1377
1377
    ADAFRUIT
    SMT BREAKOUT PCB 48QFN/TQFP 3PK
1377 数据手册
Page 1 of 2 SMT Breakout PCB for 48-QFN or 48-TQFP 3 Pack! PRODUCT ID: 1377 Page 2 of 2 DESCRIPTION - Beguiled by a fancy new chip that is only available in a QFP or QFN pinout? This breakout PCB set will make your life much much easier and get you prototyping faster than ever. One side has a 48-QFP pin out with traces going to two rows of 0.1" spaced holes, the other has 48-QFN (7mm body). Solder your chip to either side and you're ready to rock on any solderless breadboard. There's even a THM pad on the opposite side of the QFN body pad so you can fill it with solder for a heat sink and/or connect a wire to it (say when the pad must be grounded). Each item comes with three PCBs, each PCB is identical and can support either a 7mm square QFP or 7mm square QFN chip. Standard thickness PCBs, with 0.7" spacing between the two rows. The PCBs may come on a supporting strip of PCB, simply snap them off to use! http://www.adafruit.com/products/1377 10/5/2015
1377
1. 物料型号:产品ID为1377。 2. 器件简介:这种Breakout PCB用于快速原型设计,适用于那些只有QFP或QFN引脚配置的新芯片。 3. 引脚分配:PCB的一面有48-QFP引脚布局,另一面有48-QFN(7mm体)布局。引脚通过走线连接到两排0.1英寸间距的孔。 4. 参数特性:每个项目包含三个相同的PCB,每个PCB可以支持7mm x 7mm的QFP或QFN芯片。PCB标准厚度,两排孔之间间距为0.7英寸。 5. 功能详解:用户可以将芯片焊接到任一侧,即可在任何无焊面包板上使用。QFN体垫对面还有一个THM垫,可以用作散热片或连接地线。 6. 应用信息:适用于快速原型设计,方便用户使用新芯片。 7. 封装信息:PCB可能附带在PCB支撑条上,使用时可以将其折断。
很抱歉,暂时无法提供与“1377”相匹配的价格&库存,您可以联系我们找货
  • 1+45.35226
库存:9
