CN0020
CN0020
    CHIPQUIK
    JACK2.5MMID,5.5MMODADAPTER
CN0020 数据手册
CN0020 Datasheet revision 1.0 www.Proto-Advantage.com Jack 2.5mm ID, 5.5mm OD adapter board Product Highlights This adapter comes fully assembled with connector and pins installed. Specifications PCB dimensions: 17.78mm x 10.16mm x 1.6mm PCB construction: FR-4 UL94V-0 PCB operating temperature range (without connector): -40C to +130C PCB reflow maximum temperature (without connector): +260C PCB assembly standard: IPC-A-610 Class II 1 © 2007-2016 Proto Advantage
CN0020 价格&库存
很抱歉,暂时无法提供与“CN0020”相匹配的价格&库存,您可以联系我们找货
CN0020
    • 1+46.387351+5.80200
    库存:12
