28114
28114
    PARALLAXINC.
    ACTIVITYBOT WHEEL & TIRE
28114 数据手册
Complete ESD Safe Program ing on For work ive sit static sen electronic nts! compone Static Dissipative Professional ESD Safe Tools 2 Toll Free: (800) 494-6104 What is ESD? Basic Concepts in Electrostatic Discharge (ESD) We have all seen static electricity in the form of lightning or perhaps felt the zap when reaching for a door knob. Similar types of electrical charges can have an effect on the electronic components you handle every day in your work. Unfortunately, their effect is much more hazardous and not as readily apparent. Definition Static electricity is an electrical charge at rest. Static electricity is most commonly created by friction and separation. Friction causes heat which excites the molecular particles of the material. When two materials are then separated, a transfer of electrons from one material to the other may take place. As electrons transfer, the absence or surplus of electrons creates an electrical field known as static electricity. The simple separation of two materials, as when tape is pulled off a roll, can also create this same transfer of electrons between materials, generating static electrical fields. The amount of static electricity generated depends upon the materials subjected to friction or separation, the amount of friction or separation and the relative humidity of the environment. Common plastic generally will create the greatest static charge. Low humidity conditions such as those created when air is heated during the winter will also promote the generation of significant static electrical charges. Materials that easily transfer electrons (or charge) between atoms are called conductors and are said to have “free” electrons. Some examples of conductors are metals, carbon and the human body’s sweat layer. Materials that do not easily transfer electrons are called insulators. Some well known insulators are common plastics, glass and air. Both conductors and insulators may become “charged” with static electricity. When a conductor is charged, the free electrons give it the ability to discharge rapidly when it comes close to another conductor with a different potential. Typical Electrostatic Voltages Many of the common activities you perform daily may generate charges on your body that are potentially harmful to components. Some of these activities include: · Walking across a carpet, 1,500 to 35,000 volts · Walking over untreated vinyl floor, 250 to 12,000 volts · Worker at a bench, 700 to 6,000 volts · Vinyl envelope used for work instructions, 600 to 7,000 volts · Picking up a common plastic bag from a bench, 1,200 to 20,000 volts Costly Effects of ESD When you feel a static shock, you are experiencing a minimum of 3,000 volts of electricity. This “shock” known as Electro Static Discharge or ESD also may be responsible for damaging many of the rejected electronic components in your company. While you can feel electrostatic discharges of 3,000 volts, smaller charges are below the threshold of human sensation. Unfortunately, smaller charges can and do damage semiconductor devices. Many of the CMOS technology components used in your facility can be damaged by charges of less than 1,000 volts. Some of the more sophisticated components can be damaged by charges as low as 10 volts. You should be aware of the relative sensitivity to ESD damage of devices you may be working with. As electronic technology advances, electronic components tend to become smaller and smaller. As the size of the components is reduced, so is the microscopic spacing of insulators and circuits within them, increasing their sensitivity to ESD. As you can predict, the need of proper ESD protection increases everyday. Types of ESD Damage This Article courtesy of Desco Industries, Inc Static damage to components can take the form of upset failures or catastrophic failures. · Upset failures - result in gate leakage · Catastrophic failures - occur in two forms, Direct and Latent Direct catastrophic failures occur when a component is damaged to the point where it is DEAD NOW and it will never again function. This is the easiest type of ESD damage to find since it usually can be detected during testing. Latent failures occur when ESD weakens or wounds the component to the point where it will still function properly during testing, but over time the wounded component will cause poor system performance and eventually complete system failure. Because latent failures occur after final inspection or in the hands of your customer, the cost for repair is very high. Not only is this type of damage hard to find, but it severely affects the reputation of your company’s product. An upset failure occurs when an electrostatic discharge has caused a current flow that is not significant enough to cause total failure, but in use may intermittently result in gate leakage causing loss of software or incorrect storage of information. Upset or latent failures may pass your company’s quality control testing program. In other words, static damage may occur that cannot be felt, seen, or detected through normal testing procedures. Think of Static As Contamination! Damage caused by invisible and undetectable events can be understood by comparing ESD damage to medical contamination of the human body by viruses or bacteria. Although viruses and bacteria are invisible, they can cause severe damage even before you can detect their presence. A defense against this invisible threat is sterilization. As an employee, the hidden threat of electrostatic discharge or ESD should be of great concern to you. ESD damage can significantly reduce your company’s profitability. This may affect your profit sharing, your company’s ability to compete in the market place and even your employment. Everyone likes to take pride in their work, but without proper ESD controls, your best efforts may be destroyed by static electricity that you can neither feel nor see. ESD Safe Precision Screwdrivers Description Page Prec. Slotted/Phillips 4-5 Prec. Torx/TorxPlus 6 Prec. Hex Screwdrivers 7 Prec. Nut Drivers 8 Ceramic Slotted/Phillips 9 ESD Safe SYSTEM 4 Handles/Blades & Sets Description Page SYSTEM 4 10-13 Drive-Loc VI 11 www.wihatools.com 3 ESD Safe Micro Bit Handles/Bits & Sets ESD Safe Drive-Loc VI Handle Description Page Description Page Micro Bits Drive-Loc VI Handle 14-15 ESD Safe SYS 4 ESD Safe Micro Bit Sets 20-21 ESD Safe TorqueControl Tools Description Page Description Page Micro Bit Sets TorqueControl Drivers 22 TorqueControl Blades 22 16 ESD Safe Cushion Grip Bit Holders Description Page SoftFinish® Bit Holders 17 Quick Release Bit Holder 17 ESD Safe Pliers & Cutters Index Description Page Diagonal Cutters 23 Tapered Head Diagonal Cutters 24-25 Wide Tapered & Oval Head ESD Safe Cushion Grip Screwdrivers Description Page SoftFinish® Slotted Drivers 18 SoftFinish® Phillips Drivers 18 SoftFinish® Torx® Drivers 18 Diagonal Cutters 25 Wide Oval & Wide Form Oblique Angled Cutters 26 Carbide Edge End Cutters 27 Pliers 27-28 ESD Safe Proturn Pliers & Cutters Index Description Page ESD Safe Interchangeable Blade Sets Description Page Interchangeable ESD Sets 19 Proturn Wire Strippers 29 30 to 20 AWG Proturn Pliers 29-30 Long, Flat, Bent, Round Nose Precision Cutters/Flush Cut 30-31 21° & 45° Angle ESD Safe Calipers Index ESD Safe Tweezers Index Description Page Description Page Calipers Tweezers 19 32-34 Toll Free: (800) 494-6104 4 Precision ESD Safe Dissipative Drivers Wiha Precision ESD Static Dissipative Screwdrivers meet the requirements for tools used in static sensitive areas. Rotating cap for precise turning & control with fingertip Molded Precision handle of impact resistant dissipative material Tapered handle allows rapid rotation Blade, CVM steel, hardened, hard chrome finish ESD Standard IEC 61340-5-1 Tip, precision ground for exact fit, Wiha Chromtop finish Surface resistance of handles is 106 - 109 Ohms 272 Slotted Screwdriver, With Precision ESD Safe Dissipative Handle Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finished. Handle manufactured from impact resistant, dissipative material. ESD standard IEC 61340-5-1 Item No. mm Inch mm Inch mm Inch mm Inch lbs. pkg. 27208 .8 1/32 40 1.6 0.16 .01 120 4.7 .02 10 27210 1.0 .039 40 1.6 0.18 .01 120 4.7 .02 10 27212 1.2 3/64 40 1.6 0.20 .01 120 4.7 .02 10 27215 1.5 1/16 40 1.6 0.25 .01 120 4.7 .02 10 27220 2.0 5/64 40 1.6 0.40 .02 120 4.7 .02 10 27222 2.0 5/64 75 3.0 0.40 .02 155 6.1 .03 10 27223 2.0 5/64 100 3.9 0.40 .02 180 7.1 .03 10 27224 2.0 5/64 150 5.9 0.40 .02 260 10.2 .04 10 27225 2.5 3/32 50 2.0 0.40 .02 145 5.7 .04 10 27227 2.5 3/32 100 3.9 0.40 .02 195 7.7 .03 10 27228 2.5 3/32 150 5.9 0.40 .02 245 9.6 .04 10 27230 3.0 1/8 50 2.0 0.50 .02 145 5.7 .04 10 27232 3.0 1/8 100 3.9 0.50 .02 210 8.3 .04 10 27234 3.0 1/8 150 5.9 0.50 .02 260 10.2 .05 10 27235 3.5 9/64 60 2.4 0.60 .02 170 6.7 .06 10 27237 3.5 9/64 100 3.9 0.60 .02 210 8.3 .06 10 27238 3.5 9/64 150 5.9 0.60 .02 260 10.2 .06 10 27240 4.0 5/32 60 2.4 0.80 .03 170 6.7 .06 10 27242 4.0 5/32 100 3.9 0.80 .03 210 8.3 .06 10 27243 4.0 5/32 150 5.9 0.80 .03 260 10.2 .07 10 *Metric dimensions actual - Inch dimensions approximate D 27290 Set 8 Pcs. Slotted Precision ESD Safe Dissipative Handle Blade CVM steel, hardened, hard chrome. Handle impact resistant, dissipative material. In storage pouch. ESD standard IEC 61340-5-1 Item No. mm mm mm mm lbs. 27290 27208 .8 40 27220 2.0 40 .54 27210 1.0 40 27225 2.5 50 27212 1.2 40 27230 3.0 50 27215 1.5 40 27235 3.5 60 D 27390 Set 7 Pcs. Slotted & Phillips Precision ESD Safe Dissipative Handle Blade high alloy CVM steel, hardened, hard chrome. Handle manufactured from impact resistant, dissipative material. ESD standard IEC 61340-5-1 Item No. mm mm Size mm lbs. 27390 27215 1.5 40 27305 00 40 .30 27220 2.0 40 27310 0 50 27225 2.5 50 27320 1 60 27235 3.5 60 www.wihatools.com Precision ESD Safe Slotted/Phillips Drivers Surface resistance of handles is 106 - 109 Ohms D 273 Phillips Screwdriver, With Precision ESD Safe Dissipative