower assembly in from the bottom side of the chassis. Route the
cables through the large hole in the bottom plate.
Page 14 of 32
4. Mechanical Bumpers (SIK)
Read on if you have the SIK for RedBot or are using the Mechanical
Bumpers. If not, skip to the next section.
One of the sensors included in the SIK for RedBot are a set of Whisker
Mechanical Bumpers. These are basically simple switches that close a
circuit when the whisker pushes against an object. The whiskers are made
from a thick music wire and a simple RedBot Bumper board. You will need
to prepare the music wire by bending the wire itself. Then, you will add
standoffs and screws to your mechanical bumpers, followed by adding the
mechanical bumpers to the RedBot chassis.
1x Top Chassis Plate (B)
2x Bumper Board (T)
2x Bumper Whisker
(U)
6x #4-40 x 3/8" Screw (V)
2x #4-40 Nylon Standoff (W)
2x #4-40 Hex Nut (X)
2x 3-Wire Jumper Cable (Y)
1x Phillips Screwdriver (AB)
A Note About the Screwdriver
Page 15 of 32
The Mini Screwdriver contains a flat-head and Phillips head. To change to
the Phillips head, you might have to remove the metal shaft, turn it around,
and insert it back into the plastic handle.
Prepare the Mechanical Bumpers
Screw a #4-40 x 3/8" screw (V) and #4-40 hex nut (X) to one of the two
large mechanical bumper holes. You can get it pretty tight with just your
fingers, but we’ve included a screwdriver screwdriver (AB) in your kit. Note
that the screwdriver has both a Phillips and a regular head. Pull the
screwdriver out of the handle to change the head.
Time to bend the whisker!
It is easy to bend the whisker using needle nose pliers. However, there is a
trick to bend the whisker using the Mechanical Bumper Board itself. First,
stick one of the whiskers (U) through one of the smaller side holes. It only
needs to stick out a little bit.
Page 16 of 32
Bend the whisker 90 degrees.
Bend the whisker 90 degrees again.
Now that the whisker is bent, take the wire out of the PCB hole. Add a
#4-40 x 3/8" Screw (V) from the bottom and loop the bent whisker around
the screw. Hold this tight and secure it with a the #4-40 nylon standoff.
Note: It is very important that you do not let the whisker touch the hex nut or
screw on the other side. This is what triggers the sensor. Leave a little
space between the wire and other side’s nut.
Page 17 of 32
Twist and tighten the #4-40 nylon standoff on top of the screw to secure the
whisker.
Double check that the whisker does not touch the #4-40 hex nut or screw
on the other side. Use the screwdriver to tighten the screw with out moving
the position of the whisker.
We want to opposing whiskers. Take note of which side your #4-40 x ¾"
standoff is on for the first mechanical bumper. Do the opposite for the other
bumper. Double check that there is one mechanical bumper that has a
#4-40 x ¾" standoff on the right side of the “RedBot Bumper” silkscreen
and one that has a #4-40 x ¾" standoff on the left side.
Attach the Bumpers to the Chassis
Page 18 of 32
Locate the wide rectangular slot on the front of the Top Chassis Plate (B).
Notice the four circular holes as well. This is the front of the chassis.
Using two #4-40 x 3/8" Screws (V), tighten down the bumper assemblies
with the two wires pointing in opposite directions on the bottom side of the
top chassis plate. The mechanical bumpers' header pins should be
pointing toward the center of the chassis piece.
Attach the Cables
You will need to connect a 3-Wire Jumper Cable (Y) to each of the Bumper
Boards (T). Note the color of the wire attached to each pin.
Bumper Connections:
Jumper Wire Color
Black
GND
Red
VCC
White
OUT
Attach both cables to the 2 Bumper Boards.
Route the cables through the left and right oval cutouts, respectively.
Page 19 of 32
5. Chassis
With the motors and a few sensors attached, we can assemble the main
body of the robot.
4x Side Strut (E)
1x Nub Caster (M)
You will also need the Top Chassis Plate and Bottom Chassis Plate
assemblies, which have any additional parts and sensors you attached in
previous steps.
Attach the Nub Caster
Snap the Nub Caster (M) into the slot on the back of the Bottom Chassis
Plate assembly. Make sure the Nub Caster is on the side opposite the
motors (the bottom side).
Add the Side Struts
Snap the four Side Struts (E) into the diagonal slots on the four corners of
the Bottom Chassis Plate assembly.
Page 20 of 32
Route the Cables
Position the Top Chassis Plate over the Bottom Chassis Plate – but do not
snap the two plates together yet. Make sure that the front sides of each
plate line up.
Route the wires and cables through the left and right oval slots in the Top
Chassis Plate assembly as shown. For the center line follower sensor,
route this cable through the right oval slot. Note that SIK-only cables are
listed with an asterisk (*).
NOTE: It might be a good idea to use some pieces of masking tape to mark
which cables go to which component. It’s not necessary, but it might help
keep things organized.
