CN0036
CN0036
    CHIPQUIK
    QSTRIP QTH-060-01-L-D-A ADAPTER
CN0036 数据手册
CN0036 Datasheet revision 1.0 www.Proto-Advantage.com QStrip QTH-060-01-L-D-A adapter board Product Highlights This adapter comes fully assembled with connector and pins installed. Specifications PCB dimensions: 38.1mm x 162.56mm x 1.6mm PCB construction: FR-4 UL94V-0 PCB operating temperature range (without connector): -40C to +130C PCB reflow maximum temperature (without connector): +260C PCB assembly standard: IPC-A-610 Class II 1 © 2007-2016 Proto Advantage
CN0036 价格&库存
很抱歉,暂时无法提供与“CN0036”相匹配的价格&库存,您可以联系我们找货