Handle Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finished. Handle manufactured from impact resistant, dissipative material. ESD standard IEC 61340-5-1 Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 27302 000 40 1.6 2.0 .08 120 4.7 .02 10 27305 00 40 1.6 2.0 .08 120 4.7 .02 10 27307 00 75 3.0 2.0 .08 155 6.1 .02 10 27310 0 50 2.0 3.0 .12 145 5.7 .04 10 27312 0 75 3.0 3.0 .12 170 6.7 .03 10 27314 0 100 3.9 3.0 .12 195 7.6 .05 10 27316 0 150 5.9 3.0 .12 245 9.6 .06 10 27320 1 60 2.3 4.0 .16 170 6.7 .06 10 27322 1 75 3.0 4.0 .16 155 6.1 .06 10 27324 1 100 3.9 4.0 .16 210 8.2 .06 10 27326 1 150 5.9 4.0 .16 260 10.2 .07 10 *Metric dimensions actual - Inch dimensions approximate 27399 Set 8 Pcs. Slotted & Phillips Precision ESD Safe Dissipative Handle Blade high alloy CVM steel, hardened, hard chromed. Handle manufactured from impact resistant, dissipative material. In storage pouch. ESD standard IEC 61340-5-1 Item No. mm mm Size mm lbs. 27215 1.5 40 27302 000 40 .50 27399 27220 2.0 40 27305 00 40 27225 2.5 50 27310 0 50 27230 3.0 50 27320 1 60 D 27393 Set 7 Pcs. Extra Long Slotted/Phillips Precision ESD Safe Dissipative Handle Blade CVM steel, hardened, hard chromed. Handle impact resistant, dissipative material. ESD standard IEC 61340-5-1 Item No. mm mm Size mm lbs. 27224 2.0 150 27316 0 150 .50 27393 27228 2.5 150 27326 1 150 27234 3.0 150 27238 3.5 150 27243 4.0 150 91118 Rugged Polyester Canvas Storage Pouch Holds 8 Precision Tools up to 170mm in length. Folding pouch. Has security flaps and velcro closer. Item No. Size lbs. pkg. 91118 14 1/2” W x 7 3/4” L .13 1 5 Toll Free: (800) 494-6104 6 Precision ESD Safe Drivers Surface resistance of handles is 106 - 109 Ohms 278 Screwdriver, With Precision ESD Safe Dissipative Handle Blade high alloy CVM steel. Hard chrome finished. Handle impact resistant, dissipative material. ESD standard IEC 61340-5-1 Item No. Size mm Inch mm Inch lbs. pkg. T1 40 1.6 120 4.7 .03 10 27801 T2 40 1.6 120 4.7 .03 10 27802 T3 40 1.6 120 4.7 .03 10 27803 T4 40 1.6 120 4.7 .03 10 27804 T5 40 1.6 120 4.7 .03 10 27805 T6 40 1.6 120 4.7 .03 10 27811 T7 40 1.6 120 4.7 .03 10 27817 T8 40 1.6 120 4.7 .03 10 27823 T9 50 2.0 145 5.7 .04 10 27829 T10 50 2.0 145 5.7 .04 10 27835 T15 60 2.4 170 6.7 .07 10 27841 T20 60 2.4 170 6.7 .07 10 27847 *Metric dimensions actual - Inch dimensions approximate Precision ESD Safe Drivers Surface resistance of handles is 10 - 109 Ohms 6 Screwdriver, With Precision ESD Safe Dissipative 278 Handle Blade high alloy CVM steel, hardened, hard chromed. Handle impact resistant, dissipative material. ESD standard IEC 61340-5-1 Item No. Size mm Inch mm Inch lbs. pkg. 27850 IP4 40 1.6 120 4.7 .03 10 27851 IP5 40 1.6 120 4.7 .03 10 27852 IP6 40 1.6 120 4.7 .03 10 27853 IP7 40 1.6 120 4.7 .03 10 27854 IP8 40 1.6 120 4.7 .03 10 27855 IP9 50 2.0 145 5.7 .04 10 27856 IP10 50 2.0 145 5.7 .04 10 27857 IP15 60 2.4 170 6.7 .07 10 *Metric dimensions actual - Inch dimensions approximate ESD standard IEC 61340-5-1 ESD standard IEC 61340-5-1 D D 27890 Set 7 Pcs. Precision ESD Safe Dissipative Handle Blade high alloy CVM steel, hardened, hard chromed. Handle manufactured from impact resistant, dissipative material. Item No. Size mm Size mm lbs. 27890 27804 T4 40 27823 T8 40 .31 27805 T5 40 27829 T9 50 27811 T6 40 27835 T10 50 27817 T7 40 ESD standard IEC 61340-5-1 D Precision ESD Safe Dissipative Handle 27899 Set 8 Pcs. Set In Pouch Blade high alloy CVM steel, hardened, hard chromed. Handle impact resistant, dissipative material. Item No. Size mm Size mm lbs. 27899 27801 T1 40 27805 T5 40 .47 27802 T2 40 27806 T6 40 27803 T3 40 27807 T7 40 27804 T4 40 27920 Chip Lifter 27894 Set 7 Pcs. Precision ESD Safe Dissipative Handle Blade high alloy CVM steel, hardened, hard chromed. Item No. Size mm Size mm lbs. 27894 27851 IP5 40 27855 IP9 50 .27 27852 IP6 40 27856 IP10 50 27853 IP7 40 27857 IP15 60 27854 IP8 40 www.wihatools.com 7 Wiha Precision ESD Safe Hex Drivers Surface resistance of handles is 106 - 109 Ohms ESD standard IEC 61340-5-1 275 Metric Hex Driver, With Precision ESD Safe Dissipative Handle Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finished. Handle manufactured from impact resistant, dissipative material. ESD standard IEC 61340-5-1 Item No. mm mm Inch mm Inch lbs. pkg. 27507 .71 40 1.6 120 4.7 .02 10 27509 .89 40 1.6 120 4.7 .02 10 1.27 40 1.6 120 4.7 .03 10 27513 1.5 50 2.0 145 5.7 .03 10 27515 2.0 50 2.0 145 5.7 .04 10 27520 2.5 60 2.4 170 6.7 .05 10 27525 3.0 60 2.4 170 6.7 .05 10 27530 4.0 60 2.4 170 6.7 .05 10 27535 *Metric dimensions actual - Inch dimensions approximate D 27590 Set 8 Pcs. Hex Metric Precision ESD Safe Dissipative Handle Blade CVM steel, hardened, hard chromed. Handle impact resistant, dissipative material. In storage pouch Item No. mm mm mm mm lbs. 27590 27507 .71 40 27520 2.0 50 .53 27509 .89 40 27525 2.5 60 27513 1.27 40 27530 3.0 60 27515 1.5 50 27535 4.0 60 ESD standard IEC 61340-5-1 275 Inch Hex Driver, With Precision ESD Safe Dissipative Handle Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finished. Handle manufactured from impact resistant, dissipative material. ESD standard IEC 61340-5-1 Item No. Inch mm Inch mm Inch lbs. pkg. 27505 .028 40 1.6 120 4.7 .02 10 27510 .035 40 1.6 120 4.7 .02 10 27513 .050 40 1.6 120 4.7 .02 10 27537 1/16 50 2.0 145 5.7 .03 10 27539 5/64 50 2.0 145 5.7 .03 10 3/32 60 2.4 170 6.7 .04 10 27541 7/64 60 2.4 170 6.7 .04 10 27543 1/8 60 2.4 170 6.7 .04 10 27545 9/64 60 2.4 170 6.7 .05 10 27547 5/32 60 2.4 170 6.7 .05 10 27549 *Metric dimensions actual - Inch dimensions approximate D 27591 Set 8 Pcs. Hex Inch Precision ESD Safe Dissipative Handle Blade CVM steel, hardened, hard chromed. Handle impact resistant, dissipative material. In storage pouch Item No. Inch Inch Inch Inch lbs. 27591 27513 .050 1.6 27543 7/64 2.4 .57 27537 1/16 2.0 27545 1/8 2.4 27539 5/64 2.0 27547 9/64 2.4 27541 3/32 2.4 27549 5/32 2.4 91118 Rugged Polyester Canvas Storage Pouch Holds 8 Precision Tools up to 170mm in length. Folding pouch. Has security flaps and velcro closer. Item No. Size lbs. pkg. 91118 14 1/2” W x 7 3/4” L .13 1 8 Toll Free: (800) 494-6104 Wiha Precision ESD Safe Nut Drivers Surface resistance of handles is 106 - 109 Ohms ESD standard IEC 61340-5-1 277 Inch Nut Driver, With Precision ESD Safe Dissipative Handle Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finished. Handle manufactured from impact resistant, dissipative material. ESD standard IEC 61340-5-1 Item No. Inch mm inch mm Inch Inch Inch lbs. pkg. 27701 3/32 60 2.4 155 6.1 .16 .16 .04 10 27703 7/64 60 2.4 155 6.1 .20 .20 .05 10 27705 1/8 60 2.4 155 6.1 .20 .20 .05 10 27707 9/64 60 2.4 155 6.1 .21 .24 .05 10 27709 5/32 60 2.4 155 6.1 .22 .24 .05 10 27711 3/16 60 2.4 155 6.1 .25 .28 .05 10 27713 7/32 60 2.4 170 6.7 .30 .32 .06 10 27715 1/4 60 2.4 170 6.7 .34 .36 .06 10 *Metric dimensions actual - Inch dimensions approximate D 27791 Set 8 Pcs. Inch Nut Driver Precision ESD Safe Dissipative Handle Blade CVM steel, hardened, hard chromed. Handle impact resistant, dissipative material. In storage pouch Item No. Inch mm Inch mm lbs. 27791 27701 3/32 60 27709 5/32 60 .68 27703 7/64 60 27711 3/16 60 27705 1/8 60 27713 7/32 60 27707 9/64 60 27715 1/4 60 ESD standard IEC 61340-5-1 277 Metric Nut Driver, With Precision ESD Safe Dissipative Handle Blade high alloy chrome-vanadium-molybdenum steel. Hard chromed finished. Handle manufactured from impact resistant, dissipative material. ESD standard IEC 61340-5-1 Item No. mm mm inch mm Inch Inch Inch lbs. pkg. 27720 1.5 60 2.4 140 5.5 2.5 3.0 .03 10 27722 2.0 60 2.4 140 5.5 3.2 4.0 .04 10 27725 2.5 60 2.4 140 5.5 4.0 4.0 .05 10 27730 3.0 60 2.4 155 6.1 5.0 5.0 .06 10 27735 3.5 60 2.4 155 6.1 5.3 6.0 .06 10 27740 4.0 60 2.4 155 6.1 5.5 6.0 .06 10 27745 4.5 60 2.4 155 6.1 6.2 7.0 .05 10 27750 5.0 60 2.4 155 6.1 6.8 7.0 .06 10 27755 5.5 60 2.4 170 6.7 7.6 8.0 .07 10 27760 6.0 60 2.4 170 6.7 9.6 10.0 .06 10 *Metric dimensions actual - Inch dimensions approximate D 27790 Set 8 Pcs. Metric Nut Driver Precision ESD Safe Dissipative Handle Blade CVM steel, hardened, hard chromed. Handle impact resistant, dissipative material. In storage pouch Item No. mm mm mm mm lbs. 27790 27720 1.5 60 27735 3.5 60 .63 27722 2.0 60 27740 4.0 60 27725 2.5 60 27750 5.0 60 27730 3.0 60 27755 5.5 60 www.wihatools.com 9 Wiha Precision ESD Safe Chip Lifter Surface resistance of handles is 10 - 10 Ohms 6 27920 Precision Chip Lifter - ESD Safe Blade CVM steel, hardened, corrosion resistant finish. Precision handle high quality plastic, Dissipative material. Item No. 27920 Wiha Precision Ceramic 9 mm mm mm mm Inch lbs. pkg. 1 3.5 50 145 5.7 .07 1 E SD Safe dissipative handle D ESD standard IEC 61340-5-1 Surface resistance of handles is 106 - 109 Ohms 92092 Master Technicians Bench Top Set Metal frame. Equipped with 50 precision ESD Safe screwdrivers. Item No. 92092 lbs. 2.25 Slotted: .8, 1.0, 1.2, 1.5, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: #000, #00, #0, #1 : T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T15, T20 Metric Hex: .71, .89, 1.27, 1.5, 2.0, 2.5, 3.0, 4.0mm Inch Hex: 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Metric Nut Drivers: 1.5, 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm 27920 Chip Lifter 91118 Rugged Polyester Canvas Storage Pouch Holds 8 Precision Tools up to 170mm in length. Folding pouch. Has security flaps and velcro closer. Item No. Size lbs. pkg. 14 1/2” W x 7 3/4” L .13 1 91118 Handles are anti-static Blades antimagnetic Rotating cap facilitates adjusting and holding of the tools Free of contamination, suited for working in clean-rooms Blade High thermic and electric insulation Precision handle high quality plastic, cadmium free Surface resistance of handles is 106 - 109 Ohms 270 Ceramic Slotted Screwdriver, With Wiha-Precision Handle, Out of Anti-static Plastic Blade special ceramic, antimagnetic, for correct adjusting in high frequency areas. Item No. mm Inch mm Inch mm Inch mm Inch lbs. pkg. 27009 0.9 .035 15 .59 0.35 .01 94.5 3.7 .14 1 27013 1.3 .050 15 .59 0.35 .01 94.5 3.7 .14 1 27018 1.8 .071 15 .59 0.35 .02 94.5 3.7 .14 1 27026 2.6 .102 15 .59 0.35 .02 94.5 3.7 .14 1 *Metric dimensions actual - Inch dimensions approximate 27100 Ceramic Phillips Screwdriver, With Wiha-Precision Handle, Out of Anti-static Plastic Blade special ceramic, antimagnetic, for correct adjusting in high frequency areas. Item No. Size mm Inch mm Inch lbs. pkg. 27100 0 15.0 .59 94.5 3.7 .14 1 *Metric dimensions actual - Inch dimensions approximate 27090 Ceramic Slotted/Phillips Screwdriver 3 Pc. Set, With Wiha-Precision Handle, Out of Anti-static Plastic Blade special ceramic, antimagnetic, for correct adjusting in high frequency areas. Item No. mm mm Size mm lbs. pkg. 0.9 15 0 15 .28 1 27090 2.6 15 Toll Free: (800) 494-6104 10 Wiha SYSTEM 4 Precision Handles and Blades Tips Exact fit, precision machined Blades chrome-vanadiummolybdenum steel, hardened, hard chromed. On 4mm Hex shafts 15mm Collet Lock Handle adjustable blade length from 15 to 95mm/ .6” to 3.75” Rotating Cap for precise turning and control Precision Handle high quality plastic, ESD Safe or Standard styles 95mm Tapered Handle allows rapid rotation, requires less clearance Surface resistance of handles is 106 - 109 Ohms D 28000 ESD Safe Dissipative Precision Handle with rotating control cap. Surface resistant 106-109 Ohms. 4 mm hex retainer for all SYSTEM 4 interchangeable blades. Tapered handle, high quality plastic, impact resistant. Ball retainer hold. 