Cable Routing:
Cable Connection
Oval Side
Left Bumper Sensor*
Left
Right Bumper Sensor*
Right
Left Line Follower
Left
Center Line Follower
Right
Right Line Follower
Right
Left Motor wires (red and black)
Left
Right Motor wires (red and black)
Right
Left Wheel Encoder*
Left
Right Wheel Encoder*
Right
Attach Top Chassis Plate Assembly
Page 21 of 32
Line up the Top Chassis Plate on top of all the struts, and carefully snap the
Top Chassis Plate assembly onto the side struts and motor mounts. Press
gently above each side strut individually until they each snap into place. If
you have the Bumpers installed, make sure the boards are between the top
and bottom plates.
If you need to remove the plate to change anything, gently pull upward on
each side strut individually. Do not attempt to use pliers or hand tools, or
you may end up snapping the plastic clip.
6. Mainboard
In this section, you will add brains of the robot: the RedBot Mainbooard.
2x Mainboard Mount (G)
1x RedBot Mainboard (P)
You will also need the full chassis assembly, which contains any additional
parts and sensors you attached in previous steps.
Attach the Mainboard Mounts
Snap the two Mainboard Mounts (G) into the vertical slots in the back of the
top chassis plate near the large rectangular opening.
Add the Mainboard
Page 22 of 32
The RedBot Mainboard (P) snaps into the lowest of the notches on the
Mainboard Mounts (G). Make sure the power jack is facing the left side of
the robot. Push gently and evenly until it snaps into place.
NOTE: The other slots in the mainboard mounts can be used to hold the
Arduino UNO or the SparkFun RedBoard.
Connecting the Cables
It is time to connect the jumper wires; it is really important that these
connections are right.
You can follow along with the pin out tables or scroll down for a diagram.
Trace each cable poking through the top chassis plate to make sure you
know what it is connected to.
If you have the RedBot Basic Kit, disregard any extra sensors that are
missing in your kit. These sensors will be marked with the label (SIK).
Please note: When you have the RedBot upright and the front of the
chassis facing away from you, “left” sensors/motors will be on the left side
and “right” sensors/motors will be on the right side. Also - the motor wires
are intentionally switched for the right motor – see notes below.
Line Followers
Left Line Follower:
RedBot Mainboard
Pins
Jumper Wires
Left Line Follower
Board
A3
3-Wire Jumper Cable White
OUT
5V
3-Wire Jumper Cable Red
VCC
GND
3-Wire Jumper Cable Black
GND
Center Line Follower:
Page 23 of 32
RedBot Mainboard
Pins
Jumper Wires
Middle Line Follower
Board
A6
OUT
5V
VCC
GND
GND
RedBot Mainboard
Pins
Jumper Wires
Right Line Follower
Board
A7
OUT
5V
VCC
GND
GND
Right Line Follower:
Whisker Mechanical Bumpers
Left Mechanical Bumper (SIK):
RedBot Mainboard
Pins
Jumper Wires
Left Bumper
Board
3
OUT
POW
5V
GND
GND
Right Mechanical Bumper (SIK):
RedBot Mainboard
Pins
Jumper Wires
Right Bumper
Board
11
OUT
POW
5V
GND
GND
Page 24 of 32
Motors
Left Motor:
RedBot Mainboard Pins
Left Motor Jumper Wires
LEFT MOTOR - RED
Soldered on Motor Jumper Wire - RED
LEFT MOTOR - BLACK
Soldered on Motor Jumper Wire - BLACK
*Right Motor:
Right Motor Jumper Wires
RIGHT MOTOR - RED
Soldered on Motor Jumper Wire BLACK
RIGHT MOTOR - BLACK
Note that these are reversed! We need to plug the red wire into the
port marked "BLACK" and the black wire into "RED." This is because the
new Shadow Chassis motors were wired backwards (not mirrored).
Motor Encoders
Left Wheel Encoder (SIK):
RedBot Mainboard
Pins
Jumper Wires
Left Wheel
Encoder
A2
OUT
POW
5V
GND
GND
Right Wheel Encoder (SIK):
RedBot Mainboard
Pins
Jumper Wires
Right Wheel
Encoder
10
OUT
POW
5V
GND
GND
Diagram
Page 25 of 32
Note: The connections on the right motor are intentionally switched. See
the note above.
Having a hard time seeing the image? Click on the image to see a bigger
diagram.
7. Accelerometer
Time to add the RedBot accelerometer! The accelerometer is a special
sensor that can be used to measure speed (through acceleration), tilt
(orientation), and detect jolts or bumps. If you do not have headers on your
accelerometer already (older revisions of the RedBot accelerometer did not
have headers), we recommend soldering on female headers to your
accelerometer to fit on top of the RedBot Mainboard’s headers.
1x Accelerometer Board (R)
Add the RedBot Accelerometer
Locate the SENSOR port with “A4” and “A5” marked near the upper right
corner of the RedBot Mainboard. Line up the “A4” pin on the accelerometer
to the “A4” male header pin on the RedBot Mainboard, and attach the
Accelerometer Board (R).
