ROB-13176
ROB-13176
    SPARKFUNELECTRONICS
    MICRO GRIPPER KIT A STRAIGHT MNT
ROB-13176 数据手册
  Micro Gripper Kit A - Straight Mount ROB-13176 ROHS  images are CC BY-NC-SA 3.0 Description: This is the Micro Gripper Kit A, a simple robotics kit that is great for “getting a grip” on smaller robotics projects! Designed for use with any sub-micro size Hitec servo, the gripper kit is easy to assemble and requires only a Phillips Head Screwdriver. This Micro Gripper is capable of opening 2.75" wide max, has an overall body length of 1.7" long with a 1.3" wide servo housing body, and offers three 6-32 mounting thru-holes along the edges of the servo housing. Actobotics is a robotics building system based around extruded aluminum channels, gears, precision shafts, and ball bearings. Thanks to the two standardized hole patterns, nearly all Actobotics components can be intuitively connected together. The wide range of components makes building complex electromechanical prototypes or finished projects a reality. Note: This kit does NOT include a servo. Check the Recommended Products section below for great sub-micro size servo options. Features: • Opening Width - 2.75" (69.85mm) • Mounting Hole ID - 0.1" (3.5mm) https://www.sparkfun.com/products/13176 2/9/2016
ROB-13176
- 物料型号:Micro Gripper Kit A - Straight Mount ROB-13176 - 器件简介:这是一个Micro Gripper Kit A,适用于小型机器人项目,设计用于任何亚微型Hitec伺服电机,易于组装,仅需十字螺丝刀。 - 引脚分配:文档中未明确提及引脚分配信息。 - 参数特性:最大开口宽度为2.75英寸(69.85mm),整体长度为1.7英寸,伺服电机外壳宽度为1.3英寸,提供三个6-32安装通孔。 - 功能详解:Actobotics是一个基于挤压铝通道、齿轮、精密轴和滚珠轴承的机器人构建系统,具有两个标准化的孔模式,几乎所有Actobotics组件都可以直观地连接在一起。 - 应用信息:该套件不包括伺服电机,推荐产品部分有适合的亚微型伺服电机选项。 - 封装信息:文档中未明确提及封装信息
ROB-13176 价格&库存
很抱歉,暂时无法提供与“ROB-13176”相匹配的价格&库存,您可以联系我们找货
