SBB1605-1
SBB1605-1
    CHIPQUIK
    SOLDER BREADBOARD (16 ROW 5 COLU
SBB1605-1 数据手册
SBB1605-1 Datasheet revision 1.1 www.Proto-Advantage.com Solder Breadboard (16 row 5 column) Product Highlights Solder-in breadboard with 16 rows, 5 columns, and 2 power channels 450 holes in total 0.1" hole grid Specifications Dimensions: PCB construction: PCB operating temperature range: PCB reflow maximum temperature: Hole size: Diameter of 4 corner mounting holes: Distance between mounting holes: 66.04mm x 60.96mm x 1.6mm (2.6" x 2.4" x 0.0625”) FR-4 UL94V-0 -40°C to +130°C +260°C 1.0mm (40 mils) diameter Holes accept 25 mil square wire wrap posts 3.2mm (125 mils) 58.42mm x 53.34mm (2.3" x 2.1") (center-to-center) 1 © 2007-2016 Proto Advantage™
SBB1605-1 价格&库存
很抱歉,暂时无法提供与“SBB1605-1”相匹配的价格&库存,您可以联系我们找货
SBB1605-1
  • 1+23.557831+2.95534
库存:9
SBB1605-1
    库存:36
