1.75mm PLA (1kg) – Black
SKU: FIT0292-BK
INTRODUCTION
This is 1.75mm PLA filament which is commonly used by reprap, Makerbot, Mendel, Huxley UP! Printer, WeisTek and Thingo-matic 3D printers. It comes with one spool that can be easily attached on 3D printer.
PLA is a wonderful filament. It is the most environmentally friendly material available for this type of 3D printing, and it comes
in a wide range of colors.
Polylactic acid or polylactide (PLA) is a thermoplastic aliphatic polyester derived from renewable resources, such as corn starch
,tapioca roots, chips or starch, or sugarcane. It can biodegrade under certain conditions.
As the extrusion head temperature will vary from 3D printer to 3D printer design, temperature differences will affect the result of
your print, we suggest PLA use an optimal temperature range of 215Ԩ to 225Ԩ. Please make the appropriate adjustments to
temperature before you print with PLA, some testing might be required to find your optimal print settings.
SPECIFICATION
o
o
o
o
o
o
Diameters: 1.75mm(0.07")
o
o
o
o
HDT@66psi
58Ԩ
density
1.31g/cm3
Weight:1kg
PLA Parameter
Physical Property
Typical value
Tensile Strength@Yield
46Mpa
Tensile Elongation@Break
20%
Flexural Strength
70Mpa
Flexural Modulus
3212Mpa
Notched lzod lmpact(23Ԩ)
5.2kj/㎡
MFR
10-14g/10min
Accuracy
1.75±0.1mm (0.07±0.004")
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“FIT0292-BK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+271.287831+35.16874
