1325
1325
    ADAFRUIT
    TOOL ANVIL FOR STANDOFFS
1325 数据手册
Adafruit FPC Stick - 20 Pin 0.5mm/1.0mm Pitch Adapter ID: 1325 DESCRIPTION Page 1 of 2 - Page 2 of 2 Connect to 0.5mm, 1.0mm and even some 2.0mm pitch connectors that you may run across with an FPC stick. We designed this for use in house, to quickly connect to FPCs we need to test. But we also thought it might be useful for our customers. On either side is a 20 pin 0.5 or 1.0mm pitch connector with long pads and one very long 'mechanical' pad. Each pad is broken out to a 20-pin long 0.1" spaced header. It can accommodate most ZIF and snap connectors and will make prototyping much easier on you! Each order comes with a single double-sided PCB stick (one side 0.5mm the other 1.0mm), no header or other connectors included. Adafruit FPC Stick - 20 Pin 0.5mm/1.0mm Pitch Adapter (2:15 (https://www.youtube.com/watch? feature=player_detailpage&v=6lFpcLXL9n0#t=135)) http://www.adafruit.com/product/1325 2/23/2015
1325
1. 物料型号:Adafruit FPC Stick - 20 Pin 0.5mm/1.0mm Pitch Adapter,型号ID为1325。 2. 器件简介:这是一个用于连接0.5mm、1.0mm甚至一些2.0mm间距连接器的FPC(柔性印刷电路)适配器。设计用于快速连接需要测试的FPC,也适用于客户使用。 3. 引脚分配:适配器两侧各有一个20针的0.5mm或1.0mm间距连接器,每个引脚都扩展到一个20针的0.1英寸间距的长排针。 4. 参数特性:适配器可以容纳大多数ZIF(零插入力)和快拆连接器,使得原型设计更加容易。 5. 功能详解:适配器设计用于内部测试FPC,也考虑到了客户的便利性,提供了一种快速连接FPC的方法。 6. 应用信息:每个订单包含一个双面PCB条(一侧为0.5mm,另一侧为1.0mm),不包括排针或其他连接器。
很抱歉,暂时无法提供与“1325”相匹配的价格&库存,您可以联系我们找货
