SBB2805-1
SBB2805-1
    CHIPQUIK
    SOLDER BREADBOARD (28 ROW 5 COLU
SBB2805-1 数据手册
SBB2805-1 Datasheet revision 1.0 www.Proto-Advantage.com Solder Breadboard (28 row 5 column) Product Highlights Solder-in breadboard with 28 rows, 5 columns, and 2 power channels 750 holes in total 0.1" hole grid Specifications Dimensions: PCB construction: PCB operating temperature range: PCB reflow maximum temperature: Hole size: 1 66.04mm x 81.28mm (2.6" x 3.2") FR-4 UL94V-0 -40°C to +130°C +260°C 1.0mm (40 mils) diameter Holes accept 25 mil square wire wrap posts © 2007-2016 Proto Advantage™
SBB2805-1 价格&库存
很抱歉,暂时无法提供与“SBB2805-1”相匹配的价格&库存,您可以联系我们找货
SBB2805-1
  • 1+28.114481+3.65355
库存:39
