1211
1211
    ADAFRUIT
    CONN QC TAB 0.110 SOLDER
1211 数据手册
SMT Breakout PCB for SOIC-12 or TSSOP-12 - 6 Pack! PRODUCT ID: 1211 DESCRIPTION - Beguiled by a fancy new chip that is only available in a SOIC or (T)SSOP pinout? This breakout PCB set will make your life much much easier and get you prototyping faster than ever. One side has a 12-TSSOP pin out with traces going to two rows of 0.1" spaced holes, the other has 12-SOIC. Solder your chip to either side and you're ready to rock on any solderless breadboard. Each item comes with six PCBs, each PCB is identical and can support either a SOIC (narrow, medium or wide variety) or TSSOP. Standard thickness PCBs, with 0.6" spacing between the two rows. You can of course use a smaller chip but the pin numbering wont be right so use care. http://www.adafruit.com/product/1211 10/23/2014
很抱歉,暂时无法提供与“1211”相匹配的价格&库存,您可以联系我们找货
  • 1+43.609741+5.63653
