114990138
114990138
    SEEED(矽递科技)
    XY-PLOTTER ROBOT KIT V2.0
114990138 数据手册
Page 1 of 3 (images/product/114990138 3.jpg) XY-Plotter Robot Kit v2.0 (No electronic) SKU: 114990138 Description Introduction: Makeblock XY-Plotter 2.0 is a updated version of XY-plotter. With the Processing and GRemote, You can draw amazing pictures with Gcode. Page 2 of 3 Since we reinforce the structure, the XY-plotter 2.0 is stronger enough to be conversed to MiniCNC, 3D printer, driller, etc. And the movement of the terminal is stable and precise since the improved dual-way transmission mechanism. Features: • • • • • • • • • • • • Strong aluminum extrusion parts, anodizing surface Two Metal stepper motor with back shaft 12V Solenoid include Closed type bushing block and ball bushing insert for use in linear motion applications Four-bolt aluminum alloy bushing block for a lightweight ready-to-mount installation Synthetic resin retainer plate for accurate ball guidance and low noise Four rows of recirculating balls inside the ball bushing for smooth running Integral lip seals to retain lubricant and protect against contamination Round steel shaft for use with slide units in linear motion applications. Chrome plated for corrosion resistance Case hardened for wear resistance Precision ground for consistent ball bushing radial clearance Note: With this kit, you can only build a XY-Plotter without controller. You can use your own electronic parts to drive this. Part List: 4 × Linear Motion Shaft D8×480 2 x Stepper Motor 30 × Plastic Rivet 4120 6 × Linear Motion Slide Unit 8mm 2 × Stepper Motor Bracket 25 × Plastic Ring 4x7x2mm 1 × Solenoid-12V 4 × Timing Pulley 90T 10 × Plastic Ring 4x8x1mm 2 × Beam 0824-496 8 × Timing Pulley Slice 90T 35 × Screw M4×8 1 × Beam 0824-144 1 × Open-end Timing Belt (3m) 60 × Screw M4×14 3 × Beam 0824-128 3 × Link Rod 2 × Srew M4×30 1 × Beam 0824-96 2 × Shaft Connector-4 40 × Nylong Lock Nut M4 3 × Beam 0824-80 3 × Threaded Shaft 4×39mm 20 × Nut M4 1 × Beam 0808-96 3 × Shaft Collar 4mm 15 × Nylon Cable Ties 1 × General Bracket 4 × Flange Bearing 4x8x3mm 1 × Cross Screwdriver 2 × Bracket 3x6 8 × Headless Set Screw M3x5 1 × Screwdriver 3mm 14 × Bracket 3×3 15 × Countersunk Screw M3x8 2 × Screwdriver 1.5mm Page 3 of 3 2 × Plate 3×6 http://www.seeedstudio.com/depot/XYPlotter-Robot-Kit-v20-No-electronic-p-2165.html 1/7/2016
114990138 价格&库存
很抱歉,暂时无法提供与“114990138”相匹配的价格&库存,您可以联系我们找货
