F200T254P20
F200T254P20
    CHIPQUIK
    PITCH CHANGER 2.00 MM TO 2.54 MM
F200T254P20 数据手册
F200T254P20 Datasheet revision 1.0 www.Proto-Advantage.com Pitch Changer 2.00mm to 2.54mm conversion - 20 Pin REF. DIMENSIONS mm TYP. MAX. MIN. MIN. E1 E2 H1 H2 n inches TYP. MAX. 2.00 2.54 0.80 1.00 20 Top View (TH Footprints) E1 H1 1 2 n H2 1 2 n E2 (Representative drawing only - not to scale) Part Number Coding F___T___P__ From Pitch (mm): 1.00, 1.27, 2.00, 2.54 To Pitch (mm): 1.00, 1.27, 2.00, 2.54 Pin Count: 4, 5, 6, 8, 10, 16, 20 Rule: From Pitch ≤ To Pitch 1 Pin Count © 2007-2016 Proto Advantage Orderable Part Numbers Part Number F100T100P04 F100T100P05 F100T100P06 F100T100P08 F100T100P10 F100T100P16 F100T100P20 F100T127P04 F100T127P05 F100T127P06 F100T127P08 F100T127P10 F100T127P16 F100T127P20 F100T200P04 F100T200P05 F100T200P06 F100T200P08 F100T200P10 F100T200P16 F100T200P20 F100T254P04 F100T254P05 F100T254P06 F100T254P08 F100T254P10 F100T254P16 F100T254P20 F127T127P04 F127T127P05 F127T127P06 F127T127P08 F127T127P10 F127T127P16 F127T127P20 2 From Pitch 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm To Pitch 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.00mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm Pin Count 4 5 6 8 10 16 20 4 5 6 8 10 16 20 4 5 6 8 10 16 20 4 5 6 8 10 16 20 4 5 6 8 10 16 20 Part Number F127T200P04 F127T200P05 F127T200P06 F127T200P08 F127T200P10 F127T200P16 F127T200P20 F127T254P04 F127T254P05 F127T254P06 F127T254P08 F127T254P10 F127T254P16 F127T254P20 F200T200P04 F200T200P05 F200T200P06 F200T200P08 F200T200P10 F200T200P16 F200T200P20 F200T254P04 F200T254P05 F200T254P06 F200T254P08 F200T254P10 F200T254P16 F200T254P20 F254T254P04 F254T254P05 F254T254P06 F254T254P08 F254T254P10 F254T254P16 F254T254P20 © 2007-2016 Proto Advantage From Pitch 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 1.27mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm To Pitch 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.00mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm 2.54mm Pin Count 4 5 6 8 10 16 20 4 5 6 8 10 16 20 4 5 6 8 10 16 20 4 5 6 8 10 16 20 4 5 6 8 10 16 20
F200T254P20
1. 物料型号:文档列出了多种型号的转换器,例如F100T100P04、F100T127P04、F100T200P04、F100T254P04等,这些型号表示不同引脚间距和引脚数量的转换器。
2. 器件简介:文档描述了一种引脚间距转换器,可以将1.00mm、1.27mm、2.00mm的引脚间距转换为1.00mm、1.27mm、2.00mm或2.54mm的引脚间距,适用于20个引脚。
3. 引脚分配:文档提供了一个顶视图的示意图,展示了转换器的引脚布局,但请注意,该图不是按比例绘制的。
4. 参数特性:文档提供了转换器的尺寸参数,包括最小值、典型值和最大值,单位为毫米和英寸。
5. 功能详解:文档没有提供详细的功能描述,但可以推断其功能是实现不同引脚间距的转换。
6. 应用信息:文档没有明确提供应用信息,但这种转换器可能用于需要不同引脚间距的电子设备或电路板之间的连接。
7. 封装信息:文档提供了封装的尺寸信息,包括E1、E2、H1和H2的尺寸。
F200T254P20 价格&库存
很抱歉,暂时无法提供与“F200T254P20”相匹配的价格&库存,您可以联系我们找货
