CN0035
Datasheet revision 1.0
www.Proto-Advantage.com
8P8C (RJ45, Ethernet) adapter board
Product Highlights
This adapter comes fully assembled with connector and pins installed.
Specifications
PCB dimensions:
17.78mm x 20.32mm x 1.6mm
PCB construction:
FR-4 UL94V-0
PCB operating temperature range (without connector):
-40C to +130C
PCB reflow maximum temperature (without connector):
+260C
PCB assembly standard:
IPC-A-610 Class II
1
© 2007-2016 Proto Advantage
很抱歉,暂时无法提供与“CN0035”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+56.031171+7.28140
