ROB-13175
ROB-13175
    SPARKFUNELECTRONICS
    STD GRIPPER KIT B STRAIGHT MNT
ROB-13175 数据手册
  Standard Gripper Kit B - Straight Mount ROB-13175 ROHS  images are CC BY-NC-SA 3.0 Description: This is the Standard Gripper Kit B, a simple and durable robotics kit that is great for “getting a grip” on pretty much any robotics project! Designed for use with any standard size Hitec or Futaba servo, the gripper kit is easy to assemble and requires only a Phillips Head Screwdriver. This Standard Gripper is capable of opening an impressive 6" wide max, has an overall body length of 5" long with a 1.3" wide servo housing body, and offers 6-32 mounting thru-holes along the edges of the servo housing. Actobotics is a robotics building system based around extruded aluminum channels, gears, precision shafts, and ball bearings. Thanks to the two standardized hole patterns, nearly all Actobotics components can be intuitively connected together. The wide range of components makes building complex electromechanical prototypes or finished projects a reality. Note: This kit does NOT include a servo. Features: • Opening Width - 6" (152mm) • Mounting Hole ID - 0.1" (3.5mm) https://www.sparkfun.com/products/13175 2/9/2016
ROB-13175 价格&库存
很抱歉,暂时无法提供与“ROB-13175”相匹配的价格&库存,您可以联系我们找货
