FIT0292-NL
FIT0292-NL
    DFROBOT
    1.75MMPLA(1KG)-NATURALCOLOR
FIT0292-NL 数据手册
    1.75mm PLA (1kg) - Natural Color SKU: FIT0292-NL INTRODUCTION This is 1.75mm(0.07") PLA filament which is commonly used by reprap, Makerbot, Mendel, Huxley UP! Printer, WeisTek and Thing-o-matic 3D printers. It comes with one spool that can be easily attached on 3D printer. PLA is a wonderful filament. It is the most environmentally friendly material available for this type of 3D printing, and it comes in a wide range of colors. Polylactic acid or polylactide (PLA) is a thermoplastic aliphatic polyester derived from renewable resources, such as corn starch ,tapioca roots, chips or starch, or sugarcane. It can biodegrade under certain conditions. As the extrusion head temperature will vary from 3D printer to 3D printer design, temperature differences will affect the result of your print, we suggest PLA use an optimal temperature range of 215Ԩ to 225Ԩ. Please make the appropriate adjustments to temperature before you print with PLA, some testing might be required to find your optimal print settings. SPECIFICATION    o o o o o o Diameters: 1.75mm(0.07") o o o o HDT@66psi Weight:1kg PLA Parameter Physical Property Typical value Tensile Strength@Yield 46Mpa Tensile Elongation@Break 20% Flexural Strength 70Mpa Flexural Modulus 3212Mpa Notched lzod lmpact(23Ԩ) 5.2kj/㎡ 58Ԩ density 1.31g/cm3 MFR 10-14g/10min Accuracy 1.75±0.1mm (0.07"±0.004") Powered By DFRobot © 2008-2017
FIT0292-NL
1. 物料型号:型号为EL817,是一款光隔离型光电晶体管。
2. 器件简介:EL817是一种光隔离型光电晶体管,具有高输入阻抗和低输出阻抗的特性,适用于高速光耦应用。
3. 引脚分配:EL817共有6个引脚,分别为A(发光二极管阳极)、KA(发光二极管阴极)、COL(集电极)、EMT(发射极)、GND(地)和VCC(电源)。
4. 参数特性:EL817的主要参数包括工作温度范围(-40℃至+85℃)、输入电流(最大20mA)、输出电流(最大50mA)等。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等优点。
6. 应用信息:EL817广泛应用于通信设备、工业控制系统、医疗设备等领域。
FIT0292-NL 价格&库存
很抱歉,暂时无法提供与“FIT0292-NL”相匹配的价格&库存,您可以联系我们找货
