PA-TQFP-BB001-1
PA-TQFP-BB001-1
    CHIPQUIK
    TQFP 48,64,80,100 PIN BREADBOARD
PA-TQFP-BB001-1 数据手册
PA-TQFP-BB001-1 Datasheet revision 1.0 www.Proto-Advantage.com TQFP 48, 64, 80, 100 pin breadboard - TH Description Same footprint as TQFP/QFP adapter P/N: PCB3006-1 0.5mm pitch, with breakout to 0.1" pitch holes on 0.1" x-y grid for male or female headers and through hole components. Fits 48, 64, 80 or 100 pin TQFPs, PQFPs, QFPs. Fits popular microcontrollers such as PIC18F, PIC24, dsPIC, and MSP430. Includes breadboarding area for building circuits around the main IC. Specifications Dimensions: 4" x 4" x 1/16" (101.6mm x 101.6mm x 1.6mm) PCB construction: FR-4 UL94V-0 PCB operating temperature range: -40C to +130C PCB reflow maximum temperature: +260C Hole size: 1 1.0mm (40 mils) diameter. Holes accept 25 mil square wire wrap posts. © 2007-2016 Proto Advantage™
PA-TQFP-BB001-1
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号路由和信号选择。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换,具有低导通电阻和快速响应时间。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
PA-TQFP-BB001-1 价格&库存
很抱歉,暂时无法提供与“PA-TQFP-BB001-1”相匹配的价格&库存,您可以联系我们找货