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 28000 4.0 .1574 14.0 .55 .04 D 28001 ESD Safe Dissipative Precision Adjustable Handle with rotating control cap. Advantages: • Use in ESD sensitive applications. Surface resistant 106-109 Ohms. • Collet lock allows for quick & easy adjustment. • Holds blade securely in place. Accepts all SYSTEM 4 blades. 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 28001 4.0 .1574 14.0 .55 .04 269 SYSTEM 4 Slotted Reversible Blade High alloy CVM steel, hardened, hard chromed. Wiha vapor Chrome-Top finish on tips. Item No. mm mm mm Inch lbs. 26903 1.5 + 3.0 120 4.7 .05 26904 2.0 + 3.5 120 4.7 .05 26905 2.5 + 4.0 120 4.7 .06 269 SYSTEM 4 Combined Slotted/Phillips Reversible Blade High alloy CVM steel, hardened, hard chromed. Wiha vapor Chrome-Top finish on tips. Item No. mm Size mm Inch lbs. 1.5 + 000 120 4.7 .05 26971 2.0 + 00 120 4.7 .05 26972 3.0 + 0 120 4.7 .05 26973 4.0 + 1 120 4.7 .06 26974 269 SYSTEM 4 Phillips Reversible Blade High alloy CVM steel, hardened, hard chromed. Wiha vapor Chrome-Top finish on tips. Item No. Size Size mm Inch lbs. 26911 000 + 00 120 4.7 .03 26912 0 + 1 120 4.7 .03 26922 SYSTEM 4 Pozidriv® Reversible Blade High alloy CVM steel, hardened, hard chromed. Wiha vapor Chrome-Top finish on tips. Item No. Size Size mm Inch lbs. 0 + 1 120 4.7 .03 26922 269 SYS 4 Metric Ball End & Standard Hex, Reversible Blade CVM steel, hardened, hard chromed. Wiha vapor Chrome-Top finish on tips. One side hex, other side ballpoint hex. Item No. mm mm mm Inch lbs. 26932 1.27 + 1.27 120 4.7 .05 26933 1.5 + 1.5 120 4.7 .05 26934 2.0 + 2.0 120 4.7 .06 26935 2.5 + 2.5 120 4.7 .06 26936 3.0 + 3.0 120 4.7 .06 26937 4.0 + 4.0 120 4.7 .06 For angle entry 280 SYSTEM 4 Metric Ball End Hex Interchangeable Blade High alloy tool steel, hardened, corrosion protected. Ball end works at 30° angle entry for easy access to fasteners. Item No. mm mm Inch lbs. pkg. 1.5 120 4.7 .06 1 28033 2.0 120 4.7 .06 1 28034 2.5 120 4.7 .06 1 28035 3.0 120 4.7 .06 1 28036 4.0 120 4.7 .06 1 28037 For angle entry SYSTEM 4 Inch Ball End Hex 280 Interchangeable Blade High alloy tool steel, hardened, corrosion protected. Ball end works at 30° angle entry for easy access to fasteners. Item No. Inch mm Inch lbs. 28021 .050 120 4.7 .06 28023 1/16 120 4.7 .06 28024 5/64 120 4.7 .06 28025 3/32 120 4.7 .06 28026 7/64 120 4.7 .06 28027 1/8 120 4.7 .06 28028 9/64 120 4.7 .06 28029 5/32 120 4.7 .06 www.wihatools.com Wiha SYSTEM 4 Precision Blades 269 SYSTEM 4 Metric Hex Sizes, Interchangeable Blade High alloy CVM steel, hardened, corrosion protected. Item No. mm mm Inch lbs. 26913 .71 120 4.7 .06 26914 .89 120 4.7 .06 26915 1.27 120 4.7 .06 26916 1.5 120 4.7 .06 26917 2.0 120 4.7 .06 26918 2.5 120 4.7 .06 26919 3.0 120 4.7 .06 26920 4.0 120 4.7 .06 269 SYSTEM 4 Inch Hex Sizes, Interchangeable Blade High alloy chrome-vanadium-molybdenum steel, hardened, corrosion protected. Item No. Inch mm Inch lbs. .050 120 4.7 .06 26921 1/16 120 4.7 .06 26923 5/64 120 4.7 .06 26924 3/32 120 4.7 .06 26925 7/64 120 4.7 .06 26926 1/8 120 4.7 .06 26927 9/64 120 4.7 .06 26928 5/32 120 4.7 .06 26929 269 SYSTEM 4 Nut Driver Metric, Interchangeable Blade High alloy chromevanadium-molybdenum steel, hardened, corrosion protected. 120mm/4.7” OAL Item No. mm mm Inch Inch lbs. 26940 1.5 + 1.8 .12 .12 .03 26941 2.0 + 2.5 .16 .16 .03 26938 1.5 - .11 .11 .04 26939 1.8 - .12 .12 .04 26949 2.0 - .13 .13 .06 26950 2.5 - .16 .16 .06 26942 3.0 - .20 .20 .06 26943 3.2 - .20 .20 .06 26944 3.5 - .22 .24 .06 26945 4.0 - .22 .24 .06 26946 4.5 - .25 .28 .06 26947 5.0 - .27 .28 .06 26948 5.5 - .30 .32 .06 269 SYSTEM 4 Nut Driver Inch, Interchangeable Blade High alloy chromevanadium-molybdenum steel, hardened, corrosion protected. 120mm/4.7” OAL Item No. Inch Inch Inch lbs. 26962 3/32 .16 .16 .04 26963 7/64 .20 .20 .04 26964 1/8 .20 .20 .04 26965 9/64 .21 .24 .04 26966 5/32 .22 .24 .04 26967 3/16 .26 .28 .04 26968 7/32 .30 .32 .04 26969 1/4 1.34 .36 .04 269 SYSTEM 4 Reversible Blade High alloy chrome-vanadium-molybdenum steel, hardened, vapor chrome protected, Wiha vapor Chrome-Top finish on tips. 120mm/4.7” OAL. Item No. Size Size lbs. 26951 T6 + T8 .03 26952 T7 + T9 .03 26953 T10 + T15 .03 26954 T15 + T20 .03 Interchangeable 269 SYSTEM 4 Blade High alloy CVM steel, hardened, Wiha vapor Chrome-Top finish on tips. 120mm/4.7” OAL Item No. Size lbs. 26955 T3 .03 26956 T4 .03 26957 T5 .03 11 Wiha SYSTEM 4 Drive-Loc Precision Locking Tools D 26961 ESD Safe Dissipative Precision Drive-Loc Handle Surface resistant 106-109 Ohms. 4 mm hex retainer for all SYSTEM 4 interchangeable blades. Ball retainer hold. 105mm/4.13” OAL Item No. mm Inch mm Inch lbs. 26961 4.0 .1574 23 .91 .08 269 SYSTEM 4 Slotted Drive-Loc Reversible Locking Blades On 4mm Hex Item No. mm mm lbs. 26958 1.5 + 3.0 .02 26959 2.0 + 3.5 .02 26960 2.5 + 4.0 .02 269 SYSTEM 4 Phillips Drive-Loc Reversible Locking Blades On 4mm Hex Item No. Size Size lbs. 26975 000 + 00 .02 26976 0 + 1 .02 SYSTEM 4 Drive-Loc 269 Reversible Locking Blades On 4mm Hex Item No. Size Size lbs. 26977 T1 + T2 .02 26978 T3 + T4 .02 26979 T5 + T6 .02 26980 T6 + T8 .02 26981 T7 + T9 .02 26982 T10 + T15 .02 26985 12 Piece SYSTEM 4 Precision ESD Drive-Loc Set In storage pouch Item No. ESD Safe Drive-Loc Handle 26985 Slotted: 1.5x3.0, 2.0x3.5, 2.5x4.0 lbs. .44 Phillips: 000x00, 0x1 : T1xT2, T3xT4, T5xT6, T6xT8, T7xT9, T10xT15 Toll Free: (800) 494-6104 12 Wiha Canvas Pouch Sets Surface resistance of handles is 106 - 109 Ohms Canva s Pouc h D D 26990 Slotted & Phillips Precision Interchangeable Blade Set, 4 Pcs. Wiha ESD Safe precision collet lock handle and 3 Wiha interchangeable blades. 26990 Set includes the following blades: Slotted: 2.0, 3.0, 4.0mm Phillips: 00, 0, 1 lbs. .17 Canva s Pouc h D 26991 Slotted & Phillips Precision Interchangeable Blade Set, 6 Pcs. Wiha ESD Safe precision collet lock handle and 5 Wiha interchangeable blades. In canvas pouch. Set includes the following blades: 26991 Slotted: 1.5, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: 000, 00, 0, 1 lbs. .29 D 28080 Slotted, Phillips & Hex Precision Interchangeable Blade Set, 22 Pcs. Wiha ESD Safe precision collet lock handle and 20 Wiha interchangeable blades. 28080 Set includes the following blades: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex: .028, .035 Ball Hex: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” ESD Safe Chip Lifter lbs. .33 Precision Screwdrivers & Tweezers Canva s Pouc h 44590 Slotted, Phillips and Precision Interchangeable Blade Set, 12 Pcs. Wiha ESD Safe precision collet lock handle, 7 Wiha interchangeable blades & 4 ESD Safe Tweezers. 44590 Set includes the following blades: Slotted: 2.0, 3.0, 4.0mm Phillips: 00, 0, 1 : T6, T7, T8, T9, T10, T15 ESD Safe Precision Tweezers: 44501 Fine Point - AA SA 44509 Extra Fine Point - 5 SA 44505 Flat and Blunt - 2a SA 44510 Curved Fine Point - 7a SA lbs. .60 D D 28094 Slotted, Phillips & Torx Precision Interchangeable Blade Set, 11 Pcs. Wiha ESD Safe precision collet lock handle and 10 Wiha interchangeable blades. 28094 Set includes the following blades: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 lbs. 1.51 ® Canva s Pouc h Slotted & Phillips Set In Steel Box Slotted, Phillips, Torx® Set In Steel Box Surface resistance of handles is 106 - 109 Ohms s Pouc h ESD Technicians Kit Slotted, Phillips, Hex 26992 Slotted, Phillips and Ball End Hex Metric/Inch Precision Interchangeable Blade Set, 17 Pcs. Wiha ESD Safe precision collet lock handle and 15 Wiha interchangeable blades. 26992 Set include the following blades: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 Ball End Hex Inch: .050,1/16, 5/64, 7/64, 3/32,1/8” Ball End Hex Metric: 1.5, 2.0, 2.5, 3.0, 4.0mm ESD Safe Chip Lifter lbs. .63 Canva Surface resistance of handles is 106 - 109 Ohms 26993 Slotted & Phillips Precision Interchangeable Blade Set, 6 Pcs. Wiha ESD Safe precision collet lock handle and 5 Wiha interchangeable blades. 26993 Set includes the following blades: Slotted: 1.5, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: 000, 00, 0, 1 lbs. .87 D www.wihatools.com SYSTEM 4 Sets in Compact Fold-out box • ESD Safe Precision Handle Surface resistance of handles is 106 - 109 Ohms • High alloy CVM steel, hardened • Exact fit tips D D 26996 Slotted & Phillips Precision Interchangeable Blade Set, 5 Pcs. Wiha ESD Safe precision collet lock handle and 4 Wiha interchangeable blades. 26996 Set includes the following reversible blades in Slotted/Phillips sizes: Slotted: 1.5, 2.0, 3.0, 3.5mm Phillips: 000, 00, 0, 1 lbs. .24 26988 Nut Driver Inch Precision Blade Set, 9 Pcs. Wiha ESD Safe precision collet lock handle & 8 Wiha interchangeable blades. 