PA0001
PA0001
    CHIPQUIK
    SOIC-8 TO DIP-8 SMT ADAPTER
PA0001 数据手册
PA0001 Datasheet revision 2.0 www.Proto-Advantage.com SOIC-8 to DIP-8 SMT Adapter (150 mil / 200 mil body) Top side photo (showing pins assembled) Bottom side photo (showing pins assembled) Typical IC package accepted (SOIC-8) Product Highlights Immersion Gold Finish Gold Plated Pins RoHS II and REACH Compliant Comes Unassembled with Pins Included (Allows easier IC installation before the pins are soldered on) Top side of board fits surface mount footprint Bottom side of PCB has pads for two single row surface mount vertical headers (included) Specifications PCB dimensions: PCB construction: PCB operating temperature range: PCB reflow maximum temperature: 0.7” x 0.4” x 0.063” (17.78 mm x 10.16 mm x 1.6 mm) FR-4 UL94V-0 -40°C to +130°C (-40°F to +266°F) +260°C (500°F) Application Notes AN0001: IC Assembly Instructions if Using a Stencil AN0002: Pin Assembly Instructions AN0003: Adapter Selection Guide 1 © 2007-2016 Proto Advantage™ DIMENSIONS REF. A B C D e F G H MIN. mm TYP. MAX. MIN. inches TYP. MAX. 2.90 2.50 0.60 0.67 1.27 0.300 0.100 0.025 Top View (SMT Footprint) A B C e D (Representative drawing only - not to scale) 2 © 2007-2016 Proto Advantage™ Bottom View (DIP Pins) F H G (Representative drawing only - not to scale) Side View (DIP Pins) F (Representative drawing only - not to scale) 3 © 2007-2016 Proto Advantage™
PA0001 价格&库存
很抱歉,暂时无法提供与“PA0001”相匹配的价格&库存,您可以联系我们找货
PA0001
    • 1+30.570091+3.83503
    库存:455
