110990126
110990126
    SEEED(矽递科技)
    MAKEBLOCK ULTIMATE ROBOT KIT
110990126 数据手册
Page 1 of 2 Makeblock Ultimate Robot Kit - Blue SKU: 110990126 (images/product/m13_04.jpg) Description Makeblock Ultimate Kits covers the functions of Makeblock Starter Kit and Makeblock Advanced Kit. Adding more beams and other mechanical parts. Sliders and V-Slot bearing can be used to build flexible linear motion mechanism, Makeblock high torque digital servo included, can be used to build 2-DOF robot arm. Note: Free shipping policy is NOT apply to the Makeblock Kits. Features • • • • • • • • • • Strong aluminum extrusion parts, anodizing surface Metal gear motor with back shaft Different configuration of 2-wheel drive moving platform Different configuration of tracked platform Makeblock customized high torque servo included Building Linear motion mechanism Building 4-legged crawler robot 2-DOF robot arm Aluminum robot gripper Extra parts for exploring other configuration Parts are packed in a translucent plastic tool box. Parts List • • • • • • • 4x Beam 0824-96 4x Beam 0824-128 2x Beam 0824-144 2x Beam 0824-160 2x Beam 0824-192 4x Slider 256 2x Beam 0808-128 Page 2 of 2 • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • 2x Beam 0808-144 2x Beam 0808-192 2x Bracket 3x3 2x Bracket 3x6 4x Plate 3x6 20x Link Rod 2x Bracket P1 2x Bracket P3 2x Caster Wheel 2x DC Motor-25 1x DC Motor-37 1x MECDS-150 Servo Motor 2x DC Motor-25 Bracket 1x DC Motor-37 Bracket 2x MECDS-150 Servo Bracket 4x Shaft Connector-4 2x Timing Pulley18T 4x Timing Pulley 62T 6x Timing Pulley 90T 4x Timing Pulley Slice 90T 4x Tyre 68.5x22mm 60x Track 60x Track Axle 2x Timing Belt 123T 1x Timing Belt 216T 1x Timing Belt 378T 1x Open-end Timing Belt (1Meter) 2x D Shaft 4x50mm 1x D Shaft 4x160mm 6x Threaded Shaft 4x31mm 30x Shaft Collar 4mm 8x V-slot Bearing 12x Flange Bearing 4x8x3mm 1x Robot Gripper and servo 1x Screwdriver 3mm 1x Cross Screwdriver 1x Screwdriver 1.5mm 48x Screw M4x8 48x Screw M4x14 16x Screw M4x22 16x Nut M4 2x Nut M8 20x Countersunk Screw M3x8 40x Headless Screw M3x5 16x Plastic Rivet R4060 16x Plastic Rivet R4120 48x Plastic Ring 4x7x2 Support If you have any further question for technical support, please contact waker@makeblock.cc (mailto:waker@makeblock.cc) or visit forum (http://forum.makeblock.cc/category/makeblock-products) of Makeblock. http://www.seeedstudio.com/depot/Makeblock-Ultimate-Robot-Kit-Blue-p-1569.html 1/7/2016
110990126 价格&库存
很抱歉,暂时无法提供与“110990126”相匹配的价格&库存,您可以联系我们找货