26988 Set includes the following blades: Nut Driver Inch: 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” lbs. .39 D 26998 D 26997 Slotted, Phillips and Precision Interchangeable Blade Set, 9 Pcs. Wiha ESD Safe Precision Collet Lock handle and 8 Wiha Interchangeable blades. 26997 Set includes the following blades: Slotted: 1.5, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: 000, 00, 0, 1 : T6, T7, T8, T9, T10, T15 lbs. .34 Nut Driver Metric Precision Blade Set, 9 Pcs. Wiha ESD Safe precision collet lock handle and 8 Wiha interchangeable blades. 26998 Set includes the following blades: Nut Driver Metric: 2.0, 2.5, 3.0, 3.2, 3.5, 4.0, 4.5, 5.0, 5.5mm lbs. .40 D D 26999 Hex Metric Precision Blade Set, 9 Pcs. Wiha ESD Safe Precision Collet Lock handle and 8 Wiha interchangeable blades. Set includes the following blades: 26999 Hex Metric: .71, .89, 1.27, 1.5, 2.0, 2.5, 3.0, 4.0mm lbs. .36 26995 Precision Interchangeable Blade Set, 5 Pcs. Wiha ESD Safe precision collet lock handle & 4 interchangeable blades. 26995 Set includes the following blades: : T6, T7, T8, T9, T10, T15, T20 lbs. .24 D D 26989 Hex Inch Precision Blade Set, 9 Pcs. Wiha ESD Safe Precision Collet Lock handle and 8 Wiha interchangeable blades. 26989 Set includes the following blades: Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” lbs. .35 26987 Precision Interchangeable Blade Set, 8 Pcs. Wiha ESD Safe precision collet lock handle and 7 interchangeable blades. 26987 Set includes the following blades: Sizes on standard blades: T3, T4, T5 Sizes on reversible blades: T6, T7, T8, T9, T10, T15, T20 lbs. .33 13 Toll Free: (800) 494-6104 14 SYSTEM 4 Handles & Micro Bits Tips Exact fit, precision machined Rotating Cap for precise turning & control Tapered Handle allows rapid rotation, requires less clearance. Static Dissipative 106 - 109 ohms Bits CVM steel, hardened 750 SYSTEM 4 Slotted Bits High alloy CVM steel, hardened, on 4 mm hex stock. Item No. mm mm Inch lbs. 0.8 28 1.1 .01 75008 1.2 28 1.1 .01 75012 1.5 28 1.1 .01 75015 1.8 28 1.1 .01 75018 2.0 28 1.1 .01 75020 2.5 28 1.1 .01 75025 3.0 28 1.1 .01 75030 3.5 28 1.1 .01 75035 4.0 28 1.1 .01 75040 Use bits directly in handle or with 4” bit extension 75801 SYSTEM 4 ESD Safe Dissipative Precision Bit Handle with rotating control cap. Wiha precision handle, tapered, high quality plastic, impact resistant. Advantages: • For working in ESD sensitive applications Surface resistant 106-109 Ohms • Ball retainer holds bits securely in place • Accepts all SYSTEM 4 Series bits • 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 4.0 .1574 14.0 .55 .06 75801 75900 Extension Blade For SYSTEM 4 Micro Bits. Shaft CVM steel, hardened, corrosion protected. Ball retainer bit extension for 4 mm bits. Without magnet Item No. Size mm mm lbs. 75900 4.0 100 4.0 .07 75901 Magnetic Bit Extension Blade For SYSTEM 4 Micro Bits. Shaft CVM steel, hardened. Magnetic bit holder. Item No. Size mm mm lbs. 75901 4.0 100 4.0 .04 751 SYSTEM 4 Phillips Bits High alloy chrome-vanadium-molybdenum steel, hardened, on 4 mm hex stock. Item No. Size mm Inch lbs. 75105 000 28 1.1 .01 75110 00 28 1.1 .01 75115 0 28 1.1 .01 75120 1 28 1.1 .01 753 SYSTEM 4 Hex Metric Bits High alloy CVM steel, hardened, on 4 mm hex stock. Item No. mm mm Inch lbs. 75307 .71 28 1.1 .01 75309 .89 28 1.1 .01 75313 1.27 28 1.1 .01 75315 1.5 28 1.1 .01 75320 2.0 28 1.1 .01 75325 2.5 28 1.1 .01 75330 3.0 28 1.1 .01 75340 4.0 28 1.1 .01 753 SYSTEM 4 Hex Inch Bits High alloy CVM steel, hardened, on 4 mm hex stock. Item No. Inch mm Inch lbs. 75307 .028 28 1.1 .01 75309 .035 28 1.1 .01 75313 .050 28 1.1 .01 75350 1/16 28 1.1 .01 75352 5/64 28 1.1 .01 75354 3/32 28 1.1 .01 75356 7/64 28 1.1 .01 75358 1/8 28 1.1 .01 75360 9/64 28 1.1 .01 75340 5/32 28 1.1 .01 757 SYSTEM 4 Bits High alloy chrome-vanadium-molybdenum steel, hardened, on 4 mm stock. Item No. Size mm Inch lbs. T3 28 1.1 .01 75703 T4 28 1.1 .01 75704 T5 28 1.1 .01 75705 T6 28 1.1 .01 75706 T7 28 1.1 .01 75707 T8 28 1.1 .01 75708 T9 28 1.1 .01 75709 T10 28 1.1 .01 75710 T15 28 1.1 .01 75715 T20 28 1.1 .01 75720 753 SYSTEM 4 Metric Security Hex Bits High alloy CVM steel, hardened, on 4 mm hex stock. Item No. mm mm Inch lbs. 2.0 28 1.1 .01 75322 2.5 28 1.1 .01 75327 3.0 28 1.1 .01 75332 4.0 28 1.1 .01 75342 753 SYSTEM 4 Security Hex Inch Bits High alloy CVM steel, hardened, on 4 mm hex stock. Item No. Inch mm Inch lbs. 75362 5/64 28 1.1 .01 75364 3/32 28 1.1 .01 75366 7/64 28 1.1 .01 75368 1/8 28 1.1 .01 75370 9/64 28 1.1 .01 75372 5/32 28 1.1 .01 753 SYSTEM 4 Security Bits High alloy CVM steel, hardened, on 4 mm stock. Item No. Size mm Inch lbs. T7s 28 1.1 .01 75727 T8s 28 1.1 .01 75728 T9s 28 1.1 .01 75729 T10s 28 1.1 .01 75735 T15s 28 1.1 .01 75739 T20s 28 1.1 .01 75742 www.wihatools.com Micro Bit 1/4” Drive Power Tool Adapter 75902 SYSTEM 4 Micro Bit 1/4” Drive Power Tool Adapter Shaft CVM steel, hardened, corrosion protected. 1/4” Hex drive holds 4 mm bits. Without magnet Item No. Size mm mm lbs. 75902 1/4” 60 4.0 .05 Wiha SYS 4 Micro Bits & Compact Bit Sets 75996 SYSTEM 4 Interchangeable Bit Set, 40 Pcs. In Storage Box. Set includes Wiha precision handle, non-magnetic bit extension & 38 interchangeable bits. Item No. SYSTEM 4 Combination Micro Bit Set 75996 Set with ESD Safe Precision Handle Set includes the following bits: Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Metric: 1.27, 1.5, 2.0, 2.5, 3.0, 4.0mm 40 Hex Inch: .028, .035, .050, Pc . 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension - non-magnetic lbs. 1.04 D Surface resistance of handle is 106 - 109 Ohms 75990 40 Pc. SYSTEM 4 Interchangeable Bit Set, In Canvas Pouch Set includes Wiha precision handle, non-magnetic bit extension & 38 interchangeable bits. Item SYSTEM 4 Combination No. Micro Bit Set 75990 Set with ESD Safe Precision Handle Set includes the following bits: Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Metric: 1.27, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension - non-magnetic lbs. .65 Surface resistance of handle is 106 - 109 Ohms 75792 SYSTEM 4 Precision Interchangeable Bit Set, 11 Pcs. In Compact Fold Out Box. Set includes ESD Safe Wiha precision handle, non-magnetic bit extension and 9 Wiha interchangeable bits. Item ESD Safe SYSTEM 4 No. Micro Bit Set 75792 Set with ESD Safe Precision Handle Sets include the following bits: : T3, T4, T5, T6, T7, T8, T9, T10, T15 100mm Bit Extension - non-magnetic lbs. .26 Surface resistance of handle is 106 - 109 Ohms 15 D 11 Pc. Set 759 SYSTEM  4 Slotted/Phillips/Hex Inch/ Precision Interchangeable Bit Set, 27 Pcs. In Compact Fold Out Box. Sets include your choice of Wiha precision handle, non-magnetic bit extension and 25 Wiha interchangeable bits. Item Handle Options for SYSTEM 4 No. Combination Bit Sets 75991 Set with Standard Precision Handle 75992 Set with ESD Safe Precision Handle Sets include the following bits: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension - non-magnetic lbs. .34 Surface resistance of handle is 106 - 109 Ohms Se t D 40 Pc. Set 75994 SYSTEM 4 Slotted/Phillips/Hex Metric/ Precision Interchangeable Bit Set, 27 Pcs. In Compact Fold Out Box. Set includes Wiha ESD Safe precision handle, non-magnetic bit extension and 25 Wiha interchangeable bits. Item No. SYSTEM 4 Combination Micro Bit Set Set with ESD Safe Precision Handle 75994 Set includes the following bits: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Metric: .71, .89, 1.27, 1.5, 2.0, 2.5, 3.0, 4.0mm 100mm Bit Extension - non-magnetic lbs. .26 Surface resistance of handle is 106 - 109 Ohms D 27 P c. Se t D 27 P c. Se t Toll Free: (800) 494-6104 16 SYSTEM 4 Compact ESD Micro Bit Sets Technicians MicroBit Sets • Micro Precision Bits on 4mm Hex Drive • Bits of Exclusive CRM-72 Tool Steel • Handle uses non-magnetic ball retainer • Use bits in extension only • Standard extension adds 4” to length • Non-magnetic bit extension Light weight & compact Rotation cap Handle tapered for precise control Bits hardened for extreme durability 75093 SYSTEM 4 Slotted, Phillips, Compact ESD Precision Interchangeable Bit Set, 16 Pcs. Wiha precision handle, bit extension & 14 interchangeable bits. Item No. Combination Bit Set 75093 Set with Standard Precision Handle Set includes the following bits: Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: 00, 0, 1 : T6, T7, T8, T9, T10, T15, T20 100mm Bit Extension lbs. .17 75094 SYSTEM 4 Slotted, Phillips, Hex Inch Compact ESD Precision Interchangeable Bit Set, 16 Pcs. Wiha precision handle, bit extension & 14 interchangeable bits. Item No. Combination Bit Set Set with Standard Precision Handle 75094 Set includes the following bits: Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: 00, 0, 1 Hex Inch: .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8” 100mm Bit Extension lbs. .17 D D Surface resistance of handles is 106 - 109 Ohms 75095 SYSTEM 4 Slotted, Phillips, Hex Metric Compact ESD Precision Interchangeable Bit Set, 16 Pcs. Wiha precision handle, bit extension & 14 interchangeable bits. Item No. Combination Bit Set Set with Standard Precision Handle 75095 Set includes the following bits: Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: 00, 0, 1 Hex Metric: .89, 1.27, 1.5, 2.0, 2.5, 3.0, 4.0mm 100mm Bit Extension lbs. .17 75096 SYSTEM 4 Hex Inch & Metric Compact ESD Precision Interchangeable Bit Set, 16 Pcs. Wiha precision handle, bit extension & 14 interchangeable bits. Item No. Combination Bit Set 75096 Set with ESD Safe Precision Handle Set includes the following bits: Hex Inch: 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Hex Metric: .89, 1.27, 1.5, 2.0, 2.5, 3.0, 4.0mm 100mm Bit Extension lbs. .17 D D www.wihatools.com 17 Wiha ESD Safe SoftFinish Cushion Grip Bit Holders Dissipative material offers protection against electrostatic discharge Bit holders without magnetics For working on static sensitive components Surface resistance of handles is 106 - 109 Ohms D D 38701 ESD Safe Quick Release 1/4” Bit Holder, With WihaSoftFinish® Cushion Grip Handle, IEC 61340-5-1, DIN 3126, ISO 1173 Stainless steel with retaining ring bit holder. Dissipative SoftFinish® cushion grip handle, multi-component, ESD Safe surface resistance 106 - 109 Ohm. Item No. Inch mm Inch mm Inch lbs. pkg. 38701 1/4” 148 5.8 38 1.5 .18 1 In Durable Pouch Surface resistance of handle is 106 - 109 Ohms 38790 ESD Safe 1/4” Quick Release Blade Holder Set With Interchangeable 70mm Blades & Quick Release Blade Holder 20 Pc. set includes ESD Safe Quick Release Holder, cushion grip handle. 