CN0023
Datasheet revision 1.1
www.Proto-Advantage.com
MicroSD adapter board
Product Highlights
This adapter comes fully assembled with connector and pins installed.
Specifications
PCB dimensions:
25.4mm x 25.4mm x 1.6mm
PCB construction:
FR-4 UL94V-0
PCB operating temperature range (without connector):
-40C to +130C
PCB reflow maximum temperature (without connector):
+260C
PCB assembly standard:
IPC-A-610 Class II
Pinout
Pin Number
1
2
3
4
5
6
7
8
9
SD
DAT2
DAT3
CMD
VDD
CLK
VSS
DAT0
DAT1
/SW
CS
DI
VDD
SCLK
VSS
DO
10
SW_GND
SW_GND
1
SPI
/SW
Description
Switch that indicates a card is inserted. Connects to SW_GND when
a card is inserted. Connect to digital input on microcontroller with a
pull-up resistor.
Switch ground. Connect to circuit ground.
© 2007-2016 Proto Advantage
很抱歉,暂时无法提供与“CN0023”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+92.016271+11.52767
