SBB2808-1
SBB2808-1
    CHIPQUIK
    SOLDER BREADBOARD (28 ROW 8 COLU
SBB2808-1 数据手册
SBB2808-1 Datasheet revision 1.0 www.Proto-Advantage.com Solder Breadboard (28 row 8 column) Product Highlights Solder-in breadboard with 28 rows, 8 columns, and 2 power channels 1200 holes in total 0.1" hole grid Specifications Dimensions: PCB construction: PCB operating temperature range: PCB reflow maximum temperature: Hole size: 1 104.14mm x 81.28mm (4.1" x 3.2") FR-4 UL94V-0 -40°C to +130°C +260°C 1.0mm (40 mils) diameter Holes accept 25 mil square wire wrap posts © 2007-2016 Proto Advantage™
SBB2808-1 价格&库存
很抱歉,暂时无法提供与“SBB2808-1”相匹配的价格&库存,您可以联系我们找货
SBB2808-1
    库存:11
    SBB2808-1
    • 1+32.314711+4.17874
    库存:67