70mm blades are CVM tool steel, hardened. Also includes a Quick Release blade extension. Item No. 38790 Slotted: 2.5, 3.0, 3.5, 4.0, 5.5, 6.5mm Phillips: 0, 1, 2 TORX®: T6, T7, T8, T9, T10, T15 Pozidriv®: 0, 1, 2 28180 ESD Safe Stubby 1/4” Bit Holder With Ring Retainer, Cushion Grip Wiha-SoftFinish® Handle, IEC 61340-5-1, DIN 3126, ISO 1173 Dissipative SoftFinish® cushion grip handle, multicomponent, ESD Safe surface resistance 106 - 109 Ohm. Item No. Inch mm Inch lbs. pkg. 28180 1/4” 57 2.2 .11 1 Toll Free: (800) 494-6104 18 Wiha ESD Safe SoftFinish Cushion Grip Screwdrivers For working on static sensitive components Dissipative material offers protection against electrostatic discharge D D SoftFinish cushion grip handle CVM steel hardened, hard chrome Finish DIN EN 61340-5-1/ 61340-5-2 302 ESD Safe Slotted Screwdrivers, With Wiha-SoftFinish® Handle DIN EN 61340-5-1/61340-5-2 Round blade, high alloy CVM steel, hardened, hard chromed. Offers protection against electrostatic discharge. Dissipative SoftFinish® cushion grip handle, multi-component, ESD Safe (106-109 Ohm). Item No. 30240* 30242* 30244* 30246* 30248 *Cabinet mm Inch mm Inch mm Inch mm Inch lbs. pkg. 2.5 .098 75 3.0 0.4 .016 175 7.0 .06 10 3.0 .118 100 3.9 0.5 .020 204 8.0 .06 10 4.0 .157 100 3.9 0.8 .031 211 8.3 .11 10 5.5 .216 125 5.0 1.0 .039 236 9.3 .15 10 6.5 .255 150 5.9 1.2 .047 268 10.6 .22 10 Tips 311 ESD Safe Phillips Screwdriver, With Wiha-SoftFinish® Handle DIN EN 61340-5-1/61340-5-2 Round blade, high alloy CVM steel, hardened, hard chromed. Offers protection against electrostatic discharge. Dissipative SoftFinish® cushion grip handle, multi-component, ESD Safe (106-109 Ohm). Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 31150 0 60 2.4 3.0 1/8 164 6.5 .06 10 31151 1 80 3.1 4.5 3/16 191 7.5 .11 10 31152 2 100 3.9 6.0 1/4 218 8.6 .20 10 30292 Set 6 Pcs. ESD Safe Slotted & Phillips DIN EN 61340-5-1/61340-5-2 Round blade, high alloy CVM steel, hardened, hard chromed. Dissipative SoftFinish® cushion grip handle, multi-component, ESD Safe (106-109 Ohm). Item No. mm Inch mm Size mm lbs. 30292 30242* 3.0 .118 100 31150 0 60 .96 30244* 4.0 .157 100 31151 1 80 30246* 5.5 .216 125 31152 2 100 *Cabinet Tips 362 ESD Safe Screwdriver, With Wiha-SoftFinish® Handle DIN EN 61340-5-1/61340-5-2 Round blade, high alloy CVM steel, hardened, hard chromed. Offers protection against electrostatic discharge. Dissipative SoftFinish® cushion grip handle, multicomponent, ESD Safe (106-109 Ohm). Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 36260 T3 60 2.4 3.5 .139 164 6.5 .06 10 36204 T4 60 2.4 3.5 .139 164 6.5 .06 10 36200 T5 60 2.4 3.5 .139 164 6.5 .06 10 36206 T6 60 2.4 3.5 .139 164 6.5 .06 10 36208 T8 60 2.4 3.5 .139 164 6.5 .06 10 36209 T9 60 2.4 4.0 .157 171 6.7 .10 10 36218 T10 80 3.1 4.0 .157 191 7.5 .11 10 36219 T15 80 3.1 4.0 .157 191 7.5 .11 10 36224 T20 100 3.9 4.0 .157 211 8.3 .11 10 D 36289 Set 6 Pcs. ESD Safe Screwdrivers Round blade high alloy chrome-vanadium-molybdenum steel, hardened, Hard chrome finish with Wiha-Chromtop satin grip tips. Molded on SoftFinish® cushion grip handle, multi-component. Item No. Size mm Size mm lbs. 36289 36206 T6 60 36218 T10 80 .81 36208 T8 60 36219 T15 80 36209 T9 60 36224 T20 100 www.wihatools.com Wiha ESD Safe Interchangeable Sets D Surface resistance of handle is 106 - 109 Ohms In Durable Pouch 10891 ESD Safe Slotted & Phillips Interchangeable Blade Set 4 Pc. Set Includes ESD Safe handle & 3 interchangeable blades. Item No. 10891 lbs. .65 Slotted: 3.0, 4.0, 6.0mm Phillips: 0, 1, 2 D Won’t damage sensitive parts Non-metallic high-tech material with 60% fiber glass content, extremely high rigidity. Thermal stability of the measuring surfaces: Short-term up to 180OC, continuous 100-120OC Precision ratchet guarantees uniform clamping force of the measuring jaw Inside Non-corrosive, non-magnetic, hardly conductive and electrically insulated Outside Surface resistance of handle is 106 - 109 Ohms Made in Switzerland Depth In Durable Pouch 10892 ESD Safe Metric Nut Drivers Interchangeable Blade Set 8 Pc. Set Includes ESD Safe handle & 7 interchangeable blades. Item No. 10892 lbs. .75 Metric Nut Drivers: 5.0, 5.5, 6.0, 7.0, 8.0, 9.0, 10.0mm In Durable Pouch 10893 ESD Safe TORX® Interchangeable Blade Set 5 Pc. Set Includes ESD Safe handle & 4 interchangeable blades. Item No. 10893 lbs. .70 TORX®: T6, T7, T8, T9, T10, T15, T20, T25 Step Surface resistance of handle is 106 - 109 Ohms ESD Safe Dial Caliper DialMax - Metric/Inch For working in sensitive electronic components Surface resistance of handle is 106 - 109 Ohms D D 19 Conductive, Anti-static, Dissipative D ESD Standard IEC 61340-5-1 411 ESD Safe Dial Caliper DialMax - Metric & Inch Non-metallic high-tech material with 60% fiber glass content. For outside, inside, depth and step measurements. Impact resistant dial can be recalibrated to zero. Item No. 41105 41106 Reading mm Inch .001” 150 6 Inch 0.1mm 150 6 Metric Pkg. wt. 1 .10 1 .10 Surface resistance of handle is 106 - 109 Ohms D In Durable Pouch 10895 ESD Safe Interchangeable Combo Blade Set 11 Pc. Set Includes ESD Safe handle & 10 interchangeable blades. Item No. 10895 lbs. .75 Slotted: 3.0, 4.0, 6.0mm Phillips: 0, 1, 2 Inch Nut Drivers: 3/16, 1/4, 5/16, 11/32, 3/8, 7/16, 1/2” 10820 ESD Safe Dissipative Dynamic Handle, Conductive, High Quality Plastic, Impact Resistant. Advantages: • Accepts all Drive-Loc VI blades • Surface resistant 106 to 109 ohms • Safe for working on ESD sensitive parts • Collet lock holds blade securely in place Item No. mm mm Inch mm Inch lbs. 10820 6.0 135 5.3 15.2 .60 .16 Toll Free: (800) 494-6104 20 Wiha Drive-Loc VI Handle & Blades Locking mechanism in SoftFinish cushion grip handle Drive-Loc mechanism guarantees a secure hold & rapid blade exchange Adjust interchangeable blades from 40 to 120mm (1.7 to 4.7”) Surface resistance of handle is 106 - 109 Ohms D 28486 ESD Safe Drive-Loc VI Cushion Grip Handle Wiha-SoftFinish® impact resistant, with roll off protection. Advantages: Ergonomic cushion grip, Drive-Loc mechanism guarantees a secure hold and rapid blade exchange. Static Dissipative. Item No. mm mm Inch mm Inch lbs. 28486 6.0 115 4.5 36.0 1.41 .21 Wiha Drive-Loc VI Blades 281 Slotted Drive-Loc VI Interchangeable Blade High alloy CVM steel, through hardened, hard chrome finish. Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. mm + mm lbs. pkg. 28106 3.5 4.5 .10 1 28108 5.5 6.5 .10 1 281 Slotted & Phillips Drive-Loc VI Interchangeable Blade High alloy CVM steel, through hardened, hard chrome finish. Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. mm + Size lbs. pkg. 28107 3.0 0 .10 1 28109 4.0 1 .10 1 28110 6.0 2 .10 1 28112 Phillips Drive-Loc VI Interchangeable Blade High alloy CVM steel, through hardened, hard chrome finish. Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. Size + Size lbs. pkg. 1 2 .10 1 28112 28114 Pozidriv® Drive-Loc VI Interchangeable Blade High alloy CVM steel, through hardened, hard chrome finish. Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. Size + Size lbs. pkg. 1 2 .10 1 28114 281 Drive-Loc VI Interchangeable Blade High alloy CVM steel, through hardened, hard chrome finish. Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. Size + Size lbs. pkg. 28126 T6 T8 .10 1 28127 T7 T9 .10 1 28128 T10 T15 .10 1 28129 T20 T25 .10 1 28130 T30 T40 .10 1 281 Security Drive-Loc VI Interchangeable Blade, high alloy CVM steel, through hardened, hard chrome finish. Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. Size + Size lbs. pkg. 28132 T6s T8s .10 1 28133 T7s T9s .10 1 28134 T10s T15s .10 1 28135 T20s T25s .10 1 28136 T30s T40s .10 1 281 Tri-Wing® Drive-Loc VI Interchangeable Blade High alloy CVM steel, through hardened, hard chrome finish. Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. Size + Size lbs. pkg. 28138 0 1 .10 1 28139 2 3 .10 1 28140 4 5 .10 1 281 Torq Set® Drive-Loc VI Interchangeable Blade High alloy CVM steel, through hardened, hard chrome finish. Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. Size + Size lbs. pkg. 2 4 .08 1 28142 6 8 .10 1 28143 www.wihatools.com Wiha Drive-Loc VI Blades 281 Ball End Hex & Hex Metric Drive-Loc VI Interchangeable Blade High alloy CVM steel, through hardened, hard chrome finish. Ball end enables the user to work at angles up to 25O. Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. mm + mm lbs. pkg. 28116 2.5 2.5 .10 1 28117 3 3 .10 1 28118 4 4 .10 1 28119 5 5 .10 1 28120 6 6 .10 1 281 Hex Metric Drive-Loc VI Interchangeable Blade High alloy CVM steel, through hardened, hard chrome finish. Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. mm + mm lbs. pkg. 28149 2.0 2.5 .09 1 28150 3.0 4.0 .10 1 28151 5.0 6.0 .10 1 281 Drive-Loc VI Inch Nut Driver Blades High alloy CVM steel, through hardened, hard chrome finish. OAL blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. Inch mm lbs. pkg. 28156 3/16 150 .11 1 28157 7/32 150 .11 1 28158 1/4 150 .11 1 28159 9/32 150 .12 1 28160 5/16 150 .13 1 28161 11/32 150 .14 1 28162 3/8 150 .15 1 28163 7/16 150 .17 1 28164 1/2 150 .18 1 281 Hex Inch Drive-Loc VI Interchangeable Blade High alloy CVM steel, through hardened, hard chrome finish. Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. Inch + Inch lbs. pkg. 3/32 7/64 .10 1 28122 1/8 9/64 .10 1 28123 5/32 3/16 .10 1 28124 281 Drive-Loc VI Metric Nut Driver Blades High alloy CVM steel, through hardened, hard chrome finish. OAL blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. mm mm lbs. pkg. 4.0 150 .10 1 28168 4.5 150 .10 1 28169 5.0 150 .11 1 28170 5.5 150 .11 1 28171 6.0 150 .12 1 28172 7.0 150 .13 1 28173 8.0 150 .13 1 28174 28177 9.0 150 .14 1 10.0 150 .15 1 28175 11.0 150 .20 1 28176 28137 Square Drive-Loc VI Interchangeable Blade High alloy CVM steel, through hardened, hard chrome finish. Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. Size + Size lbs. pkg. 1 2 .10 1 28137 28144 Extension Blade For Drive-Loc VI Blades High alloy CVM steel, through hardened, hard chrome finish. OAL blade length 6.5”. Blades fit all Drive-Loc VI handles. Item No. mm OAL lbs. pkg. 28144 6.0 165mm .14 1 21 22 Toll Free: (800) 494-6104 ESD Safe Adjustable TorqueControl Tools D 288 ESD Safe Slotted Interchangeable Blades For TorqueVario-S Slotted tip blades on narrow 5/32 Hex shafts. High alloy chromevanadium-molybdenum steel, hardened, satin hard chrome finish. D Includes Certificate 285 ESD Safe TorqueVario-S, With Window Scale EN ISO 6798, BS EN 26789, ASME B107.14M, +/- 6% Accuracy Ergonomic multi-component handle, light and compact. Handle sizes proportioned to optimize torque range. Audible and perceptible click when torque setting has been attained. With Certificate of accuracy. Item Range No. Inch lbs. Increments mm lbs. pkg. Repeatable 28522* +/- 10% 15 - 80(in/oz) 2.5 Inch oz 122 - 127 .33 1 28524 5 - 10 .2 Inch lbs 122 - 127 .34 1 +/- 6% 28526 7.5 - 20 .5 Inch lbs 126 - 131 .42 1 +/- 6% Surface resistance of handles is 106 - 109 Ohms Each TorqueVario handle has unique serial number and certificate of calibration Item Max. Torque No. mm Inch mm lbs. Nm 28801 1.5 .059 175 .07 0.15 28803 2.0 .078 175 .07 0.4 28805 3.0 .118 175 .07 0.6 28807 3.5 .139 175 .07 1.1 28809 4.0 .157 175 .07 2.5 pkg. 1 1 1 1 1 D 288 ESD Safe Phillips Interchangeable Blades For TorqueVario-S Phillips tip blades on narrow 5/32 Hex shafts. High alloy chromevanadium-molybdenum steel, hardened, satin hard chrome finish. Item Max. Torque No. Size mm mm lbs. Nm pkg. 28810 000 175 4.0 .07 0.4 1 28812 00 175 4.0 .07 0.4 1 28814 0 175 4.0 .07 0.9 1 28816 1 175 4.0 .07 3.8 1 D 288 With Certificate of Calibration +/- 6% D 28591 Set 24 Pcs. ESD Safe Adjustable TorqueVario-S Bit Set Certified to EN ISO 6798, BS EN 26789, ASME B107.14M. Set includes ergonomic multi-component adjustable TorqueVario-S handle, 21 Micro Bits, non-magnetic Micro Bit holder and Torque adjustment tool, packed in a compact durable storage box. Item No. 28591 Slotted: 1.5, 2.0, 3.0, 4.0mm lbs. Phillips: #00, #0, #1 1.31 : T6, T7, T8, T9, T10, T15 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 28524 Handle ESD Safe Range 5 - 10 Inch lbs. ESD Safe Interchangeable Blades For TorqueVario-S tip blades on narrow 5/32 Hex shafts. High alloy chromevanadium-molybdenum steel, hardened, hard chromed. Item Max. Torque No. Size mm mm lbs. Nm pkg. 28825 T5 175 4.0 .07 0.4 1 28826 T6 175 4.0 .07 0.6 1 28827 T7 175 4.0 .07 0.9 1 28828 T8 175 4.0 .07 1.3 1 28829 T9 175 4.0 .07 2.5 1 28830 T10 175 4.0 .07 3.8 1 Surface resistance of handle is 106 - 109 Ohms With Certificate of Calibration +/- 10% Surface resistance of handle is 106 - 109 Ohms 28592 Set 24 Pcs. ESD Safe Adjustable TorqueVario-S Bit Set Certified to EN ISO 6798, BS EN 26789, ASME B107.14M. Set includes ergonomic multi-component adjustable TorqueVario-S handle, 21 Micro Bits, non-magnetic Micro Bit holder and Torque adjustment tool, packed in a compact durable storage box. Item No. 28592 Slotted: 1.5, 2.0, 3.0, 4.0mm lbs. Phillips: #00, #0, #1 1.31 : T6, T7, T8, T9, T10, T15 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 28526 Handle ESD Safe Range 7.5 - 20 Inch lbs. Surface resistance of handle is 106 - 109 Ohms D 28890 Set 24 Piece TorqueVario-S ESD Safe Micro-Bit Set Certified to EN ISO 6798, BS EN 26789, ASME B107.14M. Set includes ergonomic multi-component adjustable TorqueVario-S handle, 21 Micro Bits, non-magnetic Micro Bit holder and Torque adjustment tool. Packed in a compact durable storage box. Item No. 28890 Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: #00, #0, #1 lbs. : T6, T7, T8, T9, T10, T15 1.33 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 28522 ESD Safe Handle Range 15-80 Inch/oz. www.wihatools.com Wiha ESD Safe Pliers & Cutters 23 Surface resistance of handles is 106 - 109 Ohms Two component handle with non-slip soft grip surface, protects the hand and reduces manual effort & user fatigue Box joint for longer tool life & endurance, mirror polished finish ESD standard IEC 61340-5-1 Beveled Cutter Semi-Flush Cutter Welded double leaf spring Flush Cutter Ultra Full Flush Hardened & annealed high carbon tool steel, induction hardened cutting edges Precision Cutters Tapered Head Semi Flush 32703 Precision Cutters, Small Tapered Head, Semi Flush Cutters drop-forged for an ideal material structure. Precise aligned 9.5mm cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 7.5mm 32703 D 115mm Precision Cutters Tapered Head Flush Semi Flush D 115mm Precision Cutters Tapered Head 115mm Precision Cutters Tapered Head Flush 115mm Head Wdth 9.5mm Pkg. 1 wt. .19 mm Inch Copper Head Wdth 115 4.5 1.0 9.5mm Pkg. 1 wt. .19 32702 Precision Cutters, Small Tapered Head With Hollow Ground Back, Semi Flush 9.5mm Cutters drop-forged for an ideal material structure. Precise aligned cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 7.5mm 32702 mm Inch Copper Head Wdth Pkg. wt. 115 4.5 1.0 9.5mm 1 .19 32704 Precision Cutters, Small Tapered Head With Hollow Ground Back, Flush 9.5mm Cutters drop-forged for an ideal material structure. Precise aligned cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 6.0mm D mm Inch Copper 115 4.5 1.0 32705 Precision Cutters, Small Tapered Head, Flush Cutters drop-forged for an ideal material structure. Precise aligned 9.5mm cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 6.0mm 32705 D D 32704 mm Inch Copper 115 4.5 1.0 Head Wdth 9.5mm Pkg. wt. 1 .19 Toll Free: (800) 494-6104 24 Wiha ESD Safe Pliers & Cutters Precision Cutters Wide Tapered Head Bevel D 115mm Precision Cutters Wide Tapered Head Flush D 115mm Precision Cutters Wide Tapered Head Full Flush D 32706 Precision Cutters, Wide Tapered Head, Bevel Cutters drop-forged for an ideal material structure. Precise aligned 11.5mm cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 7.5mm 32706 mm Inch Copper Head Wdth Pkg. wt. 115 4.5 1.4 11.0mm 1 .20 Surface resistance of handles is 106 - 109 Ohms 32708 Precision Cutters, Wide Tapered Head, Flush Cutters drop-forged for an ideal material structure. Precise aligned 11.0mm cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 mm Inch Copper Head Wdth Pkg. wt. 7.5mm 32708 115 4.5 1.2 11.0mm 1 .19 Surface resistance of handles is 106 - 109 Ohms 32710 Precision Cutters, Wide Tapered Head, Full Flush Cutters drop-forged for an ideal material structure. Precise aligned 11.0mm cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 mm Inch Copper Head Wdth Pkg. wt. 7.5mm 32710 115 4.5 1.0 11.0mm 1 .23 115mm Surface resistance of handles is 106 - 109 Ohms Precision Cutters Wide Tapered Head Flush 11.5mm 7.5mm D 115mm Precision Cutters Slim Oval Form Flush D 115mm (10.8mm) w/wire 32711 Precision Cutters, Wide Tapered Head With Wire Trapping Device, Flush Cutters drop-forged for an ideal material structure. Precise aligned cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 32711 mm Inch Copper Head Wdth Pkg. wt. 115 4.5 1.2 11.0mm 1 .19 Surface resistance of handles is 106 - 109 Ohms 32712 Precision Cutters, Slim Oval Head, Flush Cutters drop-forged for an ideal material structure. Precise aligned 10.5mm cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 mm Inch Copper Head Wdth Pkg. wt. 32712 7.5mm 115 4.5 1.0 10.5mm 1 .23 Surface resistance of handles is 106 - 109 Ohms www.wihatools.com Wiha ESD Safe Pliers & Cutters Precision Cutters Slim Oval Form Full Flush D 115mm Precision Cutters Slim Oval Form Bevel D 115mm Precision Cutters Wide Oval Form And Carbide Edge Bevel 32714 Precision Cutters, Slim Oval Head, Full Flush Cutters drop-forged for an ideal material structure. Precise aligned 9.5mm cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 mm Inch Copper Head Wdth Pkg. wt. 6.0mm 32714 115 4.5 1.0 10.0mm 1 .23 Surface resistance of handles is 106 - 109 Ohms 32716 Precision Cutters, Wide Oval Head, Bevel Cutters drop-forged for an ideal material structure. Precise aligned 11.5mm cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 mm Inch Copper Head Wdth Pkg. wt. 7.5mm 32716 115 4.5 1.4 11.0mm 1 .19 Surface resistance of handles is 106 - 109 Ohms 32718 Precision Cutters, Wide Oval Head Carbide Cutting Edges, Bevel 11.0mm Cutters drop-forged for an ideal material structure. Precise aligned carbide cutting edge. