SBB8006-SS-1
SBB8006-SS-1
    CHIPQUIK
    SOLDER BREADBOARD (80 ROW 6 COLU
SBB8006-SS-1 数据手册
SBB8006-SS-1 Datasheet revision 1.0 www.Proto-Advantage.com Solder Breadboard (80 row 6 column) for 0.3” to 0.6" width SMT adapters Product Highlights Solder-in breadboard with 80 rows, 6 columns, and 2 power channels 3280 holes in total 0.1" hole grid 5 hole strips between power rails to accommodate wider DIP Adapters (adapter sizes up to 1.1" wide accepted) Specifications Dimensions: PCB construction: PCB operating temperature range: PCB reflow maximum temperature: Hole size: 1 104.14mm x 213.36mm x 1.6mm (4.1" x 8.4" x 0.063") FR-4 UL94V-0 -40°C to +130°C +260°C 1.0mm (40 mils) diameter Holes accept 25 mil square wire wrap posts © 2007-2016 Proto Advantage™
SBB8006-SS-1 价格&库存
很抱歉,暂时无法提供与“SBB8006-SS-1”相匹配的价格&库存,您可以联系我们找货
SBB8006-SS-1
  • 1+120.532491+15.66351
库存:31