Page 26 of 32
8. Buzzer (SIK)
Read on if you have the SIK for RedBot or are using the RedBot
Buzzer. If not, skip to the next section.
Every robot should be able to make some sounds. Adding the buzzer will
allow you to give your RedBot a little personality with its own beeps and
bops. Adding the RedBot Buzzer is nice and easy!
1x Buzzer Board (S)
Add the RedBot Buzzer
Locate the SERVO port with “9” marked on the RedBot Mainboard. With the
buzzer and female header side of the Buzzer Board (S) facing to the left,
place the Buzzer Board on top of the “9”, “POW”, and “GND” male header
pins.
Page 27 of 32
9. Batteries
The last step is to provide a power source for the RedBot. If you do not
have the SIK for RedBot, you will need to provide your own AA batteries.
1x Battery Pack Clip (H)
1x Battery Holder (Z)
* Provided in the SIK for RedBot
Insert Batteries
Insert the AA batteries into the Battery Holder (Z). Makes sure the batteries
are facing the correct direction, as per the markings inside of the Battery
Holder.
Attach Battery Pack
Insert the Battery Holder (Z) with batteries into the back cavity of the
RedBot. Position the Battery Holder so that the barrel jack cable comes out
on the left side of the robot.
4x AA Batteries* (AA)
Page 28 of 32
Insert the Battery Pack Clip (H) on top of the battery pack.
Twist and position the clip so that it rests on top of the battery pack.
Push the clip down into the vertical slots in the Bottom Chassis Plate so it
snaps in place.
Route the barrel jack cable out of the left side of the RedBot and up to the
Mainboard. If you have a motor encoder (SIK), make sure that the cable
does not interfere with the magnet or the hall effect sensor.
Plug the barrel jack cable into the connector labeled V_IN.
Page 29 of 32
Changing the Batteries
If you find that you need to replace the batteries in the RedBot, the process
is simple. Unplug the battery pack from the Mainboard.
Turn the RedBot over and push on the Battery Holder through the hole in
the Bottom Chassis Plate. This will cause the Battery Pack Clip to unsnap
from the Bottom Chassis Plate.
Slide the Battery Pack and Clip out from the back of the RedBot.
Page 30 of 32
Change the batteries, and follow the steps in Attach Battery Pack section
above to put the Battery Pack back in the RedBot.
10. Run It!
Now that we have built the RedBot, we should verify that it works. If you
would like a more in-depth explanation of how to program your robot, visit
the Experiment Guide for RedBot with Shadow Chassis. This will work with
the RedBot Basic Kit as well as the RedBot SIK.
Install Drivers
To program your robot right from your browser, you will first need to install
some FTDI drivers. Follow the steps in How to Install FTDI Drivers to do
that.
Install Codebender Plugin
You will need Google Chrome or Firefox as a browser for the plugin to
work. If you do not have either of those and do not wish to install them, you
should follow the steps in the Experiment Guide to program the RedBot
from the Arduino software.
Click here to install the Codebender Plugin for your Chrome or Firefox.
Power the RedBot
To program the RedBot from your browser, make sure you have the FTDI
drivers and Codebender plugin) installed. Plug in the RedBot using a USB
mini cable.
Turn the RedBot POWER switch to ON and the MOTOR switch to RUN.
Page 31 of 32
Test Some Code
Example Name
[ Edit
È Clone & Edit
3 Download
In the window above, select “Arduino UNO” for the board. Select COM port
for the RedBoard (this will be the number or name that appears when you
plug in the RedBoard).
Click the “Run on Arduino” button. The code should be pushed to the
Arduino automatically.
WARNING: If the MOTOR switch is set to RUN, the RedBot will move
forward (quite rapidly) for 2 seconds. You might want to pick the RedBot up
so that it doesn’t run away from you!
The RedBot will drive forward for only 2 seconds and then stop. If you want
to run the code again, you will need to press the RESET button on the
RedBot Mainboard.
Page 32 of 32
Resources and Going Further
What a rock star! With all that building, we bet you are ready to start
cruising. We recommend continuing to the Experiment Guide for RedBot
with Shadow Chassis to learn how to program your new robot friend.
RedBot with Shadow
Chassis
This Experiment Guide offers nine
experiments to get you started with
the SparkFun RedBot. This guide is
designed for those familiar with our
SparkFun Inventors Kit and want to
take their robotics knowledge to the
next level.
Upgrades
You might have noticed some odd-looking hole patterns in the top plate and
side struts. The RedBot’s chassis is manufactured to accept Actobotics
parts. Feel free to add other mounts, gimbals, servos, and claws!
Resources
GitHub repositories:
RedBot
RedBot with Optical Encodery
RedBot Line_Sensor
RedBot Whisker Bumper
RedBot Buzzer
https://learn.sparkfun.com/tutorials/assembly-guide-for-redbot-with-shadow-chassis/all
6/24/2015
