1553DBPCB
1553DBPCB
    HAMMONDMANUFACTURING
    Breadboard, Prepunched Insulating Non-Plated Through Hole (NPTH) 2-Hole Pad, Single Side 0.1" (2.54m...
1553DBPCB 数据手册
10/3/22, 1:34 AM ABS Plastic Hand Held Enclosures (1553 Series) - Hammond Mfg. Quality Products. Service Excellence. ABS Plastic Hand Held Enclosures 1553 Series Soft Sided, Ergonomic Comfort, Battery Compartments Key Features: Ergonomically designed for hand-held comfort. Choice of five sizes and six color combinations. All sizes except 1553A available with or without battery compartment. Molded in general purpose ABS plastic with a soft, plastic overmold for comfortable grip. Top cover is recessed for membrane display or keypad. P.C. board standoffs are molded into case (see drawings or photos for more details). Includes removable front panel (for easy modifications) and assembly hardware (except for smallest 1553A units). Battery door & compartment version includes 4 battery clips (for 2 - AA batteries) and a 9 volt (PP3) battery clip. Gray 1553 series enclosures include nickel plated screws.  All other colors use black screws.  Refer to product datasheets for correct part numbers. P.C. Board mounting screws are not included. Order part number 1593ATS50 (pack of 50) or 1593ATS100 (pack of 100).     Designed to meet IP54 For similar enclosures designed for water-tight applications, try series 1553W Photo Features: Perfect for handheld use. Battery version comes with clips for AA for 9V. Additional Color Combinations Available https://www.hammfg.com/electronics/small-case/plastic/1553 1/4 10/3/22, 1:34 AM ABS Plastic Hand Held Enclosures (1553 Series) - Hammond Mfg. Accessories: ProtoBoard Printed Circuit Boards: High quality FR4 glass epoxy board Specifically designed to fit enclosures shown in the table below Mounting screws included Lead free etched copper PCB with a flux coating for easy soldering 0.042" holes drilled on 0.1" centers For more information link to the BPS (BusBoard Prototype Systems) website www.busboard.com 1553BPCB - works with 1553 sizes "B" and "C" 1553DBPCB  - works with 1553 size "D" Belt/ Pocket Clip Option: Molded from touch nylon Includes 2 nylon screws (insulated to avoid interference) Mounting Template Included (user drilling required) 1599CLIP (black) 1599CLIPGY (gray) IR End Panels Replaces existing front plastic panel. Dark red plastic filter (transparent to IR). For all 1553 "B" sized enclosures - Part Number 1553BIR-BULK For all 1553 "D" sized enclosures - Part Number 1553DIR-BULK Single End Panel Part Number Enclosure https://www.hammfg.com/electronics/small-case/plastic/1553 Overmold Overall Dimensions Max. P.C. Board 2/4 10/3/22, 1:34 AM ABS Plastic Hand Held Enclosures (1553 Series) - Hammond Mfg. Part Number Color Enclosure Color Overmold Length Depth Overall Width Dimensions Length Width Max. P.C. Board Color Color Length Width Depth Length Width 1553AABK Black Gray 2.95 1.97 0.67 2.73 1.65 1553AAGY Grey Gray 2.95 1.97 0.67 2.73 1.65 1553ABK Black Gray 3.94 2.41 0.67 3.73 1.90 1553AGY Grey Gray 3.94 2.41 0.67 3.73 1.90 1553BBK Black Gray 4.62 3.11 0.95 4.30 2.40 1553BGY Grey Gray 4.62 3.11 0.95 4.30 2.40 1553BBKBK Black Black 4.62 3.11 0.95 4.30 2.40 1553BTBUBK Trans Blue Black 4.62 3.11 0.95 4.30 2.40 1553BRDBK Red Black 4.62 3.11 0.95 4.30 2.40 1553BYLBK Yellow Black 4.62 3.11 0.95 4.30 2.40 1553CBK Black Gray 4.62 3.11 1.30 4.30 2.40 1553CGY Grey Gray 4.62 3.11 1.30 4.30 2.40 1553DBK Black Gray 5.80 3.50 0.98 5.48 2.65 1553DGY Grey Gray 5.80 3.50 0.98 5.48 2.65 1553DBKBK Black Black 5.80 3.50 0.98 5.48 2.65 1553DTBUBK Trans Blue Black 5.80 3.50 0.98 5.48 2.65 1553DRDBK Red Black 5.80 3.50 0.98 5.48 2.65 1553DYLBK Yellow Black 5.80 3.50 0.98 5.48 2.65 Dual End Panel Enclosure Overmold Part Number Color Color Length Overall Dimensions Width Depth Length Max. P.C. Board Width 1553BXBK Black Gray 4.62 3.11 0.95 4.30 2.40 1553BXGY Grey Gray 4.62 3.11 0.95 4.30 2.40 1553CXBK Black Gray 4.62 3.11 1.30 4.30 2.40 1553CXGY Grey Gray 4.62 3.11 1.30 4.30 2.40 1553DXBK Black Gray 5.80 3.50 0.98 5.48 2.65 1553DXGY Grey Gray 5.80 3.50 0.98 5.48 2.65 With Battery Doors & Compartments Enclosure Overmold Part Number Color Color Length Overall Dimensions Width Depth Length Max. P.C. Board Width 1553BBKBAT Black Gray 4.62 3.11 0.95 3.08 2.40 1553BGYBAT Grey Gray 4.62 3.11 0.95 3.08 2.40 1553BBKBKBAT Black Black 4.62 3.11 0.95 4.30 2.40 1553BTBUBKBAT Trans Blue Black 4.62 3.11 0.95 4.30 2.40 1553BRDBKBAT Red Black 4.62 3.11 0.95 4.30 2.40 1553BYLBKBAT Yellow Black 4.62 3.11 0.95 4.30 2.40 1553CBKBAT Black Gray 4.62 3.11 1.30 4.30 2.40 1553CGYBAT Grey Gray 4.62 3.11 1.30 4.30 2.40 1553DBKBAT Black Gray 5.80 3.50 0.98 4.20 2.65 1553DGYBAT Grey Gray 5.80 3.50 0.98 4.20 2.65 1553DBKBKBAT Black Black 5.80 3.50 0.98 4.20 2.65 1553DTBUBKBAT Trans Blue Black 5.80 3.50 0.98 4.20 2.65 1553DRDBKBAT Red Black 5.80 3.50 0.98 4.20 2.65 1553DYLBKBAT Yellow Black 5.80 3.50 0.98 4.20 2.65 Extra End Panels (10-packs) Black Gray Red Translucent Blue Yellow 1553B Enclosure Size 1553BPLBK-10 1553BPLGY-10 1553BPLRD-10 1553BPLTBU-10 1553BPLYL-10 1553C 1553CPLBK-10 1553CPLGY-10 https://www.hammfg.com/electronics/small-case/plastic/1553 3/4 10/3/22, 1:34 AM ABS Plastic Hand Held Enclosures (1553 Series) - Hammond Mfg. Enclosure Size 1553D Black Gray Red Translucent Blue Yellow 1553DPLBK-10 1553DPLGY-10 1553DPLRD-10 1553DPLTBU-10 1553DPLYL-10 Translucent Blue Yellow Extra Battery Doors (5-packs) Enclosure Size All 1553's with battery doors Black Gray Red 53BATDOORBK- 53BATDOORGY- 53BATDOORRD- 53BATDOORTBU- 53BATDOORYL5 5 5 5 5 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/small-case/plastic/1553 4/4
1553DBPCB 价格&库存
很抱歉,暂时无法提供与“1553DBPCB”相匹配的价格&库存,您可以联系我们找货
