319010053
319010053
    SEEED(矽递科技)
    QFPSURFACEMOUNTPROTOBOARD0.6
319010053 数据手册
Page 1 of 2 QFP surface mount protoboard - 0.65mm SKU: 319010053 (images/product/prot61.jpg) (https://www.kickstarter.com/projects/seeed/wiolink-3-steps-5-minutes-build-your-iotapplicat/description?ref=banner_depot) Description A multi-purpose surface mount protoboard from Dangerous Prototypes. Great for getting started (http://dangerousprototypes.com/docs/Main_Page#Processor_overviews) with a new microcontroller. It has footprints for: • • • • • • • • • • • • • 32-80pin xQFP packages (TQFP, VQFP, LQFP, etc) SOIC(W) chips from .150″ to .3″ (max 32 pins) xSSOP chips (max 32 pins) Button with pull-up resistor input area (2x) LED with resistor output area (8x) SMD or through hole crystal with capacitors SOT-23-3/5/6 (6x) 0805 R and C (8x, plus extras near IC footprints) DO-323 (8x) 24×10 pin through-hole prototype area Power bus routed near all components Silk labels on top and bottom Open source (CC-BY-SA) Don't know your size? See choosing a prototype board (http://dangerousprototypes.com/docs/Choosing_a_breakout_board).  Documentation (http://dangerousprototypes.com/docs/Dangerous_Protoboards#xQFP_protoboard) If you encounter any problems when using this product, here is the forum (http://dangerousprototypes.com/forum/index.php) from which you can get the technical support. Overview Page 2 of 2 (http://www.seeedstudio.com/depot/Maker-Pro-t-1672.html?ref=pinfo) Designer: Dangerous Prototypes (http://dangerousprototypes.com/forum/) Other Products From This Designer (http://www.seeedstudio.com/depot/Dangerous-Prototypes-m9.html?ref=pinfo) Weight: 24 g http://www.seeedstudio.com/depot/QFP-surface-mount-protoboard-065mm-p-785.html?cP... 12/3/2015
319010053 价格&库存
很抱歉,暂时无法提供与“319010053”相匹配的价格&库存,您可以联系我们找货
