8472-450G
8472-450G
    MGCHEMICALS
    PENETRATING OIL
8472-450G 数据手册
Penetrating Oil 8472 Technical Data Sheet 8472-Liquid Description The 8472 Penetrating Oil has excellent lubricating and penetrating characteristics. It provides corrosion resistance as strong as any penetrant on the market. It has low-VOC’s, so it does not dry quickly. As well, unlike some penetrants, it is safe on plastics, seals, and painted surfaces. Applications & Usages Common uses include releasing rusted bolts, nuts, screws, fasteners, pulleys, scales, tools, and other frozen metal mechanisms; general industrial maintenance and repair work, lubricating close fitting parts, displacing moisture, maintaining garden and yard equipment, household repair tasks, maintaining boating equipment and any mechanical equipment regularly subject to moist or wet conditions. Superior Characteristics Penetrates Cleans Lubricates Protects Displaces Moisture Safe on parts Environmentally safe Human safe Silicone free Creeps into tiny spaces and quickly dissolves rust to free corroded nuts, bolts, and frozen mechanical parts Removes tar, sap, oils, greases, adhesives, label residues, and more Minimizes friction and wear with a low viscosity, long lasting oil blend, leading to greater machine efficiency Provides extreme protection against rust and corrosion with high tech corrosion inhibitors and leaves a preservative film that protects against abrasive particles like dirt, sand, and salt Repels water due to its high hydrophobicity Safe on seals, plastics, rubber, paint, and coatings Low VOC’s, no CFC's or Chlorinated Solvents Non-toxic Will not contaminate delicate electronic circuits with silicone particles Usage Parameters Properties Shelf Life a) Theoretical coverage per can for 25 m [0.001”] Temperature Ranges Value 5y
8472-450G 价格&库存
很抱歉,暂时无法提供与“8472-450G”相匹配的价格&库存,您可以联系我们找货
