334
334
    ADAFRUIT
    ROUND STANDOFF 4-40 BRASS 7/8"
334 数据手册
Touch screen breakout board (0.5mm FPC) PRODUCT ID: 334 10/23/2014 DESCRIPTION - If you've got a resistive touch screen that you'd like to use, you'll need this breakout! It has a fine pitch (0.5mm) connector soldered onto it and it's broken out into the 4 resistive wires of the panel. A petite 0.5"x0.5" (12.5mm x 12.5mm) with two mounting holes as well, that you can use for strain relief. Works perfectly with our 3.2" touch screen (//www.adafruit.com/product/333) We don't have a detailed tutorial yet but we do have great example Arduino library code that shows how to get readings, debounce, and read the pressure from any touch screen (so you can detect when its being touched and how hard) (https://github.com/adafruit/Touch-Screen-Library) The code is not complex and is easily ported to other microcontrollers. MAY WE ALSO SUGGEST... - Resistive Touch Screen Controller - (https://verify.authorize.net/anetseal/? pid=1de2c247-f7e6492b-99d8fb648be79ff1&rurl=http% 3A//www.adafruit.com/product/334) Online Payments (http://www.authorize.net/) http://www.adafruit.com/product/334 10/23/2014
很抱歉,暂时无法提供与“334”相匹配的价格&库存,您可以联系我们找货
    库存:25
