F127T254P20
F127T254P20
    CHIPQUIK
    PITCH CHANGER 1.27 MM TO 2.54 MM
F127T254P20 数据手册
F127T254P20 Datasheet revision 1.0 www.Proto-Advantage.com Pitch Changer 1.27mm to 2.54mm conversion - 20 Pin REF. DIMENSIONS mm TYP. MAX. MIN. MIN. E1 E2 H1 H2 n inches TYP. MAX. 1.27 2.54 0.64 1.00 20 Top View (TH Footprints) E1 H1 1 2 n H2 1 2 n E2 (Representative drawing only - not to scale) Part Number Coding F___T___P__ From Pitch (mm): 1.00, 1.27, 2.00, 2.54 To Pitch (mm): 1.00, 1.27, 2.00, 2.54 Pin Count: 4, 5, 6, 8, 10, 16, 20 Rule: From Pitch ≤ To Pitch 1 Pin Count © 2007-2016 Proto Advantage Orderable Part Numbers Part Number F100T100P04 F100T100P05 F100T100P06 F100T100P08 F100T100P10 F100T100P16 F100T100P20 F100T127P04 F100T127P05 F100T127P06 F100T127P08 F100T127P10 F100T127P16 F100T127P20 F100T200P04 F100T200P05 F100T200P06 F100T200P08 F100T200P10 F100T200P16 F100T200P20 F100T254P04 F100T254P05 F100T254P06 F100T254P08 F100T254P10 F100T254P16 F100T254P20 F127T127P04 F127T127P05 F127T127P06 F127T127P08 F127T127P10 F127T127P16 F127T127P20 2 From Pitch 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm To Pitch 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm Pin Count 4 5 6 8 10 16 20 4 5 6 8 10 16 20 4 5 6 8 10 16 20 4 5 6 8 10 16 20 4 5 6 8 10 16 20 Part Number F127T200P04 F127T200P05 F127T200P06 F127T200P08 F127T200P10 F127T200P16 F127T200P20 F127T254P04 F127T254P05 F127T254P06 F127T254P08 F127T254P10 F127T254P16 F127T254P20 F200T200P04 F200T200P05 F200T200P06 F200T200P08 F200T200P10 F200T200P16 F200T200P20 F200T254P04 F200T254P05 F200T254P06 F200T254P08 F200T254P10 F200T254P16 F200T254P20 F254T254P04 F254T254P05 F254T254P06 F254T254P08 F254T254P10 F254T254P16 F254T254P20 © 2007-2016 Proto Advantage From Pitch 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm To Pitch 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm Pin Count 4 5 6 8 10 16 20 4 5 6 8 10 16 20 4 5 6 8 10 16 20 4 5 6 8 10 16 20 4 5 6 8 10 16 20
F127T254P20
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
F127T254P20 价格&库存
很抱歉,暂时无法提供与“F127T254P20”相匹配的价格&库存,您可以联系我们找货