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 32718 mm Inch Copper Head Wdth Pkg. wt. 7.5mm 110 4 3/8 1.6 11.0mm 1 .20 Surface resistance of handles is 106 - 109 Ohms D 110mm Precision Cutters Wide Oval Form Flush D 115mm Precision Cutters Wide Oval Form Flush D 115mm 32720 Precision Cutters, Wide Oval Head, Flush Cutters drop-forged for an ideal material structure. Precise aligned 11.5mm cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 32720 mm Inch Copper Head Wdth Pkg. wt. 7.5mm 115 4.5 1.2 11.0mm 1 .19 Surface resistance of handles is 106 - 109 Ohms 32721 Precision Cutters, Wide Oval Head With Wire Trapping Device, Flush 11.0mm Cutters drop-forged for an ideal material structure. Precise aligned cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, 7.5mm ESD Safe Dissipative. ESD standard IEC 61340-5-1 32721 mm Inch Copper Head Wdth Pkg. wt. 115 4.5 1.2 11.0mm 1 .23 Surface resistance of handles is 106 - 109 Ohms 25 Toll Free: (800) 494-6104 26 Wiha ESD Safe Pliers & Cutters Oblique Angled Cutters Flush D 115mm Oblique Angled Cutters Ultra Full Flush D 115mm Oblique Angled Cutters Semi Flush D 115mm Oblique Front Cutters Flush D 130mm ESD Safe Tool Set In Canvas Pouch D 32722 Oblique Angled Cutters, 29O, Flush Oblique Cutters drop-forged for an ideal material structure. Precise 12.0mm aligned cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 mm Inch Copper Head Wdth Pkg. wt. 7.5mm 32722 115 4.5 1.2 12.0mm 1 .24 Surface resistance of handles is 106 - 109 Ohms 32724 Oblique Angled Cutters, 29O, Full Flush Oblique Cutters drop-forged for an ideal material structure. Precise 12.0mm aligned cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 mm Inch Copper Head Wdth Pkg. wt. 7.5mm 32724 115 4.5 1.0 12.0mm 1 .24 Surface resistance of handles is 106 - 109 Ohms 32726 Oblique Angled Cutters, 29O, Short Head, Semi Flush 12.0mm Oblique Cutters drop-forged for an ideal material structure. Precise aligned cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 7.5mm 32726 mm Inch Copper Head Wdth Pkg. wt. 115 4.5 1.2 12.0mm 1 .24 Surface resistance of handles is 106 - 109 Ohms 32728 Oblique Front Cutters, Very Small Head, 40O, Flush Oblique Cutters drop-forged for an ideal material structure. Precise 9.7mm aligned cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 32728 mm Inch Copper Head Wdth Pkg. wt. 6.2mm 130 5.1 0.6 8.5mm 1 .21 Surface resistance of handles is 106 - 109 Ohms 32793 11 Pc. Set, 4 ESD Safe Pliers, Slotted & Phillips Screwdrivers Pliers drop-forged for an ideal material structure. Two component non-slip soft grip handle. ESD standard IEC 61340-5-1 32793 11 piece ESD Safe Pliers & Slotted/Phillips Precision Drivers Set in custom case includes: ESD Safe Pliers & Cutters 4.5” Tapered Flush Cutters 4.5” Snipe Nose Pliers 4.375” Oblique Cutters 5.7” Long Nose Pliers ESD Safe Precision Screwdrivers Slotted 2.0 x 40mm Phillips #00 x 40mm Slotted 2.5 x 50mm Phillips #0 x 50mm Slotted 3.0 x 50mm Phillips #1 x 60mm Slotted 3.5 x 60mm lbs. 2.43 Surface resistance of handles is 106 - 109 Ohms www.wihatools.com 27 Wiha ESD Safe Pliers & Cutters End Cutters Extra Slim Semi Flush Tip Width 7.0mm 2.9mm 130mm D Surface resistance of handles is 106 - 109 Ohms End Cutters Wide Head Flush 16.5mm 115mm D ESD Safe Pliers Short Snipe Nose D 120mm ESD Safe Pliers Bent Snipe Nose 45 O D 120mm ESD Safe Pliers Long Needle Nose D 145mm 6.0mm 32732 End Cutters, Extra Slim, Semi Flush End Cutters drop-forged for an ideal material structure. Precise aligned cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 32732 mm Inch Copper Tip Wdth Pkg. wt. 130 5.1 0.6 4.1mm 1 .16 32734 End Cutters, Wide Head, Flush End Cutters drop-forged for an ideal material structure. Precise aligned 11.5mm cutting edges are additionally induction hardened at a hardness of Approx. 64OHRC. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 7.5mm 32734 mm Inch Copper Head Wdth Pkg. wt. 115 4.5 1.4 11.0mm 1 .18 Surface resistance of handles is 106 - 109 Ohms 32742 ESD Safe Pliers, Short Snipe Nose (Chain Nose) Straight, Serrated Jaws 9.5mm Pliers drop-forged for an ideal material structure. Precisely aligned, jaws, hardened. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 mm Inch Head Wdth Pkg. wt. 6.5mm 32742 120 4 3/4 9.5mm 1 .20 Surface resistance of handles is 106 - 109 Ohms 32744 ESD Safe Pliers, Snipe Nose (Chain Nose) Bent 45O, Smooth Jaws 9.5mm Pliers drop-forged for an ideal material structure. Precisely aligned, jaws, hardened. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 32744 mm Inch Head Wdth Pkg. wt. 6.5mm 120 4 3/4 9.5mm 1 .20 Surface resistance of handles is 106 - 109 Ohms 32746 ESD Safe Pliers, Long Needle Nose Pliers, Straight, Serrated Jaws 12.0mm Pliers drop-forged for an ideal material structure. Precisely aligned, jaws, hardened. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 mm Inch Head Wdth Pkg. wt. 7.5mm 32746 145 5 3/4 12.0mm 1 .27 Surface resistance of handles is 106 - 109 Ohms Toll Free: (800) 494-6104 28 Wiha ESD Safe Pliers & Cutters ESD Safe Pliers Needle Nose, Bent 90O 32748 ESD Safe Pliers, Needle Nose Pliers, Bent 90O, Smooth Jaws Pliers drop-forged for an ideal material structure. Precisely aligned, 12.0mm jaws, hardened. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 7.5mm D Short Round Nose Pliers 120mm ESD Safe Pliers Short Flat Nose Pliers Inch 5 3/4 Head Wdth 12.0mm Pkg. wt. 1 .21 32750 ESD Safe Pliers, Short Round Nose Pliers, Smooth Jaws Pliers drop-forged for an ideal material structure. Precisely aligned, 9.5mm jaws, hardened. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 6.5mm D mm 145 Surface resistance of handles is 106 - 109 Ohms 145mm ESD Safe Pliers 32748 32750 mm 120 Inch 4 3/4 Head Wdth 9.5mm Pkg. 1 wt. .17 Surface resistance of handles is 106 - 109 Ohms 32752 ESD Safe Pliers, Short Flat Nose Pliers, Smooth Jaws 9.5mm Pliers drop-forged for an ideal material structure. Precisely aligned, jaws, hardened. Two component non-slip soft grip handle, ESD Safe Dissipative. ESD standard IEC 61340-5-1 6.5mm 32752 120mm D ESD standard IEC 61340-5-1 mm Inch Head Wdth Pkg. wt. 120 4 3/4 9.5mm 1 .16 Surface resistance of handles is 106 - 109 Ohms Surface resistance of handles is 106 - 109 Ohms D ESD standard IEC 61340-5-1 D 32790 4 Piece ESD Safe Pliers Set In Custom Case Pliers drop-forged for an ideal material structure. Two component non-slip soft grip handle. ESD Safe Dissipative. 32790 4 piece ESD Safe Pliers Set Includes: 4.5” Wide Oval Side Cutters 5.75” Long Nose Pliers 4.75” Flat Nose Pliers 4.375” Oblique Front Cutters lbs. 2.06 Surface resistance of handles is 106 - 109 Ohms 32791 11 Pc. Set, 4 ESD Safe Pliers, SYSTEM 4 Slotted & Phillips 5 Pc. Set & 2 ESD Safe Tweezers Pliers drop-forged for an ideal material structure. Two component non-slip soft grip handle. ESD Safe Precision handle & 4 CVM tool steel blades. Tweezers anti-static conductive, ESD Safe Hypo allergenic, anti-magnetic stainless. 11 piece ESD Safe Pliers, Tweezers & SYS 4 precision 32791 Set in custom case includes: ESD Safe Pliers & Cutters 4.5” Wide Oval Side Cutters 5.75” Long Nose Pliers 4.75” Flat Nose Pliers 4.375” Oblique Front Cutters SYSTEM 4 Set in separate pouch ESD Safe Conductive Precision Handle Slotted: 1.5, 2.0, 3.0 & 4.0 Phillips: 000, 00, 0 & 1 ESD Safe Tweezers: 44501 AA SA ESD & 44510 7a SA ESD lbs. 2.43 www.wihatools.com n r u t pro 29 Wiha ESD Safe Proturn Pliers & Cutters Tested ESD Safe handle with non-slip soft grip surface, protects the hand and reduces manual effort & user fatigue Glare free black finish Hardened steel return spring Surface resistance of handles is 106 - 109 Ohms ESD Safe Wire Stripper A pro turn B D ESD Safe Long Nose Pliers pro turn C 160mm ESD Safe Flat Nose Pliers B pro turn 45812 Proturn ESD Safe Flat Nose Pliers ESD standard IEC 61340-5-1. C70 special tool steel. Glare free, black finish. ESD Safe handle with non-slip grips. 45812 A C 160mm 45810 Proturn ESD Safe Wire Stripper ESD standard IEC 61340-5-1. C70 special tool steel. Glare free, black finish. ESD Safe handle with non-slip grips. Strips 0.2, 0.3, 0.4, 0.5, 0.6, 0.8mm 45810 mm Inch Strips AWG A B C Pkg. wt. 165 6.5 30 to 20 30mm 12mm 4mm 1 .25 45811 Proturn ESD Safe Long Nose Pliers ESD standard IEC 61340-5-1. C70 special tool steel. Glare free, black finish. ESD Safe handle with non-slip grips. 45811 mm Inch A B C Pkg. wt. 160 6.3 2mm 30mm 3mm 1 .18 B A D D C 165mm D ESD standard IEC 61340-5-1 mm Inch A B C Pkg. wt. 160 6.3 2mm 32mm 3mm 1 .18 Toll Free: (800) 494-6104 30 Wiha ESD Safe Proturn Pliers & Cutters Surface resistance of handles is 106 - 109 Ohms Proturn available Spring 2010 ESD Safe Bent Nose Pliers 45813 Proturn ESD Safe Bent Nose Pliers ESD standard IEC 61340-5-1. C70 special tool steel. Glare free, black finish. ESD Safe handle with non-slip grips. 45813 mm Inch A B C Pkg. wt. 152 6.0 2mm 30mm 4mm 1 .18 B pro turn D A C 152mm ESD Safe Round Nose Pliers 45814 Proturn ESD Safe Round Nose Pliers ESD standard IEC 61340-5-1. C70 special tool steel. Glare free, black finish. ESD Safe handle with non-slip grips. B pro turn 45814 D A mm Inch A B C Pkg. 152 6.0 2mm 22mm 3mm 1 wt. .17 C 152mm A ESD Safe Diagonal Cutter pro turn D B 21° Angle C 127mm ESD Safe Diagonal Cutter pro turn D 45820 Proturn ESD Safe 21° Precision Cutters/Flush Cut ESD standard IEC 61340-5-1. C70 special tool steel. Glare free, black finish. ESD Safe handle with non-slip grips. 45820 mm Inch AWG A B C Pkg. wt. 127 5.0 18/1mm 13mm 12mm 3mm 1 .16 A B 45° Angle 45821 Proturn ESD Safe 45° Precision Cutters/Flush Cut ESD standard IEC 61340-5-1. C70 special tool steel. Glare free, black finish. ESD Safe handle with non-slip grips. 45821 mm Inch AWG A B C Pkg. wt. 127 5.0 18/1mm 10mm 9mm 2mm 1 .14 C 127mm ESD Safe Diagonal Cutter pro turn D 140mm A B 21° Angle 45822 Proturn ESD Safe 21° Precision Cutters/Flush Cut ESD standard IEC 61340-5-1. C70 special tool steel. Glare free, black finish. ESD Safe handle with non-slip grips. 45822 C mm Inch AWG A B C Pkg. wt. 140 5.5 16/1.3mm 13mm 12mm 3mm 1 .15 www.wihatools.com 31 Wiha ESD Safe Proturn Pliers & Cutters Surface resistance of handles is 106 - 109 Ohms Proturn available Spring 2010 ESD Safe Diagonal Cutter pro turn D 21° Angle 45823 ESD Safe Diagonal Cutter A 45824 Proturn ESD Safe 45° Precision Cutters/Flush Cut ESD standard IEC 61340-5-1. C70 special tool steel. Glare free, black finish. ESD Safe handle with non-slip grips. B pro turn 45824 45° Angle 140mm mm Inch AWG A B C Pkg. wt. 133 5.25 14/1.6mm 10mm 10mm 2mm 1 .14 C 133mm D 45823 Proturn ESD Safe 21° Precision Cutters/Flush Cut ESD standard IEC 61340-5-1. C70 special tool steel. Glare free, black finish. ESD Safe handle with non-slip grips. A B mm Inch AWG A B C Pkg. wt. 140 5.5 14/1.6mm 13mm 12mm 2.5mm 1 .16 C pro turn Surface resistance of handles is 106 - 109 Ohms D ESD standard IEC 61340-5-1 45890 26 Pc. Set, Proturn ESD Safe Pliers, Precision Slotted & Phillips Screwdrivers, Precision Micro Bit Set & ESD Safe Tweezers ESD Proturn Pliers glare free, black finish, ESD Safe non-slip soft grips. ESD Safe Precision Slotted & Phillips screwdrivers, CVM tool steel blades. Precision ESD Safe Micro Bit handle holds Micro Bit extension and 4mm Micro bits. Anti-static Tweezer conductive, ESD Safe Hypo allergenic, anti-magnetic stainless. 