Micro Gripper Kit B - Hub Mount
ROB-13177 ROHS
images are CC BY-NC-SA 3.0
Description: This is the Micro Gripper Kit B, a simple robotics kit that is great for
“getting a grip” on smaller robotics projects! Designed for use with any sub-micro size
Hitec servo, the gripper kit is easy to assemble and requires only a Phillips Head
Screwdriver. This Micro Gripper is capable of opening 2.75" wide max, has an overall
body dimension of 2.6" long by 1.3" wide, and offers the 0.77" hub pattern for easy
mounting on Actobotics components.
Actobotics is a robotics building system based around extruded aluminum channels,
gears, precision shafts, and ball bearings. Thanks to the two standardized hole
patterns, nearly all Actobotics components can be intuitively connected together. The
wide range of components makes building complex electromechanical prototypes or
finished projects a reality.
Note: This kit does NOT include a servo.
Features:
• Opening Width - 2.75" (69.85mm)
• Hub Pattern - 0.77"
https://www.sparkfun.com/products/13177
2/9/2016
很抱歉,暂时无法提供与“ROB-13177”相匹配的价格&库存,您可以联系我们找货
