VMEE-M
VMEE-M
    VECTOR
    EXTENDER CARD METRIC
VMEE-M 数据手册
VME J1/J2 Extender Home About Vector Page 1 of 2 Distributors Sales Contact Us Catalog Request VMEE-M EXTENDER VECTORBORD® 6U VME J1/J2 with 3-row, 96 positions DIN 41612 style connectors ( click on image to enlarge) KEY FEATURES : VMEEJ1 Extender on top & VMEEJ2 Extender on Bottom, new monolithic design VMEE-M Extender Excellent performance with a multi layer design Individual signal tracking with interruption option Voltage & Current measuring facilities Full ground plane Signal pin-out identification silkscreen onto outer PCB layers Jumper Blocks provided to allow signal line interrogation Max. current per contact @ nominal 50o C = 1.75A Controlled impedence, Signal trace shielding Voltage rating 200 RMS or 300 VDC DOWNLOAD DATASHEET BOARD SPECIFICATIONS : Material : FR-4 Epoxy Glass PCB UL94V-0, PCB RoHS Compliant 6 Internal 1oz. copper layers PCB exposed Copper areas plated with Immersion Gold MECHANICAL SPECIFICATIONS : Board Height 6U ( 9.187") ( 233.35mm ) Board Length 11.75" ( 298mm) PCB Thickness 0.062" (1.6mm) Card Extender brackets (arms) on top & bottom (P/N : 5210211) http://www.vectorelect.com/Product/Extenders/VMEE-M.htm 10/14/2014 VME J1/J2 Extender Page 2 of 2 Custom Extender design services available please contact inquire@vectorelect.com email us your requirements : inquire@vectorelect.com 11115 Vanowen St., North Hollywood, CA 91605, USA Tel.: (818) 985 8208, (800) 423 5659; Fax : (818) 985 7708 Circbord®, Vectorbord® and VectorPak® are registered trademarks of Vector Electronics & Technology, Inc. CompactPCI® is a registered trademark of PICMG. © 2001 Vector Electronics & Technology, Inc. - All Rights Reserved http://www.vectorelect.com/Product/Extenders/VMEE-M.htm 10/14/2014
VMEE-M
1. 物料型号:VMEE-M Extender,是6U VME J1/J2的扩展器,具有3排96个位置的DIN 41612风格的连接器。 2. 器件简介:VMEE-M Extender采用新的单体设计,顶部为VMEEJ1 Extender,底部为VMEEJ2 Extender,具有多层设计,提供优异的性能。 3. 引脚分配:文档中提到了信号引脚的分配,但具体分配未在摘要中提及。 4. 参数特性: - 材料:FR-4环氧玻璃 - PCB符合UL94V-0和RoHS标准 - 6个内部1盎司铜层 - PCB暴露的铜区域镀有浸金 - 板高6U (9.187英寸/233.35mm) - 板长11.75英寸(298mm) - PCB厚度0.062英寸(1.6mm) - 每接触点在50°C时的最大电流为1.75A - 控制阻抗,信号迹线屏蔽 - 电压等级200 RMS或300 VDC 5. 功能详解:文档提到了单独信号跟踪和中断选项,以及电压和电流测量设施。 6. 应用信息:文档提供了定制扩展器设计服务的联系信息。 7. 封装信息:文档中提到了顶部和底部的卡扩展器支架(型号:5210211)。
VMEE-M 价格&库存
很抱歉,暂时无法提供与“VMEE-M”相匹配的价格&库存,您可以联系我们找货
