1762
1762
    ADAFRUIT
    LAMP INCAND T1-3/4 WIRE TERM
1762 数据手册
5050 LED breakout PCB - 10 pack! PRODUCT ID: 1762 DESCRIPTION - This 5050 LED breakout PCB set will make your life much much easier and get you prototyping faster than ever. Solder your 5050 sized LED to either side and you're ready to rock on any solderless breadboard. Each item comes with ten PCBs and each PCB is identical. PCB is .8mm/.03" thick, with ~10mm/0.4" spacing between the two rows. http://www.adafruit.com/product/1762 11/12/2015 Technical Details Each PCB is: 13mm x 8mm / .5" x .3" .8mm / .03" thick Each PCB weighs .16g
很抱歉,暂时无法提供与“1762”相匹配的价格&库存,您可以联系我们找货
