Page 1 of 2
XY-Plotter Robot Kit v2.0
(With electronic)
SKU: 114990137
(images/product/90014P1_05.jpg)
Description
Introduction:
Stronger structure, super easy stepper motor driver and laser-head compatible -- Makeblock XY-Plotter
2.0 is a fully updated version of XY-plotter. With the Processing and GRemote, the XY-Plotter 2.0 is a
drawing robot basiclly, you can draw amazing pictures with Gcode.
Since we reinforce the structure, the XY-plotter 2.0 is stronger enough to be conversed to MiniCNC, 3D
printer, driller, laser cutting machine, etc. And the movement of the terminal is stable and precise since
the improved dual-way transmission mechanism.
We replaced the stepper motor driver to A4988, whose operation is much easier than Me 2H Microstep
Driver V1.0.
Features:
• Stronger aluminum extrusion parts than XY-Plotter 1.0 (http://www.makeblock.cc/xy-plotter-robotkit-with-electronics/), anodizing surface
• Dual-way transmission mechanism
• Improved pen rising mechanism
• Super easy-use stepper motor driver, A4988 (http://www.makeblock.cc/me-stepper-motor-driver/)
• Updated control panel -- Me Baseboard (http://www.makeblock.cc/me-baseboard-v1-0/)
• Easy-Controlled by Processing and GRemote
Specification:
Frame: Anodized aluminum
Physical Dimensions(L×W×H): 620mm × 620mm×140mm
Working area (X×Y): 310mm×390mm
XY Accuracy: 0.1mm
Max Engrave Speed: 50mm/s
Power: 100-240 V~50/60Hz AC/DC Power adapter, 12V/2.0A
Page 2 of 2
Software: GRemote
Supports file type: *.CNC(G-code)
Connections: USB
Electronics: Makeblock Me_baseboard
Note: The power supply in this kit is USA plug AC to DC wall power supply. You can buy other Power plugs
in our website.
Download:
Please visit the link to download the software and assembly instruction.
https://github.com/Makeblock-official/XY-Plotter-2.0 (https://github.com/Makeblock-official/XY-Plotter-2.0)
Instruction: http://learn.makeblock.cc/xy2/ (http://learn.makeblock.cc/xy2/)
Part List:
1 x Beam 0824-16
10 x Shaft Collar 4mm
1 x 6P6C RJ25 cable-35cm
4 x Beam 0824-48
1 x Flexible coupling 4x4mm
2 x 6P6C RJ25 cable-50cm
1 x Beam 0824-80
4 x Linear Motion Shaft D8X496mm 1 x Wall Adapter Power Supply - 12VDC
4 x Beam 0824-96
6 x Linear Motion Slide Unit 8mm
1 x USB A-Male to B-Male Cable
2 x Beam 0824-112
10 x Flange Bearing 4x8x3mm
1 x Base Bracket
2 x Beam 0824-496
1 x HEX Screwdriver 2.5mm
4 x Me Micro Switch B
1 x Beam 0808-80
1 x Cross Screwdriver 3mm
1 x 9g micro servo bracket
2 x Beam2424-504
2 x HEX Allen Key 1.5mm
1 x Linear Motion Shaft D4x512mm
2 x Bracket 3x3
1 x Wrench 7mm
1 x Linear Motion Shaft D4x80mm
5 x Plate 3x6
50 x Nut M4
3 x Nut M2
5 x Bracket U1
10 x Countersunk Screw M3x8
3 x Cross recessed pan head screw M2×10
3 x Belt Connector
26 x Headless Set Screw M3x5
30 x Socket Cap Screw M4×14
2 x 42BYG Stepper Motor Bracket
16 x Plastic Rivet R4060
28 x Socket Cap Screw M4×16
1 x K-Power 9g Micro Servo
6 x Plastic Rivet R4100
12 x Socket Cap Screw M4×22
20 x Plastic Ring 4x7x2mm
18 x Socket Cap Screw M4×30
6 x Timing Pulley18T
1 x Me-Baseboard
36 x Socket Cap Screw M4×8
3 x Open-end Timing Belt (1.3m)
2 x Me Stepper motordriver V1.0
6 x Cuttable Linkage 3
2 x D Shaft 4x56mm
3 x RJ25 Adapter
30 x Nylon cable ties 2*100
1 x Threaded Shaft 4x39mm
2 x 6P6C RJ25 cable-20cm
5 x Rubber band
http://www.seeedstudio.com/depot/XYPlotter-Robot-Kit-v20-With-electronic-p-2164.html
1/7/2016
很抱歉,暂时无法提供与“114990137”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2781.631061+356.77407
