Page 1 of 2
QFP surface mount
protoboard - 0.50mm
SKU: 319010047
(images/product/QFP surface.jpg)
(https://www.kickstarter.com/projects/seeed/wiolink-3-steps-5-minutes-build-your-iotapplicat/description?ref=banner_depot)
Description
A multi-purpose surface mount protoboard from Dangerous Prototypes. Great for getting started
(http://dangerousprototypes.com/docs/Main_Page#Processor_overviews) with a new microcontroller. It
has footprints for:
32-80pin xQFP packages (TQFP, VQFP, LQFP, etc)
SOIC(W) chips from .150″ to .3″ (max 32 pins)
xSSOP chips (max 32 pins)
Button with pull-up resistor input area (2x)
LED with resistor output area (8x)
SMD or through hole crystal with capacitors
SOT-23-3/5/6 (6x)
0805 R and C (8x, plus extras near IC footprints)
DO-323 (8x)
24×10 pin through-hole prototype area
Power bus routed near all components
Silk labels on top and bottom
Open source (CC-BY-SA)
Don't know your size? See choosing a prototype board
(http://dangerousprototypes.com/docs/Choosing_a_breakout_board).
Documentation (http://dangerousprototypes.com/docs/Dangerous_Protoboards#xQFP_protoboard)
If you encounter any problems when using this product, here is the forum
(http://dangerousprototypes.com/forum/index.php) from which you can get the technical support.
Overview
Page 2 of 2
(http://www.seeedstudio.com/depot/Maker-Pro-t-1672.html?ref=pinfo)
(http://dangerousprototypes.com/forum/)
Other Products From This Designer (http://www.seeedstudio.com/depot/Dangerous-Prototypes-m9.html?ref=pinfo)
Weight: 24 g
http://www.seeedstudio.com/depot/QFP-surface-mount-protoboard-050mm-p-786.html?cP... 12/3/2015
很抱歉,暂时无法提供与“319010047”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+88.124615+11.41371
