2444
2444
    ADAFRUIT
    SHOULDER SCREW HEX 4-40
2444 数据手册
NinjaFlex - 1.75mm Diameter - Green Grass - .50 Kg PRODUCT ID: 2444  Description Looking beyond ABS? Tired of PLA? Open a world of possibilities, limited only by your imagination. NinjaFlex, a cutting-edge filament for 3D printers, is a specially formulated thermoplastic elastomer (TPE) that produces flexible prints with elastic properties. Patent pending technology allows for smooth feeding and clean, high-quality printed parts. NinjaFlex's unique flexibility and smooth feeding characteristics enable you to create in ways you never thought possible. This is the 1.75mm diameter version and it comes in a Green Grass color! We carry a lot of NinjaFlexes in a bevy of colors and sizes.  Best Suited For o o Fused Deposition 3D printers that use 3mm filament. 3D printers that accept other types of filaments such as ABS and PLA.  Technical Details o o Features:  Filament shore hardness of approximately 85A  Consistent diameter and material properties provide reliable, high quality prints  Patent pending technology allows for smooth feeding  Low tack, low CoF exterior allows smooth feed through filament guides  High elasticity and excellent abrasion resistance  Excellent build platform adhesion and bonding between layers  REACH and RoHS 2002/95/EC Directive Compliant  1.75mm filament spool = .50 kg Processing Guidelines:  Recommended extruder temperature: 210 - 225°C  Recommended platform temperature: 30 - 40°C        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“2444”相匹配的价格&库存,您可以联系我们找货
