F200T254P16
Datasheet revision 1.0
www.Proto-Advantage.com
Pitch Changer 2.00mm to 2.54mm conversion - 16 Pin
REF.
DIMENSIONS
mm
TYP. MAX. MIN.
MIN.
E1
E2
H1
H2
n
inches
TYP. MAX.
2.00
2.54
0.80
1.00
16
Top View (TH Footprints)
E1
H1
1
2
n
H2
1
2
n
E2
(Representative drawing only - not to scale)
Part Number Coding
F___T___P__
From Pitch (mm): 1.00, 1.27, 2.00, 2.54
To Pitch (mm): 1.00, 1.27, 2.00, 2.54
Pin Count: 4, 5, 6, 8, 10, 16, 20
Rule: From Pitch ≤ To Pitch
1
Pin
Count
© 2007-2016 Proto Advantage
Orderable Part Numbers
Part Number
F100T100P04
F100T100P05
F100T100P06
F100T100P08
F100T100P10
F100T100P16
F100T100P20
F100T127P04
F100T127P05
F100T127P06
F100T127P08
F100T127P10
F100T127P16
F100T127P20
F100T200P04
F100T200P05
F100T200P06
F100T200P08
F100T200P10
F100T200P16
F100T200P20
F100T254P04
F100T254P05
F100T254P06
F100T254P08
F100T254P10
F100T254P16
F100T254P20
F127T127P04
F127T127P05
F127T127P06
F127T127P08
F127T127P10
F127T127P16
F127T127P20
2
From
Pitch
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
To
Pitch
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.00mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
Pin
Count
4
5
6
8
10
16
5
6
8
10
16
5
6
8
10
16
5
6
8
10
16
5
6
8
10
16
Part Number
F127T200P04
F127T200P05
F127T200P06
F127T200P08
F127T200P10
F127T200P16
F127T200P20
F127T254P04
F127T254P05
F127T254P06
F127T254P08
F127T254P10
F127T254P16
F127T254P20
F200T200P04
F200T200P05
F200T200P06
F200T200P08
F200T200P10
F200T200P16
F200T200P20
F200T254P04
F200T254P05
F200T254P06
F200T254P08
F200T254P10
F200T254P16
F200T254P20
F254T254P04
F254T254P05
F254T254P06
F254T254P08
F254T254P10
F254T254P16
F254T254P20
From
Pitch
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
1.27mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
To
Pitch
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.00mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
2.54mm
Pin
Count
4
5
6
8
10
16
5
6
8
10
16
5
6
8
10
16
5
6
8
10
16
5
6
8
10
16
很抱歉,暂时无法提供与“F200T254P16”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+26.292331+3.41676
