Standard Gripper Kit A - Channel Mount
ROB-13174 ROHS
3
images are CC BY-NC-SA 3.0
Description: This is the Standard Gripper Kit A, a simple and durable robotics kit that
is great for “getting a grip” on pretty much any robotics project! Designed for use with
any standard size Hitec or Futaba servo, the gripper kit is easy to assemble and
requires only a Phillips Head Screwdriver. This Standard Gripper is capable of
opening an impressive 5" wide, has an overall body dimension of 5" long by 3" wide,
and offers both 0.77" and 1.5" hub patterns for easy mounting on Actobotics
components.
Actobotics is a robotics building system based around extruded aluminum channels,
gears, precision shafts, and ball bearings. Thanks to the two standardized hole
patterns, nearly all Actobotics components can be intuitively connected together. The
wide range of components makes building complex electromechanical prototypes or
finished projects a reality.
Note: This kit does NOT include a servo.
Features:
• Opening Width - 5" (127mm)
• Hub Pattern - 0.77" & 1.5"
https://www.sparkfun.com/products/13174
2/9/2016
很抱歉,暂时无法提供与“ROB-13174”相匹配的价格&库存,您可以联系我们找货
