SBB400
SBB400
    CHIPQUIK
    400 PTS SOLDER-IN BREADBOARD (EX
SBB400 数据手册
SBB400 Datasheet revision 1.4 www.Proto-Advantage.com 400 pts solder-in breadboard (Exact Solderless Match) Product Highlights Top view Bottom view Immersion Gold Finish All holes are gold plated and are on a 0.1" grid. Column E-F hole-center to hole-center spacing is 0.3" (7.62mm). 1/16” (1.6mm) thick FR-4 UL94V-0 Accepts a variety of wire sizes (20-32 AWG) 4 mounting holes Two rectangular silkscreen areas that you can write on using pencil or pen Usage This board exactly copies the routing of a 400 pts ½ size solderless breadboard. Allows direct transfer of circuits prototyped in a solderless breadboard to a solder-in breadboard to facilitate functional insystem testing or field testing. Specifications Wiring Pattern: Dimensions: PCB construction: PCB operating temperature range: PCB reflow maximum temperature: PCB trace width: PCB trace thickness: PCB trace current capacity*: Recommended pin size: Diameter of 4 corner mounting holes: 2 Distribution Strips 1 Terminal Strip 100 Distribution Holes 300 Terminal Holes 3.6" x 2.3" x 0.0625" (91.44mm x 58.42mm x 1.6mm) FR-4 UL94V-0 -40°C to +130°C (-40°F to +266°F) +260°C (500°F) 0.059” (1.5mm) 1 oz copper / ft2 (1.4 mils) (0.03556 mm) 10A continuous @ 40°C rise, 13A continuous @ 80°C rise* 25 mil square wire wrap posts or smaller 3.2mm (125 mils) * Derived from IPC-2221 current capacity graphs at 25°C ambient temperature. Actual current capacity will vary based on air flow, component density, and other factors. 1 © 2007-2022 Proto Advantage™ Top View of SBB400 Topside silkscreen lines between holes show where bottom traces electrically connect holes. (Representative drawing only - not to scale) 2 © 2007-2022 Proto Advantage™ Complete Line of Proto Advantage Exact Solderless Match Solder-in Breadboards: Tiny breadboard match (P/N: SBB170) Full size breadboard match (P/N: SBB830) 1/6 size breadboard match (P/N: SBB136) 1/4 size breadboard match (P/N: SBB206) 1/2 size breadboard match (P/N: SBB400) 3 © 2007-2022 Proto Advantage™
SBB400 价格&库存
很抱歉,暂时无法提供与“SBB400”相匹配的价格&库存,您可以联系我们找货