45890 26 Piece ESD Safe Pliers, Precision Screwdrivers, Micro Bit Set & ESD Tweezer In Custom Case Includes: ESD Safe Proturn Strippers, Pliers & Cutters 45810 6.5” Wire Stripper 45811 6.3” Long Nose Pliers 45813 6.0” Bent Nose Pliers 45823 5.25” 21° Precision Cutters ESD Safe Slotted & Phillips Precision Screwdrivers Slotted: 2.0, 2.5, 3.0mm Phillips: 0, 1 ESD Micro Bit Handle, Micro Bit Extension & 14 Micro Bits 4mm Hex: .71, .89, 1.27, 1.5, 2.0, 2.5, 3.0 Torx: T4, T5, T6, T7, T8, T9, T10 ESD Safe Tweezer: 44532 00 SA ESD - 120mm Heavy Duty Strong, Tapered To Strong Point. lbs. 2.05 32 Toll Free: (800) 494-6104 Professional Quality ESD Tweezers D ESD SAFE • STATIC DISSIPATIVE • HYPO ALLERGENIC COATED • TEXTURED GRIPPING SURFACE Surface resistance is 106 - 109 Ohms Fine Round Points For Assembly Universal Fine Point Tweezers Item No. Description wt. AA SA ESD - 130mm .09 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44501 Item No. Description wt. 44506 3 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Fine Round Points Shorter Sturdy Long, Fine Round Points Item No. Description wt. GG SA ESD - 130mm .09 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44502 Long Narrow Body Low Force Item No. Description wt. SS SA ESD - 135mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44503 Reduced Body To Medium Point Item No. Description wt. 2 SA ESD - 120mm .08 44504 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Flat Round Tip Smooth Sides Item No. Description wt. 2a SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44505 Item No. Description wt. 3c SA ESD - 110mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44507 Very Fine Points/Tapered To Tip Item No. Description wt. 4 SA ESD - 110mm .08 44508 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Extra Fine Points/Tapered To Tip Item No. Description wt. 5 SA ESD - 110mm .08 44509 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Curved Extra Fine Rounded Tips Item No. Description wt. 7a SA ESD - 120mm .08 44510 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. www.wihatools.com 33 Wiha Professional Quality ESD Safe Tweezers Surface resistance is 106 - 109 Ohms Holds 0.8 to 2mm Diameter Item No. Description wt. 50 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44511 Narrow Rounded Tip Serrated, Guide Pin Item No. Description wt. 22 SA ESD - 150mm .10 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44518 Universal Blunt Tip Serrated Holds 1.5 to 3mm Diameter Item No. Description wt. 51 SA ESD - 130mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44512 Item No. Description wt. 40 SA ESD - 145mm .11 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44520 MicroTip 45O Hook 1x1x2mm Holds 3.5 to 7mm Diameter Item No. Description wt. 52 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44513 Holds 6.5 to 10mm Diameter Item No. Description wt. 53 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44514 Angled 3.5 to 7mm Diameter Item No. Description wt. 54 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44515 D Item No. Description wt. 12 SA-SMD ESD - 120mm .09 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44521 MicroTip For Chips Angled 1.6 x 1 x 1mm Item No. Description wt. 13 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44522 Long Rounded to 1.0mm Wide No Serration Item No. Description wt. PSF SA ESD - 125mm .09 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44523 34 Toll Free: (800) 494-6104 Wiha Professional Quality ESD Safe Tweezers Surface resistance is 106 - 109 Ohms D Flat Bent 35O, 3mm Diameter Grip Item No. Description wt. 58 SA-SMD ESD - 117mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44524 Curved Extra Fine, 3mm Long Straight Tip Item No. Description wt. 7abb SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44525 MicroTip Bent 30O 1.6mm Item No. Description wt. 8b SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44529 Flat Bent 35O, 2mm Diameter Grip Radius Item No. Description wt. 59 SA-SMD ESD - 117mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44530 ESD Safe General Purpose Fine Point Narrow Body Low Force Bent 35O-3mm Tip Item No. Description wt. SSbb SA ESD - 140mm .08 44526 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Angled Extra Fine Points Bent 30O, 3mm Long Tips Item No. Description wt. 44527 5abb SA ESD - 117mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Extra Fine Points Bent 30O, 3mm Long Tips Item No. Description wt. 44528 5bb SA ESD - 107mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description wt. 44531 1 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Heavy Duty Strong Tweezers Tapered To Strong Point Item No. Description wt. 00 SA ESD - 120mm .09 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44532 Angled & Slightly Bent With Extra Fine Tips Item No. Description wt. 7 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 44533 www.wihatools.com 35 Numerical Index by Item Number Item No. Page 10820 19 10891 19 10892 19 10893 19 10895 19 26903 10 26904 10 26905 10 26911 10 26912 10 26913 11 26914 11 26915 11 26916 11 26917 11 26918 11 26919 11 26920 11 26921 11 26922 10 26923 11 26924 11 26925 11 26926 11 26927 11 26928 11 26929 11 26932 10 26933 10 26934 10 26935 10 26936 10 26937 10 26938 11 26939 11 26940 11 26941 11 26942 11 26943 11 26944 11 26945 11 26946 11 26947 11 26948 11 26949 11 26950 11 26951 11 26952 11 26953 11 26954 11 26955 11 26956 11 26957 11 26958 11 26959 11 26960 11 26961 11 26962 11 26963 11 26964 11 26965 11 26966 11 26967 11 26968 11 26969 11 26971 10 26972 10 26973 10 26974 10 26975 11 26976 11 26977 11 26978 11 26979 11 26980 11 26981 11 Item No. Page 26982 11 26985 11 26987 13 26988 13 26989 13 26990 12 26991 12 26992 12 26993 12 26995 13 26996 13 26997 13 26998 13 26999 13 27009 9 27013 9 27018 9 27026 9 27090 9 27100 9 27208 4 27210 4 27212 4 27215 4 27220 4 27222 4 27223 4 27224 4 27225 4 27227 4 27228 4 27230 4 27232 4 27234 4 27235 4 27237 4 27238 4 27240 4 27242 4 27243 4 27290 4 27302 5 27305 5 27307 5 27310 5 27312 5 27314 5 27316 5 27320 5 27322 5 27324 5 27326 5 27390 4 27393 5 27399 5 27505 7 27507 7 27509 7 27510 7 27513 7 27515 7 27520 7 27525 7 27530 7 27535 7 27537 7 27539 7 27541 7 27543 7 27545 7 27547 7 27549 7 27590 7 27591 7 27701 8 27703 8 Item No. Page 27705 8 27707 8 27709 8 27711 8 27713 8 27715 8 27720 8 27722 8 27725 8 27730 8 27735 8 27740 8 27745 8 27750 8 27755 8 27760 8 27790 8 27791 8 27801 6 27802 6 27803 6 27804 6 27805 6 27811 6 27817 6 27823 6 27829 6 27835 6 27841 6 27847 6 27850 6 27851 6 27852 6 27853 6 27854 6 27855 6 27856 6 27857 6 27890 6 27894 6 27899 6 27920 9 28000 10 28001 10 28021 10 28023 10 28024 10 28025 10 28026 10 28027 10 28028 10 28029 10 28033 10 28034 10 28035 10 28036 10 28037 10 28080 12 28094 12 28106 20 28107 20 28108 20 28109 20 28110 20 28112 20 28114 20 28116 21 28117 21 28118 21 28119 21 28120 21 28122 21 28123 21 28124 21 28126 20 28127 20 Item No. Page Item No. Page Item No. Page 28128 20 28129 20 28130 20 28132 20 28133 20 28134 20 28135 20 28136 20 28137 21 28138 20 28139 20 28140 20 28142 20 28143 20 28144 21 28149 21 28150 21 28151 21 28156 21 28157 21 28158 21 28159 21 28160 21 28161 21 28162 21 28163 21 28164 21 28168 21 28169 21 28170 21 28171 21 28172 21 28173 21 28174 21 28175 21 28176 21 28177 21 28180 17 28486 20 28522 22 28524 22 28526 22 28591 22 28592 22 28801 22 28803 22 28805 22 28807 22 28809 22 28810 22 28812 22 28814 22 28816 22 28825 22 28826 22 28827 22 28828 22 28829 22 28830 22 28890 22 30240 18 30242 18 30244 18 30246 18 30248 18 30292 18 31150 18 31151 18 31152 18 32702 23 32703 23 32704 23 32705 23 32706 24 32708 24 32710 24 32711 24 32712 24 32714 25 32716 25 32718 25 32720 25 32721 25 32722 26 32724 26 32726 26 32728 26 32732 27 32734 27 32742 27 32744 27 32746 27 32748 28 32750 28 32752 28 32790 28 32791 28 32793 26 36200 18 36204 18 36206 18 36208 18 36209 18 36218 18 36219 18 36224 18 36260 18 36289 18 38701 17 38790 17 41105 19 41106 19 44501 32 44502 32 44503 32 44504 32 44505 32 44506 32 44507 32 44508 32 44509 32 44510 32 44511 33 44512 33 44513 33 44514 33 44515 33 44518 33 44520 33 44521 33 44522 33 44523 33 44524 34 44525 34 44526 34 44527 34 44528 34 44529 34 44530 34 44531 34 44532 34 44533 34 44590 12 45810 29 45811 29 45812 29 45813 30 45814 30 45820 30 45821 30 45822 30 45823 31 45824 31 45890 31 75008 14 75012 14 75015 14 75018 14 75020 14 75025 14 75030 14 75035 14 75040 14 75093 16 75094 16 75095 16 75096 16 75105 14 75110 14 75115 14 75120 14 75307 14 75309 14 75313 14 75315 14 75320 14 75322 14 75325 14 75327 14 75330 14 75332 14 75340 14 75342 14 75350 14 75352 14 75354 14 75356 14 75358 14 75360 14 75362 14 75364 14 75366 14 75368 14 75370 14 75372 14 75703 14 75704 14 75705 14 75706 14 75707 14 75708 14 75709 14 75710 14 75715 14 75720 14 75727 14 75728 14 75729 14 75735 14 75739 14 75742 14 75792 15 75801 14 75900 14 75901 14 75902 15 75990 15 75991 15 75992 15 75994 15 75996 15 91118 5,7,9 92092 9 (800) 494-6104 fax: (800) 494-7456 email: cservice@wihatools.com Wiha Quality Tools 1348 Dundas Circle Monticello, MN 55362 tel: 763.295.6591 fax: 763.295.6598 Catalog Item No. 99945 .wo version - 5/15/13 Wiha Tools Canada Ltd. www.wihatools.ca Brampton, ONT L6T 4X4 tel: 866.494.0096 or 763.295.6591 fax: 763.295.6598 To: Subject to change without notice ©2013 Willi Hahn Corporation ®Torx is a registered trademark of Acument Intellectual Properties LLC. 99060.wo - Product Guide 99004.wo - Shop Tools Catalog 99001.wo - TorqueControl Catalog 99934.wo - Hex Tools Catalog 99914.wo - TORX Catalog 99002.wo - Screwdrivers Catalog 99951.wo - Bits Catalog 99919.wo - Insulated Catalog 99006.wo - Tech Tools Catalog 99977.wo - Pliers/Crimpers Catalog Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Wiha: 28170 28122 28174 26977 26905 26962 75900 75901 28134 28149 28177 28114 28120 28169 26979 75008 75322 26903 26904 26946 26969 28024 26939 28144 28118 28124 28138 28168 28171 26981 26923 26966 26972 75362 75991 28116 28127 28136 28129 26950 28021 28132 28151 28173 28176 75342 28137 28175 28107 26944 28172 91118 28139 75332 28028 75115 75313 26975 75015 28026 26964 26912 26948 26942 28140
28114 价格&库存
很抱歉,暂时无法提供与“28114”相匹配的价格&库存,您可以联系我们找货
