ROB-10336
ROB-10336
    SPARKFUNELECTRONICS
    ROBOT PLATFORM ROVER 5
ROB-10336 数据手册
Rover 5 Rover 5 is a new breed of tracked robot chassis designed specifically for students and hobbyist. Unlike conventional tracked chassis’s the clearance can be adjusted by rotating the gearboxes in 5-degree increments. “Stretchy” rubber treads maintain tension as the clearance is raised. Each gearbox has an 87:1 ratio includes an optical quadrature encoder that gives 1000 pulses over 3 revolutions of the output shaft. The chassis can be upgraded to include four motors and encoders making it ideal for mecanum wheels. Inside of the chassis are 4 noise suppression coils at the bottom and a battery holder that accepts 6x AA batteries. It is recommended to use NiMh batteries as they last longer and have a higher current output than Alkaline batteries. Video of the chassis in action can be seen here: Video indoors autonomous: http://v.youku.com/v_show/id_XMjE5NzkwODA0.html Video outdoors RC mode: http://v.youku.com/v_show/id_XMjIwMTkxODk2.html Dimensions: Specifications: Motor rated voltage: 7.2V Motor stall current: 2.5A Output shaft stall torque: 10Kg/cm Gearbox ratio: 86.8:1 Encoder type: Quadrature Encoder resolution: 1000 state changes per 3 wheel rotations Speed: 1Km/hr
ROB-10336 价格&库存
很抱歉,暂时无法提供与“ROB-10336”相匹配的价格&库存,您可以联系我们找货
