FIT0292-Y
FIT0292-Y
    DFROBOT
    1.75MMPLA(1KG)-YELLOW
FIT0292-Y 数据手册
    1.75mm PLA (1kg) – Yellow SKU: FIT0292-Y INTRODUCTION This is 1.75mm PLA filament which is commonly used by reprap, Makerbot, Mendel, Huxley UP! Printer, WeisTek and Thingo-matic 3D printers. It comes with one spool that can be easily attached on 3D printer. PLA is a wonderful filament. It is the most environmentally friendly material available for this type of 3D printing, and it comes in a wide range of colors. Polylactic acid or polylactide (PLA) is a thermoplastic aliphatic polyester derived from renewable resources, such as corn starch ,tapioca roots, chips or starch, or sugarcane. It can biodegrade under certain conditions. As the extrusion head temperature will vary from 3D printer to 3D printer design, temperature differences will affect the result of your print, we suggest PLA use an optimal temperature range of 215Ԩ to 225Ԩ. Please make the appropriate adjustments to temperature before you print with PLA, some testing might be required to find your optimal print settings. SPECIFICATION    o o o o o o Diameters: 1.75mm o o o o HDT@66psi Weight:1kg PLA Parameter Physical Property Typical value Tensile Strength@Yield 46Mpa Tensile Elongation@Break 20% Flexural Strength 70Mpa Flexural Modulus 3212Mpa Notched lzod lmpact(23Ԩ) 5.2kj/㎡ 58Ԩ density 1.31g/cm3 MFR 10-14g/10min Accuracy 1.75±0.1mm   Powered By DFRobot © 2008-2017
FIT0292-Y 价格&库存
很抱歉,暂时无法提供与“FIT0292-Y”相匹配的价格&库存,您可以联系我们找货
